, {! o5 j1 ~4 a' L: ], \5 O& T+ H! Z4 b3 b8 N# ?( }' Y
ATTENTION!
2 z4 F" `4 M0 zIt's Update only! To install it you need Solid Edge ST3 to be preinstalled!1 ?% r. t9 P- V# b! r9 A. P/ Q
+ d: K/ Z/ j$ y, ]1 [+ eu.115.com
9 F9 g# t# [1 N! G- _* R( Y. ^32bit8 `& g/ o: W! X3 b9 D
http://115.com/file/bhf2sp88#
# H: g1 R' X6 f# r, N/ t64bit
% s8 E8 c1 P) `' y) ihttp://115.com/file/aqymfzrz#6 n9 i+ Q. l \' k' R; t- N o
, t0 h; Y3 T' Q) S
FileServe
; J; e- c7 a+ n) Q2 ^32bit% ~; A- z5 @5 i. B
h-ttp://www.fileserve.com/file/yT9wu7V/SE_ST3_MP8_32bit_Update_SSQ.rar
& L9 I7 @ [; J0 [5 z64bit4 \9 k q. J8 ^
h-ttp://www.fileserve.com/file/BU4AeJr/SE_ST3_MP8_64bit_Update_SSQ.rar
/ N7 g: r e6 j8 F3 N1 F! ^! x) E( z( }9 {5 ]* _- W/ C
RapidShare
4 c: _7 N) ^$ f+ D$ v. ?! n! L* q- Q32bit
$ T% K9 A: P+ ]( F) F4 h# |& K- @h-ttps://www.rapidshare.com/files/278268356/SE_ST3_MP8_32bit_Update_SSQ.rar
& O$ F8 w; ~9 H: ^64bit6 ^" U; S8 k% B4 t( A
h-ttps://www.rapidshare.com/files/2280004065/SE_ST3_MP8_64bit_Update_SSQ.rar
& ^1 Y* x3 N! r' g/ [4 K5 v
4 Z" H4 ^( m: IHere is list of fixed bugs8 p. C; e5 I, j2 V: a& d
* G _1 v z7 b0 B" ^( A& {This Maintenance Pack addresses the following PRs:4 F$ O' ~/ r) A* O. w6 F
8 z M8 [" q% l===API=== Q: h, b j& i0 a+ `
PR 1844579: Need Automation support for creating PMI dimensions
; N3 R. p$ o4 d3 t T9 UPR 6585353: BalloonDisplayedText API does not return the correct info
n; O4 t. N* R) o0 l) ^2 k===Assembly=== , x! T5 j3 i: R+ z- o
PR 6560593: A large number of embedded weldment bodies causes performance issues for view rotation5 e; R5 s: A( v* ~4 y, A: @
PR 1848704: Getting an error when adding a new standard part (from existing part file)
. L0 ^4 t' o+ z; U: EPR 1854670: Assembly aborts when using Interpart Manager4 b- h" I3 L, Y* ~9 o; t. \
PR 1855154: Unable to import a Solid Works-asm (SW2010)) J3 C% I( O2 H, _0 ~( n3 D9 A) \
PR 1859600: Assembly contains parts that no longer display after adding Assembly Features& J6 _* {/ j6 P
PR 2174262: Unable to place a 15 degree fitting, while all other angles can be placed
- R ?$ f% a2 _" t. q( Q( APR 6576033: pathfinder reports erroneous driven parts for top level sketches. v& x, J8 j, p# m
PR 1855845: Text font size doesn't change on sketch dimensions
4 F2 I9 g n, X; EPR 6571258: significant performance hit when profile has extra points
$ d& K- [; |6 x4 TPR 6487257: STEP file import performance is very slow using this file/ f4 e2 q5 [2 V0 I+ u% `
PR 1857542: Piping Performance is bad on ST3MP6 XP32BIt compared to V20 XP32Bit " |+ l! `2 l! n. a) B
PR 2175526: Problems with fitting positioning on piping: m% J+ k/ H# r1 ]) Y$ O) c5 Y
===Draft===
# \& Q4 h& p1 `" Y4 @4 FPR 1846417: Ordinate dimensions changed after opening in ST3* O: u# r5 ]7 X! r, ]- |
PR 6578739: Solid Edge aborted on close
+ \. Q! N5 D0 m6 _4 P" R7 ZPR 2174989: drawing view caption is moving on file open
+ D5 p8 }* J$ ]$ c# ]( O+ d' k3 HPR 2175139: specific edges are not displayed when the draft file is opened
2 R; X1 E6 Z2 ]( u' g: b. pPR 1794331: a trim operation has a delay of 1 min+ in this file5 A, M& J/ v* i- Z) D+ R. r, ~
