# j8 X+ F9 \; q6 q8 w% Q6 b& Y
+ V3 f- o @+ q/ V2 _. W9 ~: N/ p, G/ U, q5 U$ l7 |
What's New In Mastercam X6 4 ?- {) z) j8 x$ m$ t# ?
| Mastercam X6 is scheduled for release in the last quarter of 2011. We have been getting many questions from Resellers about what features are in X6.
2 y; }- F- o( `- x' o6 |
, D6 X" r# V! q' ~3 jThe following are the currently planned features are that will be in X6.! j" a2 q: s" [! O2 U
Gerneral and Design Enhancement :
3 s, @4 X& E4 ^- Stock Model
5 z5 P! G7 S2 ]8 f& p- 64-bit Support
* j! @7 K! J5 x4 f5 n9 c; _- New tool database/manager- r' M& x1 t5 w! f
- Solid trim to surface
; E2 e2 Z+ I, v3 T- Solid edges intersection and trimming
X4 ] y5 c! a9 j& N# H- Trim/Divide support for splines
" k; {) X$ G, n* q; H `/ L- All and Only Mask arc sweep
# C3 E H/ }* f0 M/ Y- Quick Mask group option# O# o# Q. I5 V P3 `0 u
- xform rotate min angle1 A. q' ~* W2 b. @. I4 ?/ r
- Active report updates * n/ L. i5 }& s8 T4 p6 G$ n8 b% x
Lathe :
$ `( Q+ f0 b+ ]6 n8 ]" k7 _- Face optional finish feed/speed
+ f* ]1 j: q( ~: w- Face corner break
8 p) ~6 {( L- H! C: b+ f! P: c' q5 s- Canned groove optional Finish feed/speed
; ` D* q; I! Z! t9 K5 N- Variable depth roughing
; j* r. r" A/ q6 A- Finish down-cutting strategy
) `3 z# m' \5 l- {7 H- Groove rough optional retract feed on first plunge6 V8 w9 l. t. }
- Groove finish option to remove undercuts
5 t, w* ?, u& G% m7 W7 K- Finish tool inspection) C/ F, H& I, x
- Rough remaining stock, including pinch turn
0 }5 X4 ?! |) H& o+ [2 h! n. O- MT Misc Ops" O3 ~, b' b) @, @# X* ?& ]; A I
4 @/ \! U9 k4 t4 s/ S, j9 tWire :, z7 w f5 B! ~( u
- Power Library Manager for Tech Libraries
7 u3 v. R4 M4 @- _; g- New autosync
3 i' w, S1 s* i6 F* a$ | x* n$ c' Q! \- g) q4 s! ?; K
Mill 2D :
4 \5 \; B5 P1 j) B9 Q6 z
* M& N9 v4 d! m* h8 q& I- Stock Model/ C8 y6 x9 C+ q# z3 k. n
- 2D HST by Depth and Pocket
! K$ }/ L7 L& z- Bull nose support
" F' ~6 Q" n1 _% x. O1 C/ M- New chaining
; Y# r; j0 H6 W8 i- 2D HST Blend Mill compensation
4 v S- H k0 D3 p- Zigzag for Dynamic milling toolpaths
. {, S2 p5 _& O- C- 2D Contour Smoothing
& Q$ A& @1 z/ o+ ?: K- [- 2D HST Peel Mill adjust start/end
# n% i |) l0 v- 2D HST Dynamic milling variable radius
: V# P: Z b6 y& q- 2D HST Dynamic milling approach from outside control (lead in/out control)
# q7 @5 d" X5 a3 Q# `* l6 `6 f- 2D HST Dynamic milling open toolpath
6 D1 `0 V5 i% ^4 L0 \0 }2 E) }
& r9 F6 n2 s8 u7 \& q( m: o5 UMill 3D :; f7 H' ~" b' P3 x, U l# d
- Stock Model8 ?6 u0 }# F0 y5 w, Y, o
- OptiRest toolpaths
- h! B" s) d. Y( x" @6 c1 q- Hybrid Finish filler passes) l2 a- u; _$ P/ _2 x4 @
- OptiRough now two toolpaths, OptiCore and OptiArea9 J' k4 A2 ^8 X% ?: Q5 i
- Mill toolpath drop-down menu reorganization
3 \3 H; o6 @8 H2 ^' e, S) A: B
/ d Q- L) X9 I$ Z- RMultiaxis :
0 ~4 Z% p% A- w4 t- 5-axis Stock Model toolpath trimming
) K+ j" o0 n& T" N+ Z- Support for tapered tools
/ F5 t, o2 h/ w' b- Blade Expert& V" o0 X# _0 F5 Y; s Z
- Port Expert Enhancements 6 n6 I4 E, Q+ U0 A4 f Z
