发表于 2011-4-29 08:23:38
来自: 中国广东佛山
1,写一个宏./ U1 Q# B/ d8 d* T* V- k
2,把草图名称改为"草图n".1 y; C$ s2 \$ l* h+ S
+ \9 S! L; H* i9 ]+ @
3 Y" o) O& U3 i2 C$ v, n) E5 MSub main()
/ R4 P! ?. ]( W: G+ G Dim swApp As SldWorks.SldWorks
; g2 i" k' p2 ?2 H5 V) W0 R Dim swModel As SldWorks.ModelDoc2
j" @: `! f3 j, w+ B Dim swPart As SldWorks.PartDoc+ M- y4 s. `; I5 L, h6 t
Dim swSelMgr As SldWorks.SelectionMgr
7 e9 ?8 t" @% k5 V$ I Dim swFeat As SldWorks.Feature3 C9 V# T* @5 ^; h" f
Dim swSketch As SldWorks.Sketch! @3 w0 \& ?& e( d. g( G
Dim mySelectData As SldWorks.SelectData; J9 R! E9 J7 ~7 W
Dim skContour As SketchContour0 W9 k7 e% J- F+ F7 |. m% ]' L; V
Dim vEdges As Variant, myEdge As SldWorks.Edge. z+ G: Y3 n9 s0 t i. \
Dim NumArcs, uuu As Long
- T6 K1 I6 s& B# J1 M- @% }# { Dim vArcs As Variant
4 y$ z) h: R u* R0 j, Z Dim vSkContours As Variant6 R# ^' x4 |$ U6 b8 ]5 ?
Dim vSkSeg As Variant
" X; ?+ y+ x3 l Dim i As Integer
w; z7 ~, y" p1 x" R" n; I2 u Dim boolstatus As Boolean
/ B( J3 d/ W, {8 l4 M4 E Dim swSkArc As SldWorks.SketchArc" q c$ S3 ]* `1 d1 V7 N! c
Dim swCurve As SldWorks.Curve" o( N! M! i7 |- A
Dim skPoint As Object
5 M) A7 p$ Q2 y- i E( D9 W Set swApp = Application.SldWorks
' K# y# x2 I4 C8 p; E/ K Set swModel = swApp.ActiveDoc' ?3 K# d8 ~& F* u: k/ c5 \
Set swPart = swModel) b- P1 v2 F0 d2 ]7 Z- ^
Set swSelMgr = swModel.SelectionManager
Y# b) Z% x) ?0 D; D' J Set mySelectData = swSelMgr.CreateSelectData
; Y5 |; P/ ^0 |& O$ C* D* S0 R Set swFeat = swPart.FeatureByName("草图n")5 c+ O) i4 K2 f' Q* p2 M
Set swSketch = swFeat.GetSpecificFeature
0 X) v2 r7 C; I1 j4 y swModel.Extension.SelectByID2 "草图n", "SKETCH", 0, 0, 0, False, 0, Nothing, 0
* A0 Y/ v" I5 F+ w5 }2 Q3 o* a swModel.EditSketch, C9 Y9 T0 x3 E( h2 [3 w
If Not swSketch Is Nothing Then
$ Z3 l6 e6 C0 _ NumArcs = swSketch.GetArcCount
' E1 Y0 D/ S+ _! t vSkContours = swSketch.GetSketchContours()
; u( N0 n" p: J7 U' Y9 u For i = 0 To UBound(vSkContours)* W4 ]' \" D. U% o4 I. F& P
vArcs = swSketch.GetArcs2
9 l1 ^; Q' [2 F! A% [. N5 x If IsEmpty(vArcs) Then Exit Sub3 U; ^. c A; t3 n3 w; ?; b9 J
Set skContour = vSkContours(i)
- ` k3 i! w" A: R If Not skContour Is Nothing Then
& y+ ?) W. u. h6 o) R9 W @6 H2 e If skContour.IsClosed = 1 Then! i, D2 \7 c- C. E: O+ E! t9 `$ b. a
uuu = skContour.GetEdgesCount7 T6 o. d$ K. o! W
If uuu = 1 Then
% j# Z j: R+ ~8 H& P9 [9 ^1 g. X( R. p vEdges = skContour.GetEdges2 ]% V+ `$ A- }- p* q2 h- y
Set myEdge = vEdges(0)% T* y/ v! b+ b8 e! m$ ]# K
Set swCurve = myEdge.GetCurve. N9 v$ \2 b3 y6 s6 ^0 g
vSkSeg = swCurve.CircleParams
* y5 W5 J# U, V boolstatus = skContour.Select2(False, mySelectData)8 v: S2 U( _. }- `& C
swModel.EditDelete
1 X* e! k ~+ }+ d T( [% o! H5 P* W Set skPoint = swModel.SketchManager.CreatePoint(vSkSeg(0), vSkSeg(1), 0)/ f2 O) s6 W- l/ u1 R# E) M
End If, l" L, p4 j8 V7 x H% k, @
End If$ V: z' _: _; Z0 Q/ }
End If
6 P2 x. C9 z* j2 {& I, V Next i% Z6 {3 j$ }5 V( m. g/ w+ ^
swModel.SketchManager.InsertSketch True. b, h5 ^) c/ V( H" y1 R9 }2 t' ]
End If8 U3 |' w4 z2 j2 B: @7 k
End Sub |
