查看: 2165|回复: 2
[分享] G82 P10000 後處理更改
发表于 2010-12-10 05:08:54 | 显示全部楼层 |阅读模式 来自: 中国台湾
本帖最后由 yit02yit02 于 2010-12-10 05:15 编辑 3 G( f1 F1 |& h+ R+ h( R. K& F
2 V* |9 @1 ?# G$ i
到台灣三重湯城欣昊((充電))上課五天
/ O' `+ [& p0 o/ w; k1 v0 R這次幫我們上課的是陳漢傑老師
6 C7 @3 [% ]# n1 {: w; V7 P2 f我也問了關於G82 P10000 萬分位的問題(一般是千分位)! O) s" B  [. ?/ |' h7 a5 {1 ^5 T$ [
陳老師也幫我解決了這方面的困擾# U/ X  \) i: X" P! q" `& M
首先開啟POST
  Z$ H' m/ g% j2 a1 Q6 T  A找到
  Y! v- I: _% |/ m7 S# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
% M5 I4 l5 T) D% z0 e5 a! Y# --------------------------------------------------------------------------+ v0 Y/ w$ F! N% v4 D: X" L
#Default english/metric position format statements
2 r  q! M% B4 f  z  [$ ?( ]fs2 1   0.7 0.6     #Decimal, absolute, 7 place, default for initialize (
8 d$ q0 A/ I7 }fs2 2   0.4 0.3     #Decimal, absolute, 4/3 place
* \  I2 f; ^3 z2 X# ^fs2 3   0.4 0.3d    #Decimal, delta, 4/3 place
3 o8 v+ n9 @2 m#Common format statements- X3 d3 ^7 P. f- I# s3 h. C
fs2 4   1 0 1 0     #Integer, not leading$ l& h1 P+ n1 V! `7 [
fs2 5   2 0 2 0l    #Integer, force two leading7 a8 ?' K1 h! R9 V/ o! g
fs2 6   3 0 3 0l    #Integer, force three leading
& i# ^- q7 o, H9 l( L9 n2 Nfs2 7   4 0 4 0l    #Integer, force four leading
. M2 H, l) E& D% L' Xfs2 8   5 0 5 0l    #Integer, force five leading) E# P  W! }: v8 P" v, X
fs2 9   0.1 0.1     #Decimal, absolute, 1 place
0 z$ q- N4 \" Y' C6 g  `, ]fs2 10  0.2 0.2     #Decimal, absolute, 2 place% G3 N& u+ X. }# F8 r3 `
fs2 11  0.3 0.3      #Decimal, absolute, 3 place
0 I+ g; v4 d) k- Zfs2 12  0.4 0.4     #Decimal, absolute, 4 place# _# Z" R; R) N$ u
fs2 13  0.5 0.5     #Decimal, absolute, 5 place' {0 \+ e9 j8 z$ ?& u
fs2 14  0.3 0.3d    #Decimal, delta, 3 place
' }) m" D& s/ Q2 _: |: _fs2 15  0.2 0.1     #Decimal, absolute, 2/1 place (feedrate), P/ S/ P( M( ~& I5 ^
fs2 16  1 0 1 0n    #Integer, forced output. @- ]5 O3 S5 b4 U5 ~& j$ ~
fs2 17  1.4 1.3lt   #Decimal, absolute, 4/3 trailing
, z) p% }. C& N& {  Kfs2 18  0 4 0 4t  (增加這一行)+ ^: Z0 ~# V0 \
" I+ N* h6 X# E8 w! \3 J5 d
再找到
8 `  w+ B# P* `: [+ q1 ~* k# --------------------------------------------------------------------------  U  G0 q$ ?) G4 ~
fmt  N  4   n$          #Sequence number/ S( j7 O4 f; S0 O
fmt  X  2   xabs        #X position output
* K5 n8 W8 E7 _+ H) Afmt  Y  2   yabs        #Y position output# E* Y1 Z* A2 _: G2 f" A+ s2 K# `' U
fmt  Z  2   zabs        #Z position output  m( v1 a: ]9 |, e- ^9 ~5 i
fmt  X  3   xinc        #X position output
7 z( ]: A5 _- B+ `# Ffmt  Y  3   yinc        #Y position output) o% ?  c# Y4 M; A; c. h9 _
fmt  Z  3   zinc        #Z position output
3 e8 \- k* T% n" P1 o2 rfmt  A  11  cabs        #C axis position
% {3 B  U0 K8 `0 K- _0 k/ L+ Gfmt  A  14  cinc        #C axis position
# X7 W8 k4 @3 ], Q" K8 f3 [fmt  A  14  cout_i      #C axis position' b# ]/ L! M2 s
fmt  A  4   indx_out    #Index position
; L) s. z- _8 m) F" `: Z5 Kfmt  R  14  rt_cinc     #C axis position, G68
- b3 d, u: L& z. ufmt  I  3   iout        #Arc center description in X
/ K2 J6 n# L) d4 J! O( Qfmt  J  3   jout        #Arc center description in Y. L* y& z+ E* f4 w8 m/ d$ q
fmt  K  3   kout        #Arc center description in Z$ c8 J" N( p* X- ^- x
fmt  K  2   lead        #Helical lead- G; S7 h$ g* c8 I3 O
fmt  R  2   arcrad$     #Arc Radius6 u* N  q. ]$ f) H2 Z# Z1 T& Y
fmt  F  15  feed        #Feedrate
- J/ p" K! k: W  u- ^# p9 Y2 Hfmt  P  11  dwell$      #Dwell (把P11改P18)1 I. o. o) u. `. Q
fmt  M  5   cantext$    #Canned text! v4 Y' V: r5 S$ m5 V" @
fmt     4   mr2$        #HSM, R: D& D: h- z( U
程式選G82時暫停時間打1.0
/ u2 o* C' c5 [; J! U/ r轉出來就會是G82 P10000
) j/ E% Q+ t% o: S9 h+ A1 r真是謝謝)))陳老師)))))
参与人数 1三维币 +10 收起 理由
pengxiangxu + 10 好资料,感谢您对论坛的支持!
发表于 2010-12-10 20:17:47 | 显示全部楼层 来自: 中国台湾
yit02yit02  Thanks for sharing
 楼主| 发表于 2010-12-10 20:41:16 | 显示全部楼层 来自: 中国台湾
2# andy124203158
' b# Y* Y, F9 ~& ?0 i* m4 X4 U2 O* j3 W: B
之前轉出G82 R3.Z-20. P1.0 F100.
6 q1 ?4 |: @9 KFAUNC 會發出錯誤訊息!
. s% g5 W$ G3 h% b) y: {老師就是專業!
