发表于 2010-5-7 16:28:34
来自: 中国四川德阳
以下我把我的源程序共享给大家:希望共同学习!主要难点调用打印命令3 g6 t8 H2 W! D
$ p v5 {0 s& T: f0 c& ]$ S4 {
;;图纸连续打印A4
! S1 z( t6 R' j) G2 p(defun c:dy ()& h( N9 _* L. o. p. J8 o- H
(setq num 8) //打印张数- L: q9 a# b; H* \" a* r
(setq hang 3) //打印行数. Z8 v# ?0 B: w4 b2 Z w
(setq lie (+ (fix (/ num hang)) 1))
8 X/ o9 D) \1 {$ o (setq i 0)
7 A8 w; |% M# M+ }7 \+ S2 o (alert "选择坐标原点!")
4 D* r& f. f2 y1 v% E. Q6 L (command "_ucs" "n" (getpoint))
; T( a) ^- d6 Z2 ]2 c+ b/ q (command "")
0 R! ?2 k1 |- z7 n3 K( _& T (while (< i hang)
% p, w1 k$ u g+ a3 s! v( m (progn
6 i. z1 P& w- I (setq k 0)9 e8 Z) u# p+ W! \
(while (< k lie); `3 g9 w5 R# l" C$ c
(progn
4 H# f! n8 T4 v" q (if (/= (and (= i 2) (= k 2)) T)% S3 \; g8 |9 E: q
(progn4 q7 U9 s5 t9 W W W2 A; ^
(cond
8 t( O3 a. w$ l4 t ((= i 0) (setq hangnum 0))
2 d7 P8 }: V! f$ X( ~9 {1 l9 K0 l ((= i 1) (setq hangnum -230))
- z \6 b. R3 A, p ((= i 2) (setq hangnum -460))# \2 U. K& S; R! I5 P! T0 f; u
)# ^6 U+ {4 Z x0 v! g$ m' @. L( ?8 b% C% b
(cond! L) P4 x, K+ J% m
((= k 0) (setq lienum 0))' J- ?' Q; Q) L) \9 `4 X
((= k 1) (setq lienum 312))
1 U% W! S$ f, S# t/ j ((= k 2) (setq lienum 624))
% {' J; U4 h# u7 X )
1 L# V. B2 x6 i% I# ~) M! k (setq startpoint (list lienum hangnum))
; a8 L5 r, H4 \7 v2 l% U0 m( F D (setq endpoint (list (+ (car startpoint) 297) (+ (cadr startpoint) 210))); t7 r( V4 ?) \4 x5 `
(command "_plot"+ ~7 Q+ v; B7 ~+ I
"y" q: J4 q3 i! J" D' c
1 X O7 W' x! w" |! q" \ "\\\\Jz-dy\\HP Deskjet 1280" //此处是打印机型号,可支持局域网打印机
6 j5 w1 ~7 ]$ o4 ]" E" R ""
% x6 J7 L' t' Q" M, q/ N$ ~ "M"
. x6 F$ P& c1 [9 o1 M% _" K' |9 P! o "L"
( S2 S: P7 [. I0 S1 J+ }0 j "N"
; w2 K: |* U- j+ } "W"
) u' z2 x9 I" Y' V: D9 N3 ~ startpoint
( w& S3 S& j3 ^" e2 l3 U0 ^ endpoint$ z0 @: K. W; C) k1 z* |+ ^/ ~6 j8 H
"F". T" f) T1 _# s6 t% L
"C"
" r" e+ N5 E! R! V "Y"- K& R5 |, m/ Q5 y0 _( P* u
"monochrome.ctb"4 R/ _2 m2 E3 O) E: H1 U1 @4 p
"Y"
8 u( ^. h2 P' x Q- S+ W9 Z% a "W"
4 d5 `7 ?2 u9 ]. @$ ]- o+ G8 u "N"
2 f0 L' O) m, H8 @ "Y"9 X" _/ ^3 [. ~" `. d8 Q, L
""4 v8 h9 U$ ?5 F2 d A! J/ @- f- ~$ T F
6 K, {( Y& D( w )
4 [" b+ Q/ f$ d1 S )
[8 e$ k. i o& l; q( ] a )
. Y2 S+ K S f. r0 V (setq k (+ k 1))# G- P, m) I+ F6 O% V3 R; L6 q* O
$ v" K, r& Z+ N: @" I; t( R* ?, u (setq i (+ i 1)); Q% L8 g' j7 k8 l0 W: y
)1 k/ F0 J4 h) V/ R, a$ E
(princ) p0 I/ i7 O* Z5 q" E0 W2 _
