% m7 M+ ^; Z2 h2 `! S/ k0 n5 ~% S% i6 `
代码写的比较粗糙,不支持深孔往复钻,只贴出钻孔部分代码,其他运动代码无须更改,如果无法正常编译请检查后处理头是否声明了代码中的变量。
+ S/ E5 h, k3 y8 R/ R! f/ x
: { g% M8 k0 EGPP2代码在7楼4 G4 ^8 J5 H! C# C3 o
********************************************************& w/ V6 t5 W6 n5 r V' Y
CYCLE: ON:
# C6 @5 K% e& }*{{ GPP range check2 z7 v/ t0 q2 m' \5 }4 p$ d
*}} GPP range check
" e) E% N# O) ~) e FlagSpin = NO ;& t* [" I0 f; x1 z- l$ f& V6 n7 k+ t
IF_SET (SPIN_SPEED) FlagSpin = YES ; END_IF ;7 q& F1 v9 y0 G2 A3 q* M/ ]1 B/ @
IF_SET (SPIN_DIR) FlagSpin = YES ; END_IF ;
( }1 E( H e4 C% F& J IF_SET (FlagSpin _EQ_ YES)( V; @" Z) C* d: @ z8 C6 a0 |
1 X( [/ X; [) ? SET_ON SPIN_SPEED SPIN_DIR ;7 d* G. l3 _. d9 e9 V
END_IF ;1 E; X: d: y, r
9 i, c% m# p$ v SET_ON X_CURPOS Y_CURPOS Z_CURPOS ;
; d( e- K9 c5 v6 u6 \( O# C' D SET_ON CYC_DEPTH CYC_RETR CYC_CLEAR MCH_FEED ;+ G+ W% D- w8 [3 Y8 X$ T4 D5 \
SET_ON Zinit Depth Clear ;% _7 e5 c, J" a
Zinit = Z_CURPOS + CYC_DZINIT ;
9 M/ K; Y0 d" n9 ?% f Q& { Depth = Z_CURPOS - CYC_DEPTH ;
% H. h. L* z9 [3 f G4 h Clear = Z_CURPOS + CYC_CLEAR ;
* ~ |+ z, y$ I7 @. O/ O/ \( R IF_SET (Zold _LT_ Zinit) OUTPUT $ "G00Z" Zinit ; END_IF ;" l0 p0 C' A" m) {2 R/ C5 B
" \! ~, {" I- T5 ?. M- ~ OUTPUT $ ;
4 V! O, l9 F) ], h! Z5 d9 s/ O6 X7 y6 R- W8 X
OUTPUT "G00";( X; N& U. R& K
: W& v* }% I! N; ? OUTPUT "X" X_CURPOS ;
! M- @) n/ D& A
+ s6 L% A- F: A- Y& O+ g/ B! i OUTPUT "Y" Y_CURPOS ;
* p: |( S5 c: t, a, q1 W OUTPUT "Z" Zhome ;0 l/ Z5 z8 T5 |$ [3 Q6 c$ i
OUTPUT $ ;
" N5 |0 g# v F! {8 _5 [8 T; Q9 l& }# v# I, o
) t) l2 I# K- o8 _
0 V) X" F1 o5 q# ]" A2 k) M3 H* U OUTPUT "Z" Clear ;
( k& A( j u4 I! t$ p OUTPUT $ ;) }. V' e! \$ D, j A+ F
5 \1 u* b1 V3 u { U! |& T
IF_SET (LIN_MOV) OUTPUT LIN_MOV ; END_IF ;
/ h' H' r# Q- Y: S
, L; \' [) |2 O+ n OUTPUT "X" X_CURPOS ;7 `% ^1 [% C3 |- A, q
5 a6 y! p: s' I* d
: @$ k4 F; F% ^
5 B5 o' S9 t1 K) Y OUTPUT "Z" Depth ;0 x0 J# S; b o! ~% Z9 f* u
5 V/ l6 b" z+ E3 w4 P) J+ ]6 s2 S OUTPUT "F" MCH_FEED ;
! {2 D4 v& N: c
; S7 p( x v7 w" p* I SET_ON LIN_MOV CIRC_MOV ;
; g! ]9 E4 B9 v/ N/ n7 i9 e. R2 ? SET_OFF CYC_DEPTH CYC_CLEAR;
