楼主 |
发表于 2011-10-18 16:55:05
来自: 中国江苏苏州
* The Cutter E10_T01, loaded from a template, uses magazine number 32 that is already in use.
% u2 u+ y; n% O m4 V* Y( @* The magazine number was replaced to 40.# ~! Z1 P: a0 r2 A+ j C2 G5 Y
* The Cutter E4_T01, loaded from a template, uses magazine number 33 that is already in use.0 [7 I" ]8 R" k& z* I
* The magazine number was replaced to 41.
8 }0 n) ` j* N: i4 X. Q* A! Z* The Cutter E8_T01, loaded from a template, uses magazine number 34 that is already in use.( G0 k: Y' f4 i7 ?# K4 j
* The magazine number was replaced to 42.
# E: d* |! `* V- _- {5 p* The Cutter E4R0.3_T01, loaded from a template, uses magazine number 35 that is already in use.
3 C% m3 S! @; X+ X V- Y3 Y* The magazine number was replaced to 43.5 B# c4 ~4 s6 f
* Template loaded from C:\Cimatron\模版\兜下去的.mtt: Q0 J' u/ T* Q6 ~
* Missing Start Point parameter was attached to contour' L. @/ `2 r# d: a) e# @
* Missing Cutting Mode parameter was attached to contour
$ ]' c) v$ O( i* _, S# c b x% c1 c* WARNING! INTERNAL INCREMENTAL CLEAR MAY GOUGE PROTRUSIONS!
1 f* N" J l4 d: T' z RECOMMENDED TO APPLY THE OPTIMIZER/RAPID MOVE GOUGE CHECK OPTION6 I1 G' ^( G0 {) A, O
* Note: When using Internal Incremental Clear, it is recommended to define the stock
3 Y- T- U7 h+ V6 E( c. @+ t6 n; band to use the Optimizer option Rapid Motion Gouge Check.- d0 b0 T" b0 ]( ]9 V4 D5 ]
" c: t8 P" |9 N& j5 U+ B/ T* Target Part_2; 18/10/11; 11:27:15; End Execution; Total 00:00:00; Succeeded
8 M* N0 `) M' v4 z# ~* Stock By Contours_3; 18/10/11; 11:27:15; Start Calculation at PC-002;
, h" ]. H e+ x4 }: ~3 ^* Stock By Contours_3; 18/10/11; 11:27:15; End Calculation; Total 00:00:00; Succeeded) O3 C' t# u+ t" o1 a& g) l5 c1 H
* Stock By Contours_3; 18/10/11; 11:27:15; End Execution; Total 00:00:00; Succeeded/ f8 K4 r2 X) i9 _
* 2.5 Axes-Profile Closed Contour_4; 18/10/11; 11:27:20; Start Calculation at PC-002;
0 ]0 Q/ X2 n% r9 I; h* 2.5 Axes-Profile Closed Contour_4; 18/10/11; 11:27:20; WARNING! INTERNAL INCREMENTAL CLEAR MAY GOUGE PROTRUSIONS!
8 P: g H* N5 H" ~, l2 _ RECOMMENDED TO APPLY THE OPTIMIZER/RAPID MOVE GOUGE CHECK OPTION
* R! z$ l' Q2 q7 G6 c; y3 |! F/ v* 2.5 Axes-Profile Closed Contour_4; 18/10/11; 11:27:20; End Calculation; Total 00:00:00; Succeeded
( w: r* d4 n# H0 d' V2 g* 2.5 Axes-Profile Closed Contour_4; 18/10/11; 11:27:20; End Execution; Total 00:00:00; Succeeded$ q+ B( [8 G) u8 [
* Volume Milling-Rough Spiral_5; 18/10/11; 11:27:27; Start Calculation at PC-002;
: p0 C$ P, m/ l* Volume Milling-Rough Spiral_5; 18/10/11; 11:27:27; End Calculation; Total 00:00:03; Succeeded5 w& x% x+ Q) `( B2 z( E5 S
* Volume Milling-Rough Spiral_5; 18/10/11; 11:27:27; End Execution; Total 00:00:03; Succeeded
/ ?3 |$ C; ]% A* Volume Milling-Rough Spiral_7; 18/10/11; 11:27:34; Start Calculation at PC-002; % U: l6 K4 j8 g' ~2 J7 J$ u
* Volume Milling-Rough Spiral_7; 18/10/11; 11:27:37; End Calculation; Total 00:00:06; Succeeded
! O. r4 g; u: y% I* Volume Milling-Rough Spiral_7; 18/10/11; 11:27:37; End Execution; Total 00:00:07; Succeeded' p8 J& g9 G9 [/ U- i" j+ S
* Surface Milling-By Layers_8; 18/10/11; 11:27:42; Start Calculation at PC-002; + |7 B/ l) `, |. O; x
* Surface Milling-By Layers_8; 18/10/11; 11:27:42; OVERLAP OFFSET OF REGION 0 FAILED AND SET TO 0.0) I+ I7 _$ w! m2 ? v
* Surface Milling-By Layers_8; 18/10/11; 11:27:42; ENTRY POINT: X = -15.27 Y = -5.28 Z = -12.03$ ` U% c* R& Y" H
* Surface Milling-By Layers_8; 18/10/11; 11:27:42; ENTRY POINT: X = -15.27 Y = -5.28 Z = -12.05
3 U7 E, Q! o5 s" U" q" H* Surface Milling-By Layers_8; 18/10/11; 11:27:42; End Calculation; Total 00:00:02; Succeeded
. J \: D2 f" s- |$ F/ R* Surface Milling-By Layers_8; 18/10/11; 11:27:42; End Execution; Total 00:00:02; Succeeded2 m9 C8 g) t2 B# W/ ^2 e* A" m
* Surface Milling-Finish Mill All_10; 18/10/11; 11:27:46; Start Calculation at PC-002;
( s, P/ o- g0 q; P& R* Surface Milling-Finish Mill All_10; 18/10/11; 11:27:46; End Calculation; Total 00:00:00; Succeeded
) k: a1 q) Q9 B# \* Surface Milling-Finish Mill All_10; 18/10/11; 11:27:46; End Execution; Total 00:00:00; Succeeded5 K; L: C& @3 _$ b) ]! y) q
* Surface Milling-Finish Mill All_11; 18/10/11; 11:27:50; Start Calculation at PC-002;
. ]" s$ J2 M* H( M; M* Surface Milling-Finish Mill All_11; 18/10/11; 11:27:50; End Calculation; Total 00:00:00; Succeeded
+ ~; e$ x3 z1 u2 q7 R8 n( z* Surface Milling-Finish Mill All_11; 18/10/11; 11:27:50; End Execution; Total 00:00:00; Succeeded8 `+ Z ]8 ?: }8 m
* Surface Milling-Finish Mill All_13; 18/10/11; 11:27:57; Start Calculation at PC-002;
3 B! q/ G6 N4 m* Surface Milling-Finish Mill All_13; 18/10/11; 11:27:57; End Calculation; Total 00:00:03; Succeeded( S& G% x: I) F" O, q! h
* Surface Milling-Finish Mill All_13; 18/10/11; 11:27:57; End Execution; Total 00:00:03; Succeeded
t/ k& r* S: H2 V* 18/10/11; 11:27:57; All procedures have been executed; no additional procedures are submitted for execution.
4 w; y6 d* O3 Z$ S7 d5 N, K: n: T这个是后台的数据。。 |
