发表于 2009-9-9 08:55:05
来自: 中国江苏苏州
原帖由 minwenqi 于 2009-9-9 00:27 发表 http://www.3dportal.cn/discuz/images/common/back.gif
. ?. N7 t7 K8 upen 1 color 0.0 0.0 0.0; thickness 0.025 cm& E J8 n; ^7 C J
pen 2 color 0.0 0.0 0.0; thickness 0.01 cm5 c% [8 r! W: [ D. z0 \
pen 3 color 0.0 0.0 0.0; thickness 0.01 cm2 y, U3 ]! F" M7 T1 Q' |, U
pen 4 color 0.0 0.0 0.0; thickness 0.01 cm
$ _# q Q1 o6 V( ]0 g0 _* Mpen 5 color 0.0 0.0 0.0 ... . A6 r0 k' o$ C0 g3 O8 m5 s
" W/ v. c1 m o!pen # pattern values; thickness value units; color valurs; <color_name> W, E* F# ~& s; I4 n1 L; P
pen 1 8 T9 X: G1 {% [" l
! white entities (GEOMETRY, CUVERS, VOLUME: object lines)
9 v7 F0 X0 }+ a3 z dpen 2
0 i) m, m% r* X% }! yellow entities (LETTER: text, dimensions, cross hatching)* T$ ]1 e* z8 g# K) T( ]
pen 3 % J" [% N! I# O! m" u
! grey entities (HIDDEN: hidden lines)2 |$ u/ H- f0 ?7 E# {: h s0 p
pen 4 2 X3 C: e- A8 ?- ?- \. H
! red entities (HIGHLIGHT: can use for drawing border if you change the entity color to red in the format file)
7 c0 M8 t0 |3 n7 fpen 5- K) Q% Q1 \, i6 Y" [6 F- p
! green entities (Sheetmetal)
/ U( f( ~; b- Z6 J; E+ ]* V2 w+ wpen 6
8 K; V- f, `) l8 m! cyan entities (SECTION: Sketcher)
/ G+ r' @# V2 V0 H9 U( Upen 7 ' P4 C* Y6 |. f+ Q; A/ l0 X
! gray entities (Dimmed Menu)
8 c% e& W8 N1 O6 _+ x3 wpen 8 ( h; n: p8 q5 c
! blue entities (Edge High) |