$ l# t1 Z/ Y- E Xold = X_CURPOS ;
* I, j% D4 |% I) H% ]0 R Yold = Y_CURPOS ;
5 Q+ Z$ g$ @ l* d Zold = Z_CURPOS ;
' ?& x& w2 G+ } u( q& r* o( c2 o, W- ?- S" W! o* M
CYCLE:$ p3 E# t8 [1 F2 A: R0 w; B/ J( D3 y
*{{ GPP range check( M! Z7 Z) c9 b' S- O4 V$ K$ G, D' \4 g. E
*}} GPP range check
' S. L8 P/ K& ^. K1 v: W1 r SET_ON X_CURPOS Y_CURPOS Z_CURPOS ;2 k, s# }) K1 p( q C
SET_ON CYC_DEPTH CYC_RETR CYC_CLEAR MCH_FEED ;* C9 o- {1 s4 Q% b, i) o: a
/ I3 c+ _! ~% d0 C @ Zinit = Z_CURPOS + CYC_DZINIT ;
* f, Y- O* K1 ^, U0 K! G9 Q Depth = Z_CURPOS - CYC_DEPTH ;4 S, U- j* {% z4 t/ A4 B) V
Clear = Z_CURPOS + CYC_CLEAR ;: B6 P7 o2 L f0 F; L( Q; E
IF_SET (Zold _LT_ Zinit) OUTPUT $ "G00Z" Zinit ; END_IF ;% a7 P+ i+ E6 U! p- W" Y" ~2 [
OUTPUT $ ;4 k: Y0 C, ^$ F8 q' Y$ s. P
" {% u# A+ _! P7 C$ x0 ]1 ^; A
0 U( g0 m% H/ H0 {; A
$ T2 n+ H0 A2 i# y0 k! l$ _ OUTPUT "X" X_CURPOS ;8 k6 ~8 u2 {% n3 Q8 ~' f/ b/ t+ g
4 [$ @8 f/ n. G) Q P! `1 A
OUTPUT "Y" Y_CURPOS ;1 [ ^% r4 Q/ T# ~1 L, w/ M; z
OUTPUT $ ;8 |' r B+ Z) S& b
7 X0 e) j. @: [& x( I/ C; F( I4 J' u: j" r. p, y
) Y$ ?$ ^( c; S' ]3 Z OUTPUT "Z" Clear ;% n8 _8 b" s: T; J) y' q
OUTPUT $ ;5 a1 [6 s. e; W
2 z* N9 R( h# Q5 y' ]: U1 q/ R IF_SET (LIN_MOV) OUTPUT LIN_MOV ; END_IF ;# C' L1 d' d, |8 Y- N
) y& s) {6 H" I( x0 }6 A
* I2 Q( f' X! g" ?1 _$ k, L3 m# }7 q! _4 @
OUTPUT "Y" Y_CURPOS ;2 a# W+ [, e& m
* S2 I. o/ m; l' M D: y
OUTPUT "Z" Depth ;
) u* c1 A( X# l$ b IF_SET (MCH_FEED) OUTPUT "F" MCH_FEED ; END_IF ;
, p" u9 T. A- @0 ?% Y9 }4 }7 f
4 F1 e" U: n1 m+ X* Q SET_ON LIN_MOV CIRC_MOV ;! s; H3 Q2 L L: t; A' ?0 H2 x
3 T5 B6 |: U; N* x Xold = X_CURPOS ;* X) o* S6 T! j' d7 ]# k% k
Yold = Y_CURPOS ;) \+ `- G2 T1 C+ A( T1 d% E) b
Zold = Z_CURPOS ;
" [/ f6 b# f& F% V, U0 s: Z3 _1 t
CYCLE: OFF:
- H0 n9 J; }/ B: ~$ U*{{ GPP range check0 @1 g" ], W+ B7 |- s2 P
*}} GPP range check. j3 Y8 D1 y) Z3 U3 O
OUTPUT $ ;
5 n: B3 m8 n4 P8 M+ J L, c/ r OUTPUT "G00Z" Zhome ;
: c x6 T, D8 @; B, R J! ^& t5 D; t SET_ON CIRC_MOV ;
: B' |8 S1 O( u$ k8 K" ` Zold = Zinit ;2 U: B1 }" J# g8 Q- m
5 `/ E* s! G5 P
