查看: 3748|回复: 8
[已解决] GG-15HC Cu Cr 是什么意思?
发表于 2010-11-9 12:27:09 | 显示全部楼层 |阅读模式 来自: 中国辽宁大连
大家帮助我看看,一款产品,是做汽车排气管子的,材质一栏里面有这么个东东,GG-15HC Cu Cr 大家帮我看看是什么意思!!!
发表于 2010-11-9 13:27:05 | 显示全部楼层 来自: 中国湖南株洲
GG-15HC  不明白 是什么东东 是国内的么?
 楼主| 发表于 2010-11-9 13:34:26 | 显示全部楼层 来自: 中国辽宁大连
好像是德国的东东
 楼主| 发表于 2010-11-9 13:55:08 | 显示全部楼层 来自: 中国辽宁大连
GG15HC' c' }8 U! C. y4 k" E, s" K$ w$ k( O
汽车制动盘,材料到底是什么东东
发表于 2010-11-9 14:49:33 | 显示全部楼层 来自: 中国上海
按德国牌号标准,GG-15是灰铸铁,15表示抗拉强度150MPa。另外的符号啥意思不知。
发表于 2010-11-10 10:59:50 | 显示全部楼层 来自: 中国江苏南京
德国的合金灰铸铁,后面为合金元素
发表于 2010-11-10 14:56:48 | 显示全部楼层 来自: 中国江苏常州
本帖最后由 wenjuanzhi2008 于 2010-11-10 15:00 编辑 # d2 v' W% r* V0 H1 f
( \! }; M: k0 K. h3 D0 l. R7 [
HC:High Carbon Cast Iron; Cu,Cr is the mainly alloy element.
' A# v7 g/ Q8 m; [5 sThe material in the German literature GG15HC sign, in English is GIHC (Gray Iron High Carbon). # W2 Z! |9 b& |
GG-15HC: A wide range of cast iron is produced from the HC-type cast iron used in the manufacture of brake discs, because of its favorable effect of alloying on the texture and very good resistance to abrasion. # B& w/ o) H' m6 d1 S% w
The cast-iron texture: Graphite (%) 12.5, Graphite shape IA3, Perlite (%) 99, Ferrite (%) <1;
! z" m" ^# D# j* c, t& h+ k; g9 ?Chemical composition: C 3.73, Si 2.07, Mn 0.78, P 0.058, S 0.085, Ti 0.014, Cu 0.56, Cr 0.27, Sn 0.039.* v9 ^; s: w/ ^
Mechnical property:Hardness: 180 ± 5 HB, Tensile strength:240 MPa. 1 i% j6 Q  [& X( v: X1 K9 ^3 c6 r
The cast GG15HC marked characteristics:
2 K( |( m% e/ ^# e' z0 R: i. A- High thermal conductivity,2 M, h1 ?( S. t# Q
- Low thermal stresses,+ n+ O; Z' J  Z" n7 c, T, H
- High resistance against cracking due to heat generated,
& a! }8 R' o" @6 C( P- Good shock absorption properties.
wwjxgz + 3 应助
 楼主| 发表于 2010-11-11 14:05:39 | 显示全部楼层 来自: 中国辽宁大连
7# wenjuanzhi2008 / j& F  X7 d0 o' `2 s- s
/ A9 z- V: t4 w. |' Xyes, you right, the iron was used in brake!7 _% X% H2 [5 _3 c
thank you very much for your help, and do you have some standards for this grey cast alloy, I want to know where does  the data comes from;
: \& R& E" q9 O; U6 M+ ]6 I( ^thank you!
发表于 2010-11-11 14:20:54 | 显示全部楼层 来自: 中国江苏常州
Please refer to the attachement as belows, the thesis is witten by Hungarian, you can find google translation for help.
HC type cast.pdf
140.17 KB, 下载次数: 6
wwjxgz + 3 应助
