Board logo
标题: [分享] 机械字典1 [打印本页]
作者: jiang1019    时间: 2008-7-31 16:07     标题: 机械字典1
A
电镀electroplating
阿[a]
阿登生圈Adamson ring
阿登生式炉胆Adamson furnace; Adamson type furnace
埃[ai]
anstrom unit (A)
安[an]
安定化shake-down
安定到弹性行为 shakedown to elastic action
安定状态 shake-down
安培计分流器ammeter shunt
压力容器安全技术监督规程 supervision regulation on safety technology for pressure vessels
安全阀safety valve
安全阀回座压力 blow-down for safety valve
安全阀接口connections to safety valve
安全阀壳casing of safety valve
安全阀排放量 discharge capacity of safety valve
安全阀排汽管 discharge pipe from safety valve
安全阀容量换算 capacity conversion for safety valve
安全阀整定压力 safety valve setting]
安全规则 rules of safety
安全壳 containment vessel
安全排放地点safe discharge point
安全-破坏空间 safety-failure space
安全释放地点 safe point of discharge
安全水平 safe level
安全停堆safe shutdown
安全温度范围 safe temperature limits
安全限度safe limits
安全泄压阀safety relief valve
安全系数safety factor
    安全应力范围 safe range of stress
安全运行寿命safe operation life
安全装置safety appliance
安全装置失灵 circumventing of safety device
安匝ampere turns
安装mounting
安装队伍 erection staff
安装方法 assembly method
安装静载荷 erection dead load
安装者的钢印assembler’s stamp
氨[an]
氨合成塔ammonia converter
鞍[an]
鞍式支座saddle support
鞍式支座卧式容器horizontal vessel on saddle support
鞍型接管 saddle type nozzle
鞍座 saddle
鞍座包角contact angle of saddle support
鞍座边角horn of saddle
鞍座反力reaction of saddle
鞍座宽度width of saddle support
鞍座数目 number of saddle support
鞍座位置 location of saddle support
鞍座型连接件saddle type fittings
按[an]
按规范检验 code inspection
按规范建造的过程 code construction process
暗[an]
暗带 dark band
暗盒 cassette
暗红色dull red
凹[ao]
凹槽 recess; groove
凹角焊缝concave fillet weld
凹口接头rabbet joint
凹面concave side
凹凸面法兰male and female (facing )flange
凹凸密封面 male-female seal face
凹形concave; dishing
凹形爆破片reverse buckling rupture disk
凹陷sag
奥[ao]
奥氏体不锈钢austenitic stainless steel
奥氏体钢austenitic steel
奥氏体铬镍不锈钢 austenitic chromium-nickel stainless steel
奥氏体晶界austenite grain boundaries
奥氏体抗蠕变速器钢austenitic creep-resistant steel
A
A-    No.成分阶段 A-number analysis
A-    型扫描 A-scan
ANSI钢制管法兰和附件标准ANSI standard pipe flanges and fittings
ASME标志ASME symbols
ASME规范技术内容technical aspects of the ASME code.
ASME指定人员ASME designee
ASTM代号ASTM designation
AWS型号AWS classification
B
八[ba]
八角垫octagonal ring
八字型开裂chevron cracking
巴[ba]
巴氏裂纹扩展公式Paris crack growth equation
钯[ba]
钯屏检漏仪palladium barrier leak detector
靶[ba]
靶板target
靶板/底铁界面target/anvil interface
靶板厚度target thickness
白[bai]
白点fish-eye
白光white light
百分误差percent error
百万电子伏Mev=million electron volts
摆[bai]
摆动焊weave bead welding; welding with weaving
摆动焊道 weave bead
摆幅oscillation displacement
扳[ban]
扳边的板flanged sheet
扳边开孔flued opening
扳紧螺纹用的面wrenching surfaces
扳手spanner; wrench
扳手面wrenching surfaces
扳弯试验deflection bend test
班[ban]
班数number of shift
颁[ban]
颁发issuance
搬[ban]
搬运handling; carry; transport
板[ban]
板边plate edge; edges of plates
板边偏移plate edge offset
板边缺陷edge imperfections
板波plate wave
板材的确认plate material validation
板材的验收plate material receipt
板材识别号plate identification number
板翅式换热器plate-fin exchanger
板的串动和变形plate shifting and warpage
板的底角处bottom corner of plate
板的两端both ends of the plate
板的位置plate position
板和壳 plate and shell
板厚中部mid-thickness
板壳理论plate and shell theory
板坯slab
板式换热器plate heat exchanger(PHE)
板条lath
板条覆盖strip covering
板条状马氏体lath martensite
板头预弯pre-setting of the ends
板桩sheet piling
半[ban]
半顶角half apex-angle
半焊道half-bead
半焊道法half bead technique
半价层厚度half-value thickness (HVT)
(半)径比radius ratio
半精加工semi-finished
半经验基础semi empirical basis
半靠背half coupling
半波电流half-wave current (HW)
半波整流电流half-wave rectified current
半烟煤semibituminous coal
半圆形顶板semicircle top sheet
半圆形火箱顶板semicircular crown sheet
半自动焊semi-automatic welding
