查看: 13668|回复: 65
SolidCAM 2009 SP4 HF1 (Chinese Simplified-English) for SolidWorks 2007-2010
发表于 2010-2-22 15:08:25 | 显示全部楼层 |阅读模式 来自: LAN
Version: 2009 SP4 HF1 (released 18 January 2010)9 h- [( N; P) g( j
SolidWorks supported: 2007-2010 32 bit & 64bit, k8 }& {% m$ ^. L% J; i2 ]& ?
Languages supported: Chinese Simplified, English/ o& f( u+ x9 E5 i
Size: 600 MB (ISO: Setup + crack)
2 D4 h* p" t* q; x
/ j! f! N% D3 }$ [2 g$ k; }2 w1) Here is RS links (Setup +crack)
# D% d6 F& C  v0 Y2 K  b" Kh-ttp://rapidshare.com/files/353926409/SolidCAM_2k9_SP4_ChineseSimpl-Eng.part1.rar.html; J8 X% @5 \1 W
h-ttp://rapidshare.com/files/353925446/SolidCAM_2k9_SP4_ChineseSimpl-Eng.part2.rar.html
7 V- U, |* l( |2 B0 a8 Dh-ttp://rapidshare.com/files/353925600/SolidCAM_2k9_SP4_ChineseSimpl-Eng.part3.rar.html
( t* ?2 {: O7 I. e0 ]! _& fh-ttp://rapidshare.com/files/353930590/SolidCAM_2k9_SP4_ChineseSimpl-Eng.part4.rar.html
6 h2 `- J+ V, N2 M2 O# K" i$ y( `/ Fh-ttp://rapidshare.com/files/353930698/SolidCAM_2k9_SP4_ChineseSimpl-Eng.part5.rar.html7 Z! e5 w. c& o( k+ {7 q
h-ttp://rapidshare.com/files/353929059/SolidCAM_2k9_SP4_ChineseSimpl-Eng.part6.rar.html
) H+ G; c: E3 x& _) b! g, a; t9 z2 Y' j" D
2) Here is local FTP link7 |+ t/ f6 e3 C7 c0 `7 n6 e
http://www.3dportal.cn/discuz/viewthread.php?tid=873315
$ ^4 R# h! e& {  ^' f1 i# J% ^; p: i+ J; r9 b) a' j$ E) P/ z; F
3) About crack
0 N! c& D1 I; s2 }! PCrack in release is USB HASP HL Emulator (with service vusbbus.sys and dump storing in Windows Registry parttion
# F! k8 d1 j- c- B/ j0 n6 Q' D[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\NEWHASP\Services\Emulator\HASP\Dump\4C8F743C]
5 a5 _  n7 _4 ]+ I5 \/ J  p7 D- |If you have other USB HASP HL Emulator already installed (for example USB Emulator for Mastercam or some other programs) you can use it, but you mast check if it uses the same Windows Registry partion for storing the dumps. If needed you can edit SolidCAM_Win32.reg and SolidCAM_Win64.reg for your Emulator
发表于 2010-2-22 15:26:06 | 显示全部楼层 来自: 中国浙江宁波
solid_user老大总是时时给人惊喜啊,马上去下载,rapidshare用工具下载起来也不慢啊
发表于 2010-2-22 16:52:26 | 显示全部楼层 来自: 中国台湾
:)好東西!感謝樓主無私分享。
发表于 2010-2-22 19:28:55 | 显示全部楼层 来自: 中国广东佛山
发表于 2010-2-22 19:44:39 | 显示全部楼层 来自: 中国江苏苏州
非常感谢!正在下载中,终于等到了2009的中文版,
发表于 2010-2-22 20:02:08 | 显示全部楼层 来自: 中国湖北宜昌
非常感谢solid_user,但我不能下载,能发到我的邮箱吗yc.liuping@163.com
发表于 2010-2-22 21:57:43 | 显示全部楼层 来自: 中国湖南湘潭
不知道怎么下
发表于 2010-2-22 22:03:43 | 显示全部楼层 来自: 中国江苏常州
谢谢分享,速度有点慢。
发表于 2010-2-22 22:04:20 | 显示全部楼层 来自: 中国江苏常州
谢谢分享,支持一下,速度有点慢。
发表于 2010-2-22 22:38:47 | 显示全部楼层 来自: 中国广东中山
很感谢SOLID,经常看到你的作品, 对我们帮助很大
发表于 2010-2-22 23:22:37 | 显示全部楼层 来自: 中国贵州六盘水
楼主真是牛人啊,总能找到好东西分享,顶一个!
发表于 2010-2-23 15:00:16 | 显示全部楼层 来自: 中国山东青岛
非常感谢···········
发表于 2010-2-23 19:10:49 | 显示全部楼层 来自: 中国江西九江
太感谢solid_user了,还是中文版的,强啊
发表于 2010-2-23 20:35:47 | 显示全部楼层 来自: 中国北京
怎么安装,如何Crack。
发表于 2010-2-23 21:41:33 | 显示全部楼层 来自: 中国江苏无锡
正在从FTP下载,但不知道有没有Crack!
 楼主| 发表于 2010-2-23 23:03:00 | 显示全部楼层 来自: 俄罗斯
正在从FTP下载,但不知道有没有Crack!5 c4 {% I2 ]2 p+ F; |
fushuixiu 发表于 2010-2-23 21:41 http://www.3dportal.cn/discuz/images/common/back.gif
7 K1 _# b; j$ V. S, ISolidCAM_2009_SP4_ChineseSimpl.iso on FTP and release on RS includes Setup + crack
发表于 2010-2-23 23:13:01 | 显示全部楼层 来自: 中国
下载完了里面什么都有了,(crack)我已经装好,很好用
发表于 2010-2-23 23:15:59 | 显示全部楼层 来自: 中国上海
谢谢分享!
发表于 2010-2-24 08:24:54 | 显示全部楼层 来自: 中国台湾
THanks solid_user
发表于 2010-2-24 11:10:40 | 显示全部楼层 来自: 中国辽宁朝阳
17楼的高人,能介绍一下安装经验吗?
发表于 2010-2-25 00:08:54 | 显示全部楼层 来自: 中国广东惠州
17楼的高人,能介绍一下安装经验吗?
  d$ Q- ]) u  @$ xyujinghua 发表于 2010-2-24 11:10 http://www.3dportal.cn/discuz/images/common/back.gif
1 L9 ]; w! B2 [# b: c, m, J  X不难装的,你自己装一次就知道了
发表于 2010-2-25 09:37:46 | 显示全部楼层 来自: 中国辽宁朝阳
安装了好几次,大概是系统的的问题,总是启动不起来,还是Crack有问题!
发表于 2010-2-25 09:39:47 | 显示全部楼层 来自: 中国辽宁朝阳
错误是“.......该内存不能为read”
发表于 2010-2-25 09:52:01 | 显示全部楼层 来自: 中国
8 z9 w% `/ F, r6 `0 p) ~yujinghua 发表于 2010-2-25 09:39 http://www.3dportal.cn/discuz/images/common/back.gif
( v1 i* E: j; f1 ]/ \可能是系统问题,资源可以肯定没问题,系统最好不要用什么优化版的
发表于 2010-2-25 10:08:48 | 显示全部楼层 来自: 中国江苏无锡
能用在SW2010上的吗,挺好
