查看: 2535|回复: 5
[求助] 有人知道如何读出刀shank吗?
发表于 2011-7-19 21:46:53 | 显示全部楼层 |阅读模式 来自: 加拿大
就是将图中绿色的部分的参数导入VB中.
发表于 2011-7-19 23:39:22 | 显示全部楼层 来自: 中国浙江台州
可以读出的!
 楼主| 发表于 2011-7-28 05:20:31 | 显示全部楼层 来自: 加拿大
可以读出的!$ r$ m. a" ]. g: }
wangzibo341224 发表于 2011-7-19 23:39 http://www.3dportal.cn/discuz/images/common/back.gif
. K/ Z. C  m) a2 q1 Q# _1 |9 f
9 V7 G& e# L, o6 C
3 G( I* `) f4 ]2 L全世界都知道,但说说方法吧 * R' E2 J) f4 V7 {& v$ y4 G
6 ?- T$ r1 L2 h5 W" n2 O我现在用工单的方法输出, 但这方法读不出没有用到程序上的刀夹。/ o% y: D" k( W6 Q% l
4 k6 x/ a2 U3 q) v: d
令一方法是读进刀具数据库再输出, 但效率不好。) ?# z& \9 Q! B) C6 N& s8 S
- H! n/ ~4 d  r, B* Q
ype,Name,Number,Diameter,Length,Tip Radius,Chamfer Angle,Chamfer Length,X Offset,Y Offset7 z6 J, ?- x7 h; F4 H
3 h3 N% I% d, \9 a4 |+ s: v5 pBall,1,0,10.0,50.0,0.0,0.0,0.0,0.0,0.02 g" M# x4 B7 R1 {
Holder********************************************
, z+ T2 U  i4 ?6 y2 n0.000000000000000 0.000000000000000 0.000000000000000
! g& J3 z2 e0 w& ?12.800000000000001 0.000000000000000 0.000000000000000
$ k( f. u& C/ T5 G16.070000000000000 0.000000000000000 17.050000000000001
6 F& z% W/ ^1 X8 A0 e1 K16.070000000000000 0.000000000000000 41.500000000000000
* D. s& G$ x5 T+ d2 t! Q2 S1 q' p' R25.170000000000002 0.000000000000000 46.730000000000004/ b1 g- U" }; w3 s3 ]
25.170000000000002 0.000000000000000 60.860000000000007
! p# S" {* t4 b- H+ u# p. N31.350000000000001 0.000000000000000 60.860000000000007
- j+ v) m0 t9 i) v/ @31.350000000000001 0.000000000000000 86.830000000000013
$ A% [* Y. m. V/ w  p! a
+ u1 Q! K. I, zBall,2,0,10.888,54.44,0.0,0.0,0.0,0.0,0.01 C3 D' }: O8 `' K+ L$ F" j# m/ Z
Shank--------------------------------------------  |) q5 ~, H- w- o1 E
0.000000000000000 0.000000000000000 0.0000000000000000 W% T# Q0 x# r* |% X7 Z
0.000000000000000 0.000000000000000 54.4399999999999983 x2 _. H- r2 w& }3 ~: N" ^
8.166000000000000 0.000000000000000 54.4399999999999986 S' J1 I$ J: m, r/ d# J
8.166000000000000 0.000000000000000 108.8800000000000008 r0 H* G8 U/ Q, u8 Y) r
' {$ e6 q  h- k5 R+ bBall,2_1,0,10.888,54.44,0.0,0.0,0.0,0.0,0.04 [# a" V1 _) Q- `7 V
1 F+ K( Q8 L$ @( A. v* t0.000000000000000 0.000000000000000 0.000000000000000
5 S! g  _3 V3 @3 L8 h8 W/ \0.000000000000000 0.000000000000000 54.439999999999998$ e% Y/ E  ?9 H
8.166000000000000 0.000000000000000 54.439999999999998, S2 H0 E: N0 C% o
8.166000000000000 0.000000000000000 108.880000000000000; e; w* S& F8 u- Y# R3 x0 C( {
4 ?# G+ l! Q" H3 {* z- p2 [Tap,3,0,10.888,54.44,0.0,0.0,0.0,0.0,0.0/ g3 m- p: q$ F5 q7 N
Shank--------------------------------------------' f2 H  m7 j) |- Z7 H
16.332 16.332 54.44 0
 楼主| 发表于 2011-7-28 05:22:11 | 显示全部楼层 来自: 加拿大
忘了补充, 这是为运行Vericut连接作准备的。
. d$ m+ `* r& h% N) S: s' N$ n3 i有谁做过Vericut连接的外挂呢?
发表于 2011-11-3 19:52:08 | 显示全部楼层 来自: 中国浙江宁波
这个我也在想  命令是什么   这样程序单就可以显示绿色部分的刀长
发表于 2012-8-7 10:30:06 | 显示全部楼层 来自: 中国上海
PRINT FORMVALUE RoughTool.ToolShankLen
