楼主 |
发表于 2009-11-24 23:35:47
来自: 中国广东东莞
FORM BLOCK
9 W3 d: p' c7 t* u) ZDELETE BLOCK5 @& Y/ X* }, b: c! j' L1 ~ t
EDIT BLOCK ALL UNLOCK
. D. @: H/ r- {& u& ]9 B, Y$ A7 pEDIT BLOCK RESETLIMIT "8"
) h1 Q' S( T& L0 `( NEDIT BLOCK RESET
; h# j1 b1 o2 Z1 e' {# ~EDIT BLOCK ZMIN LOCK
$ J9 Y- E( e1 DEDIT BLOCK ZMAX "31.0"# o; S d* b) I
EDIT BLOCK RESETLIMIT "8.0"
5 e; G3 w* u9 b/ K" F& p8 uEDIT BLOCK ZMAX LOCK
% N: I2 E9 D9 m9 J& l+ @6 ZEDIT BLOCK RESETLIMIT "30"2 A- X5 H- t, |: x \8 ^! H
EDIT BLOCK RESET' T5 T/ j1 ]8 B7 v
EDIT BLOCK DRAWMODE 0
! f6 N7 W" r) W( fUNDRAW BLOCK
# N- J8 T5 {! B8 X0 aBLOCK ACCEPT
% Z$ U4 ], W) ~! _) hEXPLORER SELECT Tool "Tool\R刀\R3" NEW
' {- i0 \. U. i( L; B% k5 n3 j" }ACTIVATE Tool " R3"7 M# c, b) [: k! G
CREATE BOUNDARY ; SELECTED FORM BOUNDARY
) B0 s, F! E f$ X, f3 ]) GEDIT BOUNDARY "1" SELVERTICAL UP5 Q* A2 f3 J& u5 H3 ]
EDIT BOUNDARY "1" TOLERANCE "0.01 "
: V' v+ _4 B4 o% m; O: X7 UEDIT BOUNDARY "1" THICKNESS 0
& K7 z2 t, Z& }0 pEDIT BOUNDARY "1" THICKNESS -0.07+ s3 ~, o0 {5 Y& o9 a# Z
EDIT BOUNDARY "1" CALCULATE
) Y5 w; t- `, ]; [' dEDIT BOUNDARY "1" SURFACES ACCEPT BOUNDARY ACCEPT
2 h! Y$ o7 p+ @) P; YEXPLORER SELECT Boundary "Boundary\1" NEW
. C) S/ }5 R) v/ h# N) {RENAME Boundary "1" "a"$ ~: Y; M7 i, d) y
EXPLORER SELECT Boundary "Boundary\a" NEW
~2 Y6 g7 P9 z! S! Y* k0 S7 tEDIT BOUNDARY "a" 3DOFFSET `8 N! J3 y0 v" x: h x
0.5: h" q; j1 C/ q. z$ R
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI
) l+ G- g4 s2 ^. ~"Finishing\Raster-Finishing.ptf"
" h0 Y& d: v6 N; s. ^5 G* x0 p! OEDIT FTOLERANCE "0.01 "
" x9 o. g3 r/ J+ f0 rFORM FILTER
& s" A2 L# Z4 d4 H3 E& O; _- ]EDIT FILTER TYPE REDISTRIBUTE
. r% k2 K3 \$ L* c% A' gEDIT FILTER FACTOR "0.1"
7 Z7 A$ g8 Q" |" I& e8 DEDIT MESH TOLFACTOR "0.1", Y% k. i3 p7 o4 B# m0 p" r
FILTER ACCEPT
! O+ o/ K! T2 e5 k/ nEDIT FTHICKNESS AXIAL_RADIAL ON
# q! f1 Q" n1 n( rEDIT FTHICKNESS AXIAL_RADIAL OFF7 n: k7 q( I- h! s+ \
EDIT FTHICKNESS "-0.07 "1 O* w/ B. c" G7 N; K, Z0 w
EDIT FINRASTER STEPOVER " 0.11"! {9 Z& ~2 Q( I- F- N: F
FORM LEADLINK" R; R9 A' x$ x3 T
EDIT TOOLPATH LEADS INCREMENT_FROM_STOCK N
7 F$ a5 k, V8 I/ IEDIT TOOLPATH LEADS PLUNGEDIST "1"' B% B0 y% J& y7 Q7 g
EDIT TOOLPATH LEADS PAGE FIRSTLEADIN- m* o1 k9 O$ s0 w; d; M
EDIT TOOLPATH LEADS PAGE LEADIN
/ ?' l; D/ C* s; a8 m9 WEDIT TOOLPATH LEADS PAGE LINK
# F, f0 p' J0 A; f3 K) }' vEDIT TOOLPATH LEADS LINK SURFACE
, a' I$ d5 ^3 c5 JEDIT TOOLPATH LEADS LONGLINK SKIM3 s/ j. G' s3 c/ x1 b
PROCESS TPLEADS
& c6 A# {* e" o# [0 e/ w* bLEADS ACCEPT" Q& L1 Y l6 ^* v R" P5 @
EDIT FINRASTER ANGLE " 45 "2 F6 a4 @4 S5 G
EDIT FINRASTER STYLE TWOWAY
: V8 W& w9 B7 N. t: B+ y* V/ eEDIT TOOLPATH "1" CALCULATE
, o' c3 u. r8 l2 Q& z- r! q3 P1 pFINISHING CANCEL
1 \. ~, F, T/ @4 uFORM TOOLZHEIGHTS
: K+ }5 M4 c9 IEDIT TOOLPATH SAFEAREA RESET5 g3 W3 r! Y5 o; T! r8 }
RESET TOOLPATH RAPID/ ~- J# c+ r: f' y' ?7 @) ?
TOOLZHEIGHTS ACCEPT! R* ^. A) ^0 a( G& {; x
FORM FEEDRATE
4 {5 _# W% [" H$ V) F8 lEDIT RPM "18000"
. G% D% c/ G. J* J9 W! m! REDIT FRATE "2000"; Q8 _1 E. s0 ?4 i
EDIT PRATE "2000"
( ]( G: Z3 e1 ~; Y, h# L, aEDIT RSPEED "5000"$ V5 }- ]* N9 [
RESET TOOLPATH FEEDRATE
; `) E) V0 e) L% q- r6 zFEEDRATE ACCEPT! \' o6 z, k- p
EXPLORER SELECT Toolpath "Toolpath\1" NEW
$ l7 I3 p( v5 D# Z, W3 f0 _RENAME Toolpath "1" "曲面平行加工"
- {$ o" e; X; {) i4 IEXPLORER SELECT Boundary "Boundary\a" NEW
: U q( k# x8 L( w# v% F& d( y1 uDEACTIVATE Boundary- a3 Q: C" }* a) M8 i4 f* ?$ c
/ x$ [ N. x- K2 G8 {; C6 s4 D
) T/ y! P1 d" `% w! @
0 y7 ^+ r5 J4 |7 n, S$ p* Q% q红色字为变量,我希望可做到,运行到变量时,手动输入,值!麻烦你了,版主好人! |
