1天前
查看: 20021|回复: 51
[已解决] HSM Performance Pack v.2.3.3.6892 for Mastercam 9.1 crack (by kiev78)
发表于 2008-9-16 03:48:05 | 显示全部楼层 |阅读模式 来自: 俄罗斯
1) Install Mastercam 9.1 7 f# A9 y! [+ D! v& L3 H3 k4 d9 o
) E* P. ]* [! @# i2) Download and install Mastercam HSM Performance Pack v.2.3.3.6892
- z, r, S; U- r! @0 S7 t$ f* `$ [8 l6 Z! g$ l% B
3) Download a crack (for more info read readme!.txt in crack archive)+ D$ w% B- [5 T; [
- x/ |' z! w  u, c4 h
Attention!$ M9 H) Y  k; j0 x) K
HSM Performance Pack v.2.3.3.6892 does not work under Windows XP SP3!
hsm_2.3.3. 6892_for_mc9.1_crk.rar
15.87 KB, 下载次数: 729
发表于 2008-9-16 05:10:25 | 显示全部楼层 来自: 中国广东深圳
Sofa! Thank you very much
发表于 2008-9-16 05:16:52 | 显示全部楼层 来自: 中国广东深圳
HSM Performance Pack v.2.3.3.6892 does not work under Windows XP SP3! % Q2 }/ k1 {0 j/ ^2 P  i: z5 x- ^
) B" G+ a3 g1 V/ Q3 XI am using is the SP3
 楼主| 发表于 2008-9-16 05:24:06 | 显示全部楼层 来自: 俄罗斯
原帖由 joks 于 2008-9-16 05:16 发表 http://www.3dportal.cn/discuz/images/common/back.gif
- @, v% L$ e$ J* GI am using is the SP3
/ x4 [) e! s" f
Sorry, You've got a bad luck # s3 w6 p2 T: D, \
Win XP SP3 has a bag with reading intermediate toolpath results file in HSM 2.3.3.6892 .. So it can not build a toolpaths...
) ]1 b& W4 u% D2 O& o- G0 \& ]9 i+ r
[ 本帖最后由 solid_user 于 2008-9-16 05:28 编辑 ]
发表于 2008-9-16 05:34:56 | 显示全部楼层 来自: 中国广东深圳
HSM 2.3.3.6892 seems not the final version?
 楼主| 发表于 2008-9-16 05:47:37 | 显示全部楼层 来自: 俄罗斯
原帖由 joks 于 2008-9-16 05:34 发表 http://www.3dportal.cn/discuz/images/common/back.gif% ]3 D( _0 y% B( f! m3 ]0 `4 V4 a4 f
9 d; Q& i, V! r3 II don't know.. If you have got a newer than HSM 2.3.3.6892 Installation for Mc9.1 I can try to make a crack.  Maybe it will be work under Windows XP XP3
9 G) V; {. R, d+ Y# n% m! F6 U: |' p# N
BTW HSM 3.0.31 for MC X-X3 is already released om cimco-hsm.com $ U! j2 a" I( b
. N* P; b4 r: ]7 ?! {- ~) n+ G$ a[ 本帖最后由 solid_user 于 2008-9-16 05:49 编辑 ]
发表于 2008-9-16 06:11:04 | 显示全部楼层 来自: 中国广东深圳
error: failed to read from kernel stream (please try to repair the installation)( V' l' ]: s" \
error: toolpath generation failed
0 h; Q7 U; L/ g2 Z8 K5 l' c1 [* E9 q5 Q- \/ ^' d$ |+ {- v6 b/ m6 P
I think I have to change the system
 楼主| 发表于 2008-9-16 06:28:46 | 显示全部楼层 来自: 俄罗斯
原帖由 joks 于 2008-9-16 06:11 发表 http://www.3dportal.cn/discuz/images/common/back.gif
4 I. ?2 F# G' c, t/ g5 `error: failed to read from kernel stream (please try to repair the installation)' `7 U% `  M" j* z8 h( z- d
- j' `( ~6 I. i
" P9 x; a. y7 m/ D* j) o% NI think I have to change the system
9 u9 w' _* l+ @3 i
That's bug of Win XP SP3 I said...
% w" i% d, d' J. M6 Q$ jIn Win XP SP2 all works and you will not get that message
8 o/ V+ K! t* }: N5 G( F- L0 Y; h6 v; z) i
[ 本帖最后由 solid_user 于 2008-9-16 06:37 编辑 ]
发表于 2008-9-16 06:29:00 | 显示全部楼层 来自: 中国广东深圳
I have updated 3.0.31  ! you are still using SP2 system?:lol:
 楼主| 发表于 2008-9-16 06:41:56 | 显示全部楼层 来自: 俄罗斯
原帖由 joks 于 2008-9-16 06:29 发表 http://www.3dportal.cn/discuz/images/common/back.gif
! v9 C2 S. M) @3 T9 M) M6 q I have updated 3.0.31  ! you are still using SP2 system?:lol:
- i, F5 h/ b  D: \0 II use different OS's on different computers..