PR 2175819: Parts List marks ambiguous parts even though the option is disabled8 v! i3 o: Z/ w# R# h# Y9 J
PR 6557936: PDF sheet sizes are swapped
7 U+ [4 F' a2 o& I* \6 a6 L4 ^4 jPR 1861764: Performance problem updating a view after many additions/deletions in the model0 Y, A _: k( ?2 q2 `
PR 6572180: Spell Checker changes justification and removes text7 h9 ^# Q. r2 Z
Note: the updated spell checker can be downloaded from: http://ftp.ugs.com/solid_edge/SupportTools/SpellChecker/
. Q3 a9 T& c0 `5 r===Insight/View & Markup===
3 G4 I: m: w& H: _! o$ Z' SPR 1844744: No error displayed when search query ends 10x with timeout ; N" k% M1 a7 [2 o5 j* C F7 q
PR 6557429: Crash editing sync file in asm after synchronizing through Cache Assistant+ q# R& \2 G- i1 m
PR 1856783: any user can release assemblies that contain parts with a Prerelease or Obsolete status; \2 y x3 F# ]& }% k
PR 6569695: Revise and set path operation creates duplicate files
2 N# w: l [: y, B: y2 gPR 6571007: Full Text search hangs on WSS3 server
$ N6 I: q2 @! b1 O iPR 6424248: User cannot create a revision as a member of a domain group
4 N9 f1 K+ V0 n5 Y3 r) r- IPR 2165916: Traditional Chinese View & Markup aborts closing files
$ ~: S1 A! l& ^, ~ Note: A workaround / partial fix for PR#2165916 has been verified for MP8 that requires you to manually delete
5 a0 Z4 `- y6 N8 Y+ u FrameBrokerWeb_res.dll & WorkspaceManager_res.dll files. The complete fix is scheduled for ST5.
3 J8 @1 R; P% A7 u% t( W===Part/Profile/Sheet Metal=== 4 X- k5 V% v$ W: L
PR 1857983: Synchronous hole thread disappearing when an ordered cutout is placed on the sheet metal part
. H) H2 j6 ~& u1 d) ^) l# B/ \+ uPR 6566839: Doing a recompute on first feature and Solid Edge hangs; L. R$ L* [6 ^& U1 k
PR 1856721: Select from sketch features indicate under-constrained profiles% e1 y g: r O
PR 1860323: DIN.PZL and neutral factor has no impact on converted sheetmetal parts) d; C2 [7 p' z
PR 6576500: Fewer Undo steps after each sketch, ending with a system error5 {1 {3 L0 r k7 v( b& M3 B
PR 1861355: Product Aborts when saving or loading a customization file with "deny" security5 |6 ~5 R8 H1 l6 \
PR 1860681: Unable to edit dimensions in a sketch3 ~9 [1 f5 P3 x$ @( A1 }. I% x
PR 6580444: Bends w/default bend radius are not driven by the global setting after transform) N4 m0 i; G5 [( y" S. @* M6 y
PR 6582077: Adding a cutout makes part disappear
9 E( b3 g- D, l; s8 Y+ R# Q) [PR 1856611: Part disappears after move/zoom/rotate
1 o+ S1 ~4 S4 F { C7 I===Solid Edge Embedded Client===! P O8 ?2 D) t$ Z5 N+ l
PR 6569840: cannot save searches based on newly created searches
9 n5 Y/ M7 m& l z- `% bPR 1843322: NX part files are not updated / removed from SEEC cache
8 Y: @ L5 I4 q/ ^$ L" MPR 1851218: Very low performance for AddToTeamcenter " H8 {- E2 _. A2 W) C' y
PR 1851237: Solid Edge Item Number Sync works not from TC to SE
; _8 m- d$ F V6 d8 SPR 6515479: Find Number for TcVC tries to reset and can lead to a collision4 S$ B8 @% V; V$ L/ h- f- d
PR 6546565: Sets Priority ID for a new revision of a part in the CPD and it changes Priority id |
