楼主 |
发表于 2012-2-18 22:32:41
来自: 中国台湾
密密麻麻大大...你那視窗是怎叫出來的..2樓的大大..我在DOS裡叫出來的很多數字...哪一組才是阿( Q* R8 C0 L U
Microsoft Windows XP [版本 5.1.2600]5 e' J6 e5 p& j. r1 w
(C) Copyright 1985-2001 Microsoft Corp.
/ d% K( J/ ]1 W+ t; G" d( i: z# P% y( Y
C:\Documents and Settings\USER0555>ipconfig/all
$ Z {" ?/ X$ a9 r
( c& s' n$ `9 Z! B3 J0 i" fWindows IP Configuration! i9 B4 Z+ Q% F% g% k$ d
0 f% c! F5 d# [- O$ E
Host Name . . . . . . . . . . . . : USER05551 ^* y) B# m9 j9 W
Primary Dns Suffix . . . . . . . :
/ q6 V; |% j( M4 ^1 l Node Type . . . . . . . . . . . . : Unknown
% Q3 I1 I0 K! T- B8 J; Y IP Routing Enabled. . . . . . . . : No# d2 U& `4 m; y2 G+ y7 f: s! N P4 W
WINS Proxy Enabled. . . . . . . . : No
3 A* S* W8 N& r ^/ S1 y9 T0 K' U8 N+ _* A! v1 n, l
Ethernet adapter 區域連線:/ T& L) Z) {+ h F8 p1 I
* o& w: c. Y" t# s1 z4 g2 t Connection-specific DNS Suffix . :
2 e# d4 E) ?% l, M) }& w Description . . . . . . . . . . . : Realtek RTL8139 Family PCI
9 H9 G# J- v3 Lrnet NIC+ f! f8 O! K/ u6 Z( K
Physical Address. . . . . . . . . : 00-0D-61-1F-23-93. u7 J4 F5 O0 s0 ~0 U
Dhcp Enabled. . . . . . . . . . . : Yes
2 G2 j' d" ?/ D% C Autoconfiguration Enabled . . . . : Yes
1 C6 n5 F2 g- `: c Autoconfiguration IP Address. . . : 169.254.151.28; a" G) @7 ^* V' F, u
Subnet Mask . . . . . . . . . . . : 255.255.0.0
7 d. Q9 A: s- H* \( R+ S: g/ n Default Gateway . . . . . . . . . :
; z5 K9 b" ]) L2 P# t
t" {2 ]7 Y6 z( [/ q9 z) yPPP adapter ADSL:
% E4 R/ ?9 G2 J1 a: [
; v y, c( i3 H+ ~+ `0 L1 _ Connection-specific DNS Suffix . :% N S2 j# _, x; V
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
( {/ g$ X$ Y3 O" y$ D; S( ? Physical Address. . . . . . . . . : 00-53-45-00-00-00" ~: p) ` v$ \8 A
Dhcp Enabled. . . . . . . . . . . : No
7 b, x: u& `) N% D. i, E$ M/ H IP Address. . . . . . . . . . . . : 118.170.128.213
7 k2 u Q4 A3 C6 z Subnet Mask . . . . . . . . . . . : 255.255.255.255( {4 `4 L/ w8 E* I) t& K; X, c
Default Gateway . . . . . . . . . : 118.170.128.213, z! E. g) U& q
DNS Servers . . . . . . . . . . . : 168.95.192.1
# |: o; ]& l5 Z( n& N! W) ^ 168.95.1.19 T* u$ c. ^: |
NetBIOS over Tcpip. . . . . . . . : Disabled7 W* W; I* N) v3 P9 X1 m' C5 G2 d
% a; x; y' D8 g: l9 C3 o: `
C:\Documents and Settings\USER0555> |
