查看: 3002|回复: 2
[已解决] TN-C-S系统中的TN,C,S分别的英文单词是什么?
发表于 2007-7-10 09:16:17 | 显示全部楼层 |阅读模式 来自: 中国北京
TN-C-S系统中的TN,C,S分别的英文单词是什么?不要中文,谢谢!; h. ^! K' E1 D
0 V5 k' _, P0 E. x; p[ 本帖最后由 bdblbyq 于 2007-7-11 12:34 编辑 ]
发表于 2007-7-10 18:05:52 | 显示全部楼层 来自: 中国河南南阳
仅供参考
Terra Neutral-Combined-Separate
" q+ X0 p; t+ e1 X5 B* u; J4 `0 R8 I- Y3 @
9 ^% s; v* G4 g, [* x% l7 K1 k2 \7 R7 A! I7 `1 s# C& \- }% ~
International standard IEC 60364 distinguishes three families of earthing arrangements, using the two-letter codes TN, TT, and IT.5 T6 e5 M0 i3 m; Y& y
+ b4 i+ R! {' t  X* D
The first letter indicates the connection between earth and the power-supply equipment (generator or transformer):. C. n7 a6 k; ?* Y
7 g( s* }/ g1 L& \- c. j- N* KT  :  direct connection of a point with earth (French: terre); & Z7 K9 v$ q5 P( L3 u
I  :  no point is connected with earth (isolation), except perhaps via a high impedance. : B; e- X% k/ }2 {. z2 A
4 }/ s8 W4 \+ m5 t8 G; K
The second letter indicates the connection between earth and the electrical device being supplied:8 Z. i' ^: z6 c) `
. Q: }2 ?6 F" U' r8 \' ?T  :  direct connection with earth, independent of any other earth connection in the supply system;
3 i/ F9 e3 P: n8 N; q- z) ~N  :  connection to earth via the supply network
0 \5 _) a" C  s; u: P# X& a5 T' U7 K. S+ H! [7 f9 X
3 H8 U  y! t8 I2 A3 `  `% n
The conductor that connects the exposed metallic parts of the consumer is called protective earth (PE). The conductor that connects to the star point in a three-phase system, or that carries the return current in a single-phase system, is called neutral (N). Three variants of TN systems are distinguished:- j! {3 F" i* M: n
3 ?7 ]  W. r0 S& Y3 y9 q/ P
TN‑S  :  PE and N are separate conductors that are connected together only near the power source. ) q4 e2 J  N: V
TN‑C  :  A combined PEN conductor fulfils the functions of both a PE and an N conductor.
/ o- _7 o8 }2 B: E; vTN‑C‑S  :  Part of the system uses a combined PEN conductor, which is at some point split up into separate PE and N lines. The combined PEN conductor typically occurs between the substation and the entry point into the building, whereas within the building separate PE and N conductors are used. In the UK, this system is also known as protective multiple earthing (PME), because of the practice of connecting the combined neutral-and-earth conductor to real earth at many locations, to reduce the risk of broken neutrals - with a similar system in Australia being designated as multiple earthed neutral (MEN).
bdblbyq + 5 应助
 楼主| 发表于 2007-7-11 09:21:30 | 显示全部楼层 来自: 中国北京
很详细
很详细,谢谢!有关它的英文标准吗?