半自动弧焊semiautomatic arc welding
半自动弧焊机semiautomatic arc welding machine
半自动钎焊semiautomatic brazing]
半镇静钢semi-killed steel
半镇静状态semi-killed state
半值层厚度half-value thickness (HVT)
瓣[ban]
瓣片petal-shaped pieces; petals;curved plate segments
棒[bang]
棒材bar; bar stock material
棒钢steel bar
棒料bar stock
包[bao]
包复板上的开孔opening in wrapper sheet
包角contact angle
包晶反应peritectic reaction
包括在内inclusive
包内真空除气法ladle degassing
包札式容器wrapped vessel
包装packaging
包装标记package marking
薄[bao]
薄板sheet
薄板坯sheet bar
薄壁容器 thin-walled vessel
薄壁套管thin-walled sleeve
薄壁柱壳thin-wall cylindrical shell
薄壳membrane shell
薄壳理论membrane shell theory
薄壳微体thin-shell elements
薄膜力membrane force
薄膜应力membrane stress
薄膜应力的合力membrane stress resultant
薄膜应力分析membrane stress analysis
薄膜应力强度membrane stress intensity
薄膜应力概念membrane stress concept
薄片thin sheet
薄片弯曲slice bend
薄片状的lamellar
薄弱环节weak link
薄药皮焊条lightly coated electrode
饱[bao]
饱和电平saturation level
饱和温度saturation level
饱和蒸汽安全阀saturated-steam safety valve
饱和蒸汽温度saturated steam temperature
饱和状态的疏水器saturated drain
保[bao]
保持泵holding pump
保持块retainer
保护层buffer
保护连锁装置protective interlocks
保护膜 protective film
保护气体shroud gas; shrouding gas; protective atmosphere; cover gas
保护涂层protective coating
保护装置secured by guide; guard arrangement
保留不予修理left unrepaired
保留垫板permanent backing
保留在原处left in place
保守的conservative
保守观点 conservatism
保守主义conservatism
保单费用warranty cost
保温insulation;lagging
保温阶段holding period
保温期间holding period
保温时间soak time; time at soak temperature; holding times at temperature; time at temperature
保温视镜thermo-protective sight glass
保温温度soak temperature
保险公司insurance company
保险式fail-safe manner
保险单 Insurance policy
报[bao]
报废率rejection rate
报废原因cause for rejection
报价tender
保审设计designs for approval
暴[bao]
暴露表面exposed surfaces
鲍[bao]
鲍辛格效应Bauschinger effect
爆[bao]
爆轰产物detonation products
爆轰膨胀产物expanding detonation products
爆轰速度detonation velocity
爆破片bursting disk; rupture disk
爆破片爆破试验bursting test of rupture disk
爆破片箔材foil of rupture disk
爆破片额定泄放流量rated discharge capacity of rupture disk
爆破片公称直径norminal diameter of rupture disk
爆破片夹盘rupture disk holder
爆破片坯片blank of rupture disk
爆破片起拱工艺和爆破试验technological doming and bursting test of rupture disk
爆破试验burst test; bursting test
爆破片试验泄放流量test discharge capacity of rupture disk
爆破片泄放直径discharge diameter of rupture disk
爆破片泄压面积relief area of rupture disk
爆破片装置rupture disk device
爆破片最大泄放流量maximum discharge capacity of rupture disk
爆破片最小泄放面积minimum net flow area of rupture disk
爆破片温度允差tolerance of bursting temperature
爆破压力bursting pressure
爆破压力允差tolerance of bursting pressure
爆破元件rupture element
爆炸成形explosive forming
爆炸复合板explosively clad plate
爆炸复合法explosive cladding
爆炸复合连接件explosive clad connections
爆炸过渡explosive transfer
爆炸焊explosive welding
爆炸焊技术explosive welding technique
爆炸焊塞子explosively welded plug
爆炸焊修理技术explosive welding repair technique
爆炸气浪blast
爆炸塞焊技术explosive plugging
爆炸消除应力explosive stress relieving
爆炸胀接explosive expansion
爆炸滴喷射过渡explosive droplet spray transfer
爆破允差bursting tolerance
爆破片装置额定泄放系数rated relieving coefficient of bursting disc device
爆破片试样爆破试验burst testing of sample bursting disc
爆破片装置额定泄放量rated relieving capacity of bursting disc device
爆破片装置实际泄放量actual relieving capacity of bursting device
爆破片装置理论泄放量theoretical relieving capacity of bursting disc device
爆破片装置泄放面积relief area of bursting disc device
爆破片装置公称直径nominal diameter of bursting disc device
爆破片装置泄放直径relief diameter of bursting disc device
爆破片夹持器bursting disc holder
爆破片组件bursting disc assembly
杯[bei]
杯-锥状断裂面cup-and-cone form fracture surface
贝[bei]
贝氏体bainite
贝氏体钢bainite steel
贝氏体相变bainitic transformation
贝氏体-针状铁素体钢bainitic-acicular ferrite steels
