发表于 2012-3-28 09:21:42
来自: 中国台湾
1# lx558 4 d2 T8 j6 W8 I: L9 N; J' F
先打開X版,做以下設定。
4 l; Q x. n" }
! N2 J( o6 I4 J! g1.
9 z+ _* u# c5 s y8 h
$ v; m. F) I! s* c
8 n( Y1 U9 B4 b& l' S% W
, r- {6 y& U" c' k$ h7 v" y+ f$ P2 p1 ^- E6 b' S$ a$ i+ X
2 [( x! J+ H" ]6 r- i
再打開後處理,改以下紅色部份。& e" E# D8 c- z& i2 O4 x4 Y
5 i3 o& ~ ^5 v. B1 x
* @, a8 y2 X5 V* K# ^# Coolant output code selection for X style coolant* h1 D; z$ q' [* R" a& W
# Note: To enable X style coolant, click on the General Machine Parameters icon" A' f0 o1 c& H. a
# in the Machine Definition Manager, Coolant tab, disable first check box9 e5 I% q& |1 t B
# Output of X style coolant commands in this post is controlled by pcan, pcan1, & pcan21 _; i+ y, O2 U) U# D5 b- l
scool50 : "M8" #Coolant 1 on value
0 ]3 [& t. q6 d9 Hscool51 : "M9" #Coolant 1 off value
4 d6 R& X4 _8 W$ G9 J( }scool52 : "M14" #Coolant 2 on value
: b( s- Z: r$ f9 s5 Q* b* J' nscool53 : "M15" #Coolant 2 off value5 _9 D# l! l' s- u3 E
scool54 : "M14" #Coolant 3 on value
, ~4 S0 x) n: ^ gscool55 : "M15" #Coolant 3 off value4 e; }. F$ G5 z: j+ v
scool56 : "M8(Coolant4=ON)" #Coolant 4 on value
c1 n4 c( ^" e8 \6 _7 S9 a# K- Iscool57 : "M9(Coolant4=OFF)" #Coolant 4 off value
3 j* L( f# ~9 t, ?1 b& N; vscool58 : "M8(Coolant5=ON)" #Coolant 5 on value
: u& U& g9 l" _ Q! A0 nscool59 : "M9(Coolant5=OFF)" #Coolant 5 off value9 p: H2 v3 o0 r+ g: d3 Y
scool60 : "M8(Coolant6=ON)" #Coolant 6 on value
/ ^( m4 ?( T5 j$ H: ?scool61 : "M9(Coolant6=OFF)" #Coolant 6 off value3 B2 B, p2 b5 S" n
scool62 : "M8(Coolant7=ON)" #Coolant 7 on value3 ~+ n, r8 C# O1 S
scool63 : "M9(Coolant7=OFF)" #Coolant 7 off value
5 w. [6 h$ \! F Q) o/ M: P! wscool64 : "M8(Coolant8=ON)" #Coolant 8 on value
. v! n! _8 g" P' P |scool65 : "M9(Coolant8=OFF)" #Coolant 8 off value7 J2 o7 w: ]/ W
scool66 : "M8(Coolant9=ON)" #Coolant 9 on value
! G! R$ a4 x6 v8 |. e c: T- D# Iscool67 : "M9(Coolant9=OFF)" #Coolant 9 off value. T7 e% P* K& X, \1 M
scool68 : "M8(Coolant10=ON)" #Coolant 10 on value, I3 y2 L* C8 G! [: O. B
scool69 : "M9(Coolant10=OFF)" #Coolant 10 off value' O( H" n& ?& z4 Y5 A5 J& U
scoolantx : "" #Target string2 Q! X: B. e5 h0 U
% E# n4 k Y" e) c! D
fstrsel scool50 coolantx scoolantx 20 -1+ L3 `# L7 v4 z( s/ {* \3 e& A, A$ G