0 w$ i( G* ?+ ?1 v3 u& FAs for HSM 3.x.x it's good but it can not be run under MC 9.1... I think you need HSM not only for MC X-X3 but for MC 9.1 too.. Isn't it?: n5 D8 [5 O. H
" i  a3 `( j3 U3 j0 y. s8 O
BTW MoldPlus v10 SP0 for Mastercam X3 is already released on mastercam.fi
3 k8 m( a6 A" |; q- a  E- V, f5 b. j5 T4 P
[ 本帖最后由 solid_user 于 2008-9-16 06:45 编辑 ]
发表于 2008-9-16 06:54:34 | 显示全部楼层 来自: 中国广东深圳
HSM 3.0.31 more beautiful, contour strategy pity or no smoothing deviation, looking forward to improving!
; {( |- I) d( C8 x  ^4 @
: s1 p! u. q$ O5 A! h' S( v contur1.png contur2.png
发表于 2008-9-16 07:13:39 | 显示全部楼层 来自: 中国广东深圳
I use different OS's on different computers..   =             Oh!
0 ?$ t; i+ U8 S: X. x: x$ f
3 v  Y( ~1 b- WAs for HSM 3.x.x it's  but it can not be run under MC 9.1... I think you need HSM not only for MC X-X3 but for MC 9.1 too.. Isn't it?                     =    Yes! I started learning is the most Mastercam, I like mastercam!+ l: o) t5 v1 f8 n7 T, Y( @  B6 }
/ T# I4 a, p6 T% |  HBTW MoldPlus v10 SP0 for Mastercam X3 is already released on mastercam.fi     =                Moldplus_10_SP0_for_X3 can use it without Crack ?
发表于 2008-9-16 08:02:24 | 显示全部楼层 来自: 亚太地区
感谢楼主无私奉献:call:
发表于 2008-9-16 09:32:49 | 显示全部楼层 来自: 中国广东深圳
谢谢"solid_user"老大,又有好东西了.
发表于 2008-9-16 09:40:32 | 显示全部楼层 来自: 中国贵州遵义
谢谢,不知有没有中文的。
发表于 2008-9-16 11:39:06 | 显示全部楼层 来自: 中国广东惠州
谢谢 solid_user,跟以前9.0HSMCrack有什么不同吗8 S. P2 i5 A2 k; t) A
0 J( O5 X4 D) c& d# w: v
[ 本帖最后由 OUCEGEN 于 2008-9-16 12:55 编辑 ]
发表于 2008-9-16 11:56:16 | 显示全部楼层 来自: 中国江苏苏州
感谢楼主!我看看和以前的有什么不同?
发表于 2008-9-16 21:07:09 | 显示全部楼层 来自: 中国台湾
dear  solid_user brother: thank you very much....
发表于 2008-9-17 10:54:01 | 显示全部楼层 来自: 中国上海
error: failed to read from kernel stream (please try to repair the installation)( P$ |/ K( F6 \( P2 W" [
error: toolpath generation failed - g/ |- }1 T' o) p$ ]2 Y/ j
WORK IN SP2
发表于 2008-9-17 10:56:56 | 显示全部楼层 来自: 中国上海
error: failed to read from kernel stream (please try to repair the installation): ]$ N. [' Y2 g" v% P
error: toolpath generation failed 3 D% _8 \% F9 U, k
WORK IN SP2
发表于 2008-9-17 11:44:54 | 显示全部楼层 来自: 中国江苏苏州
我和楼上的问题一样
 楼主| 发表于 2008-9-17 15:40:05 | 显示全部楼层 来自: 俄罗斯
原帖由 ryanhe2008 于 2008-9-17 10:56 发表 http://www.3dportal.cn/discuz/images/common/back.gif
' j$ S0 P* B3 i$ d2 \9 D, A) derror: failed to read from kernel stream (please try to repair the installation)  W( S1 D1 a9 }0 u. n% d" G
error: toolpath generation failed 1 g$ |1 I2 v+ _' i# l8 j8 D
WORK IN SP2
4 N% h# O5 J- H, x
I suppose that you have install some of Windows XP2 Update wich couse this bug..+ l; q, |+ `$ n5 q+ ?# D
In any case it's bug of Windows..
发表于 2008-9-17 22:19:58 | 显示全部楼层 来自: 中国四川成都
好用是好用!不过英文版的看着很费力!
发表于 2008-9-18 11:37:48 | 显示全部楼层 来自: 中国台湾
感謝您的分享!good
发表于 2008-9-18 17:17:46 | 显示全部楼层 来自: 中国浙江宁波
回复 8# solid_user 的帖子
老大    这东西我都找X年了     多谢
