我刚下了一个cimatrone9.0 official 版但里面的 cimatron. LIC 似乎不好用。请装好E9.0 official版的朋友帮忙看看这个lic文件 讲一下怎样安装 如图:( S) k/ ~( [6 B' |
server localhost ANY 7788, f6 S3 k: A* Y/ \ z6 }
PACKAGE PKG_COMPLETE_SYSTEM cima-d 9 COMPONENTS="2X-MILL 3X-MILL \
" g# f4 v* G1 C0 M 3X_SIMULATOR 4X-CONT 5X-CONT 5X_SIMULATOR 5X_TRIM CAD_MODE \
( Q. K" L/ {3 X8 r7 B' f: \ CADENAS CATALOGTOOL CATIAR3D CATIAW3D CORE_STANDARD CORE \
& B4 m. c6 s2 e DIE_QUOTE_GENERATOR DRAFT DWG DXF EDM_SETUP_WIZARD \ d$ z; F7 P! G5 @
EDM_WIZ_AGIE EDM_WIZ_CHARMILLE EDM_WIZ_DPC EDM_WIZ_INGERSOL \% s. S8 @0 ^& E8 @/ D5 {# A
EDM_WIZ_MAKINO EDM_WIZ_MITSUBISHI GPP IGES LATHE_2X \
; V" y x0 s9 \7 u3 B. L9 E LATHE_PP_COMPILER LOCAL_3X MACHINE_SIM MOLDDESIGN MWSIM_3X \' X( l, B% \9 c V, a2 A( w
MWSIM_5X NC-LINK PARASOLID_SAT QCOMPARE QELECTROD QSPLIT \
) k2 g+ ?, G9 S% n/ u0 L& i- t2 t2 z QUICKDRILL R_CATIA5_PMI R_CATIA5 R_CATIA_SAT R_IGES \
% `% p9 \! H! R U: ` d R_PARASOLID R_PROE_PMI R_PROE R_SOLIDWORKS R_STEP R_UG_PMI \8 m8 T5 P0 c+ l/ n( E: G* o9 d
R_UG R_VDA RD-PTC SAT SOLID-ASSEMBLY SOLID STL UGR3D W_CATIA5 \9 o7 _+ G) L, a6 _. d/ V
W_CATIA_SAT W_IGES W_PARASOLID W_STEP W_VDA W_VRML WIRE_2X \% c9 \, l+ E1 {
WIRE_4X WIRE_STANDALONE DIE_TRANSFER " ISSUER=CAXiSO TS_OK \
* M0 L6 D4 z. w SIGN=3E05261E778C
6 h! x- ]( |9 G) m( g. nFEATURE PKG_COMPLETE_SYSTEM cima-d 9 27-nov-2009 uncounted HOSTID=ANY \7 r7 u' g M, w$ {2 W" s: r
ISSUER=CAXiSO TS_OK SIGN=268E76E4117A
) C3 D( e5 R0 _* y# YPACKAGE PKG_COMPLETE_SYSTEM2 cima-d 9 COMPONENTS="5X_AEROSPACE \. ]: z G4 v2 P; s: [
API_IT_DIMA2DIMA API_IT_EFUSION API_IT_EHEEL API_IT_ESHOES \) `# r9 O& y% L' t
API_IT_REENGE AUTOMATED_DRILL CATALOG_CABE CATALOG_CN_FUTABA \5 |5 e" J3 D8 V. q, R
CATALOG_DANLY_INCH CATALOG_DANLY_MM CATALOG_DAYTON_INCH \
5 z/ M* d+ W+ I8 k' k CATALOG_DAYTON_MM CATALOG_DE_MEUSBURGER CATALOG_DME_INCH \
: q" V" l- K0 c CATALOG_DME_MM CATALOG_DMS CATALOG_FIBRO CATALOG_FUTABA \( y6 S8 g. I) o, a: W$ T- v
CATALOG_HASCO_INCH CATALOG_HASCO_MM CATALOG_IT_PEDROTTI \
& \0 j0 u6 v" L/ Q, y5 m# {8 I CATALOG_IT_SIDECO CATALOG_IT_SKF CATALOG_IT_STAMPI \$ F& V7 e: S8 m D
CATALOG_IT_SYSTEM3R CATALOG_IT_TVMP CATALOG_IT_UNI \4 E7 U# i4 U1 P
CATALOG_KISHIN CATALOG_LKM CATALOG_MEUSBURGER CATALOG_MISUMI \2 Q7 K. ~+ e3 @
CATALOG_OKSET CATALOG_PCS CATALOG_PEDROTTI CATALOG_POLIMOLD \
/ F" D- H3 D, y CATALOG_PROGRESSIVE CATALOG_RABOURDIN CATALOG_SIDECO \ w- n4 b& ~! n0 U
CATALOG_SKF CATALOG_STAMPI CATALOG_STRACK_NL CATALOG_STRACK \7 X0 C4 N, q, H6 ^4 n! t
CATALOG_SYSTEM3R CATALOG_TEKIS CATALOG_TVMP CATALOG_UNI \
7 E z" L# G3 l t4 B& P# [" G CATALOG_VAP CONCURRENT_DESIGN DIE_BLANK DIE_FLANGE DIE_FORM \
' _% r" Y& ]+ y1 f1 \6 ?6 x$ i DIE_LABEL DIE_PLOT_SAFETY DIE_PLOT_THICK DIE_SET DIE_STRIP \3 {6 O" _; ]. Z- u: `) a1 O
DIE_TOOLS GPP2_3X GPP2_5X GPP2_DEV_DF2 GPP2_DEV_EX2 GUN_DRILL \6 E# A; ^) Z* j' j: T6 G7 g3 K2 ~
MICRO_3X MICRO_5X NC_UNDERCUT R_INVENTOR " ISSUER=CAXiSO TS_OK \
3 ^9 r9 x7 h) P" F4 N5 e; ^, b! T SIGN=ACBE473839AE
+ g/ N2 ?4 g& @$ k% E7 gFEATURE PKG_COMPLETE_SYSTEM2 cima-d 9 27-nov-2009 uncounted \
2 R) ]7 p$ j& l( h# L& i$ V% E- y HOSTID=ANY ISSUER=CAXiSO TS_OK SIGN=059C7A5059DE
0 O% F" v |# d" C8 ^, b. \( j7 Q8 ?FEATURE CHINESE_TRANSLATION cima-d 9 27-nov-2009 uncounted HOSTID=ANY \) q: K. S6 i; N$ ?& F- |
ISSUER=CAXiSO TS_OK SIGN=D93BECA02C44- o* o% J; g% y( Q9 h, l# F
FEATURE $ABCDEFG123456++= cima-d 9 27-nov-2009 uncounted HOSTID=ANY \7 n! `+ V$ l4 c) [
ISSUER=CAXiSO TS_OK SIGN=5C3D4974CDF0 |
