$ j* r; R) [9 s2 t9 l! }( ]! }- S
1) If you are using SE ST2 pirate's licenses (by ODDiTY or illmaR) you will get a problem with opening files (in SE ST2 MP4 and higher) saved under such licenses
( V9 |# ?" f; t* X% R5 h" QIn a month after saving files you will get warning "Internal error 0x248" and files can not be opened any more..
. Y2 Z t4 _, ?0 d& M4 D4 F; } n6 i* Q
4 d9 H' A# v8 p) o2 p% c9 y- D
2) This SE ST2 files cleaning tool ( SECleaner.exe ) deletes from SE files information about blocking for opening. After cleaning files can be opened both under legal and pirate licenses, but if you will save them under pirate license they will me marked and a blocked again..$ }; k8 e; a5 n" a% `6 K$ F
So you need to use this cleaning tool time after time if needed/ ]. q" }- \/ @
8 M' T* G: r4 F. \7 c
3) The using of tool is very simple3 P: b) h( N# `
- Q3 @' L% ^3 U: @0 E
Run "SECleaner.exe"
9 ?0 J) z( @6 H/ t" nBrowse to folder with "blocked" SE ST2 files- }- f2 B9 p) S1 V" O
Click "Clean them!"
, g$ i; M1 C& a- }Program will scan all SE files in that folder (and subfolders) and will clean files if needed..' l# X! G& W3 e7 c7 y1 h
7 [; M: {$ W0 q; j" G! ?: D
Good luck!
7 z* v6 @, Z, d, YTeam- SolidSQUAD |