贝氏体转变bainite transformation
贝壳状条纹oyster shell markings
背[bei]
背部连接件back connections
背反射back reflection
背风侧leeward side
背加压试验back pressurizing testing
背面back face; root surface
背面侧side evading the wind
背面缝隙back crevice
背面焊缝back-face weld
背面焊接back-face welding
背面余高root reinforcement
背压back pressure
背压托架back pressure support
被[bei]
被捕集的射流trapped jet
被紧密装配在一起的表面closely fitted surfaces
被录用的焊工approved welders
被强烈氧化的表面drossed surface
被摄物衬度subject contrast
被摄物对比度subject contrast
被授权的代表authorized representative
被水湿润的锅炉受压元件water wetted boiler pressure parts
被正式授权的官员duly authorized officer
倍[bei]
倍尺长度multiple lengths
本[ben]
作者: jiang1019    时间: 2008-7-31 16:10     标题: 机械字典2
本底background
本底信号background signal
本体试块test lug
本底荧光background fluorescence
本影umbra
本票 promissory
[beng]
泵壳casing of pump
[beng]
迸裂点pop-in point
迸裂现象phenomenon of pop-in
[bi]
比较测量comparative measurements
比较读数comparative reader
比较试块comparative test block
比较线圈comparator coils
比较系统comparative system
比例极限limit of proportionality; proportional limit
比例探头proportioning probe
[bi]
笔试written examination
[bi]
必须达到的一致性mandatory conformance
必要的质量requisite quality
[bi]
闭环操作closed loop operation
闭环控制closed loop control
闭环再现closed loop playback
闭路电视closed circuit television(CCTV)
闭锁lock
[bi]
壁厚wall thickness
壁厚变薄wall thinning
壁厚中部裂纹midthickness crack
壁孔opening in the wall
壁温变化changes in metal temperature
[bian]
边角料scrap
边界层boundary layer
边界条件boundary conditions
边线borderline
边排管bounding row of tubes
边缘穿透裂纹through edge crack
边缘反力boundary reaction
边缘滑移型edge sliding mode
边缘力矩edge moment
边缘区boundary region; boundary zone
边缘缺陷edge defects; edge imperfections
边缘效应edge effect
边缘应力boundary stress
边缘质量marginal quality
[bian]
编码标志coded marking
[bian]
扁材flat
扁坯slab
扁平钢带错绕式容器crossly wound vessel by flat ribbon
扁平区flatted spot
扁塌现象collapse phenomenon
[bian]
变动应力fluctuating stress
变动载荷variable loading
变坏degradation
变截面壳体non-uniform sectional
变径段reducer
变量variable
变色discoloration
变形distortion; deformation
变性材料modified material
变形测定器tensometer
变形层deformed layer
变性能理论distortion energy theory
变形速度velocity of deformation
[biao]
标定爆破压力stamped bursting pressure
标定过的流量计calibrated flow meter
标定压力stamped pressure
标记铅笔marking pencil
作者: jiang1019    时间: 2008-7-31 16:11     标题: 机械字典3
标准硬度块hardness standard block
标准正文body of specification
标准重力式压力表检验仪standard deadweight tester
标准编制组织standard preparing organization
标准草案draft standard
[biao]
表面标定缺口surface calibration notch
表面不平整surface irregularities
表面层surface coat
表面层下缺陷subsurface defects
表面铲伤chipping mark
表面粗糙surface asperity
表面粗糙度surface roughness
表面粗糙度检查仪surface roughness tester
表面镀层surface coating
表面堆焊层surface weld metal buildup
表面钝化surface passivation
表面多孔性surface porosity
表面发暗surface staining
表面分层surface lamellation
表面割炬gouging blowpipe
表面鼓包surface bulging
表面光洁度surface roughness; surface finish; surface smoothness
表面光洁度检查仪surface finish indicator
表面火焰清理surface scarfing
表面积surface area
表面检查surface examination
表面精整surface dressing; surface finish
表面孔隙度surface porosity
表面亮度surface brightness
表面裂纹surface crack
表面面积surface area
表面敏感性surface sensitivity
表面膜surface film
表面磨伤grinding mark
表面能surface energy
表面排污surface blow off
表面疲劳破坏surface fatigue failure
表面波surface wave
表面气孔surface pore; surface blowhole
表面气泡surface blowhole
表面清洁度surface cleanliness
表面氢化surface hydriding
表面清理surface dressing; surface cleaning
表面缺陷surface defects; surface imperfections;
表面热电偶surface thermocouple
表面伤痕surface flaws
表面烧剥surface scarfing
表面失去光泽surface staining
表面撕裂torn surface
表面损伤作用surface damage effect
表面缩孔surface pipe
作者: jincy    时间: 2008-7-31 16:42
我还以为什么大字典呢!
欢迎光临 三维网技术论坛 (http://www.3dportal.cn/discuz/) Powered by Discuz! 7.0.0
