发表于 2012-4-25 22:12:37
来自: 中国江苏苏州
9# laimeng5
3 H( g. {5 Q+ C 这是最详细的安装I-DEAS 6.2 m0 说明
* V: R2 v2 K$ X+ e/ A% V仅供参考1 a- ^) t, A7 G, l5 o. Z
NX I-DEAS V6.2 M0 INSTALLATION: q$ Y1 T' j" q1 {4 s# b
1, in control panel delete all of these selected items:
) m2 |( G+ d& H y6 ?. i6 |a, I-DEAS NX series- a' C& Y: W. v. }* `
b,I-DEAS Resource locking service! {3 u2 q( q3 }
c,I-DEAS SFAM component r4 }( ^! ~$ @! H
d,Java 2 SDK,SE V1.4.2_05
3 ?1 p% }8 Z* I0 u. M2 y7 b0 l( N Je,orbix
b; o$ P; k# q, f8 A0 `2,restart your computer
. R9 ?4 \2 b$ A, Y3 O1 t! _3,Nothing related I-DEAS and java left
+ C4 H: \5 q0 ?+ g- C9 T9 ^! J( D+ X4,delete I-DEAS related files in windows registry, use run “regedit”/ S4 }$ Z" F# B" K8 t
5,begin to install I-DEAS V6.2 M0; `; j( k# d+ b$ t, b
6,Do not install UGS license server
( S& I# T5 M6 i" d% P4 v7,install i-deas nx prerquisites
) b3 W, S! W1 j1 x, A% V' uNotice:1),change the path to what you want,remember ,Chinese path not permitted.(you”d better choose the default).' I# K" @+ C8 E2 B7 r
2),if you can not install this step, you maybe reset the windows system.if your OS is the Windows 7 (64bit&32bit),you must hold the right mouse, you required the administrator permissions before you run the programs.. ) ~+ u2 O2 e: F0 B& K, @. p
8,we continue to install environment after computer is restarted.& D4 } w5 @& i, f- \- L" U
9,install the i-deas nx serices setup., G0 K+ }, a Q$ y
9.1 install shield wizard’s dialog box comes out in design product group select this 4 items(A004 Assembly set,you can choose the all if you need)..% \- v6 [. j1 S( U( |
Select the language your OS used,if you are using an English OS,don”t need to seletct anything.(you can select the Chinese simplified and Chinese traditional.+ ?0 \8 `# J- h+ a. r8 \: M& v
9.2 in license server’s dialog you need change the local host to your computer name.
9 v7 R9 L2 {0 }" @4 S; C' Z10, accept all the default items and finish the installment.
8 f6 [& J6 H9 ]8 a11,install help if you need it
. I7 K; O$ T7 Z$ q" s12,exit setup
2 w0 o' h0 ?4 t7 i( C3 r# e13, replace orginal …\lic\nxlic.dll with cracked one. Copy “nxlic.dll” to folder I-DEAS 6.2 prog dir\lic (by default c:\siemens\nxi62\lic)and overwrite orginal one.
6 N1 \( n. e/ { R14,before running i-deas run”TDI Wizard” and install i-deas resource locking service.(continue to configure the team date.): C5 J" x- |. y% P1 D. m9 g" O9 f
Open TDI for mainmeau:
$ b* a( p0 q- u- e p$ s% R. eCreate and publish a teamdate installation' t M: R$ H6 ~/ q( P5 u
Set the team master ID:1/2/3/4 more than 1+ ~; M6 k3 P+ A3 R, Y
Next you can default set,finish all the default option,+ h& E: l8 a4 d6 q7 ~, G
15,enjoy.
1 I% ~. W$ w& Q) }Notice:that’all. No flexlm server or license are need.
7 H( v$ y9 \! z8 U9 I2 F8 P$ i安装中最容易出现问题,建议重装系统后再安装。0 b8 \2 y6 Q) {' s% L# l2 x
无法开启界面,最主要的是NX I-DEAS resource locking service 没有开启,可以在控制面板 管理工具 服务中查看,可以手动开启3 E! A# P, m _$ ^& l
安装前确保磁盘文件中不包含中文。, k0 ?7 O2 o7 t# q, v7 N8 D: B
启动时可以右键通过管理员权限设置i-deas在起始位置中指定默认存放文件夹,默认为空白。+ M, e, H2 G5 T3 h$ f/ W
新建文件名不能包括中文及数字。 |
