查看: 7157|回复: 6
[已解决] win7 64安裝master camx6 安裝不了啊?
发表于 2012-1-27 11:13:55 | 显示全部楼层 |阅读模式 来自: 中国台湾
win7 32位元的可以.為何64位元的就不行: D4 G: |7 i3 n# m& `3 B
也有試試案F8安裝也是開不了ㄚ~* J7 E% z5 x- d/ l1 H. U/ b
有哪位大大可以只點一下.拜託^^
发表于 2012-1-30 21:22:41 | 显示全部楼层 来自: 中国广东珠海
本帖最后由 lixinqiou 于 2012-1-30 22:31 编辑   D1 j2 G9 o) e% e( e1 y
- |8 m' _) x1 ]: y3 B9 _1# mi15988 同解!E文不好,麻烦哪位楼主翻译下:/ \8 U  n3 O: Y! N  ~% p
4) Install a USB-Win64 Emulator. A! B9 B9 H7 \  m* s; Y1 l
You need a local Administrator rights to install this emulator for Win64!
8 L! o0 b) p7 v: {  EOn Windows Vista64 and Windows7 64-bit you need to boot Windows in mode F8 > Desable Unsigned Drivers Enforcment !!!
5 n6 w4 l( P' D  g  {* D" m0 s4.1. Reboot computer (for Windows Vista64 and Windows7 64-bit you need to boot Windows in mode F8 > Desable Unsigned Drivers Enforcment !!!)
1 [( r. Y$ c) Y4 X3 l& j. y4.2.   Install usb-emulator drivers. j; w) E5 b$ @8 e+ X9 a5 g
  Start ->  Control Panel -> Add Hardware (Yes, I have already connected the hardware) -> Add a new hardware device -> Install the hardware that I manually select from a list -> Show all Devices -> Have disk -> Browse -> (browse to folder "USB-Emul_Win64") -> OK -> Confirm to install not certificated drivers if Windows ask for../ f; j, t8 ?) q+ X$ k: L
If setup is succesfull you have to see new system device:) A1 }$ ^' j/ U: ?
Device Manager -> System devices -> Virtual Usb Bus Enumerator3 W3 j. E; w# }. e5 s' \
/ ~) y0 ^' R" \5)  Install MC X6 v15.0.4.3 64bit  as HASP or NetHASP SIM type. 1 e$ q0 {. E+ b( m6 e
6) Copy Mastercam.exe from crack to <Mastercam X6 progdir> and replace original one
! ~8 f0 @2 n" |0 B1 V; v7) Enjoy
8 U) k7 N% u2 c4 j' O多谢!现在知道了,不好意思!
发表于 2012-2-2 21:39:31 | 显示全部楼层 来自: 中国江西南昌
本帖最后由 wgchen0113 于 2012-2-2 21:40 编辑 2 ^; L# o( p# j
' [: O; ~( Y  M0 k 2# lixinqiou " Y( n9 ~) y% o6 P
4)安装64位的USB虚拟狗
0 @/ G3 D/ m# ]$ X( f8 g5 X在64位系统下安装时要以管理员权限安装虚拟狗!
+ \# e0 W: C4 i0 q% u64位的vista和win7系统需要在启动windows时进入F8模式中的<禁用驱动签名>状态下安装虚拟狗!!!
. X7 J8 Z/ j4 G* A4.1 重启电脑(对于64位的vista和win7 进入F8模式->禁用驱动签名!!!)
! ]# \3 F* y/ j2 H, n/ |$ f4.2 安装USB虚拟狗驱动: ?, N+ j) |9 U- e
5)安装64位MCX6 V15.0.4.3,使用HASP或是NetHASP SIM类型。+ [; N. P7 C. u9 c
6)将Mastercam.exe<Mastercam X6 安装目录>替换相应文件。, ^3 C+ H  V$ i# T' J+ j8 A
以下只是说明,非翻译' K2 A8 N" x+ C: a0 D) a
4.2步骤下的安装虚拟狗驱动的过程有很多种路径,我就直接说明关键的,不翻译了,在win7 x64下一定要在启动时按F8(就是进入安全模式那种),选择<禁用驱动签名>的那种模式启动windows。当进入桌面是点击<我的电脑>,右键选择<属性>,在窗口画面左上方处选择<设备管理器>,任意选中对话框中的硬件,点击菜单栏中的<操作>,选择<添加过时硬件>,点击<下一步>,选择<安装我手动从列表选择的硬件>点击下一步,点击<磁盘安装>,选择驱动目录安装驱动就可以了。如果安装成功在<设备管理器>中的<系统设备>中出现Virtual Usb Bus Enumerator。
" K: v, j" L' F5 a要在x64的vista&win7正常使用MCX6,只能在<禁用驱动签名>模式下使用。
+ T% \: t. d' d我现在用的是2008R2,也可以安装并使用MCX6。
路过不买 + 2 应助
发表于 2012-2-2 22:19:00 | 显示全部楼层 来自: 中国广东珠海
3# wgchen0113
 楼主| 发表于 2012-2-3 22:39:54 | 显示全部楼层 来自: 中国台湾
感謝這位大大的指點^^% j: P5 `% S8 d4 i5 `
學習了~
发表于 2012-2-10 09:25:18 | 显示全部楼层 来自: 中国浙江宁波
本人安装已成功!!
发表于 2012-2-20 19:25:52 | 显示全部楼层 来自: 中国台湾
thank you...
