3天前
查看: 4883|回复: 15
[注意] NX7补丁 Maintenance Pack 1 for NX 7.0.0.9
发表于 2009-10-15 13:43:33 | 显示全部楼层 |阅读模式 来自: 中国广西柳州
Date:               29 September 2009
# G+ X6 [! C0 H" o! X) `, e2 _) F, I' b! a
Subject:           Maintenance Pack 1 for NX 7.0.0
0 d& z1 n, ~* w
5 P% r. v  q) Y7 c9 r
To:                   All users of NX 7.0.0
. u/ @" @! v. K, T1 B; ]6 ?, I! t: z" L5 G
! A3 f7 A; M: H$ k# A/ z# u2 A# k) a0 B! V1 o
! P, O" N8 t( Y. e
; Y( T4 @* \9 K/ s, b/ h
We are pleased to inform you that fixes are available for the problems listed below.  A maintenance pack (MP1), built for installation on top of Windows XP32 and Windows XP64 images of NX 7.0.0, can now be downloaded from the Siemens FTP server.  This maintenance pack fixes an accumulation of problems listed in the tables below.
1 d1 t6 [, {! D# w6 L2 a- ^7 ^4 N2 d
8 ?. l3 g& h9 `+ B! I
4 q6 F3 Y% O! B: ~* T! q
  U) u& O" |/ T/ S1 z9 p* q
Release
5 x* x& o- O% ^3 c3 G2 M
PR Number
' G6 W+ t: a0 f8 K" h
Problem Description
, ~' ~% Q5 u1 ^" f* M
MP1
* m" a5 E2 _) o. ]+ T8 t& y% q' I
2127947 2128621 2129923 2129275
The problem in Teamcenter Integration for NX if "Check-out Policy" was set to "Manual" assemblies failed to save is fixed. The problem in Teamcenter Integration for NX where the "Save Assembly Hidden Line Part" command did not save the Part Name and the Part Description attributes is fixed.4 w2 O7 D7 b) t- t0 N
$ U! E& f( J& a2 D% p
MP1
( G, ~7 l9 x  }& b
6189561
The problem in Shape Studio where the X-Form dialog selection was not showing the text for options is fixed.1 t- N/ q9 Q* e( ~6 y* s& X
+ L0 {/ M3 R8 j, r* f! I8 f
MP1
) h: H: L$ u9 K" d* v
6192252
The problem in Section Analysis where the selection options "Rectangular Select" or "Select All" did not work when the poles were displayed is fixed.! L- O% V( m& v5 M( O5 k+ u$ Y6 }" F. _/ V/ o$ i6 s
' V9 B1 T+ r; w) w! N0 q1 `/ |: C. S1 H( P: @1 y2 U
1 o% P6 ^0 q+ i+ X0 I: T! a6 j) V; f( Z8 N& e
5 h* Y* I. u, g. o- d6 K& k- N) b1 _6 \
Windows update instructions
# a' e; I+ W+ E7 z0 h9 x$ Z% X9 g2 J
. [3 M! Z4 r+ Z4 V% e  k0 v1 s+ [% E2 Q: k- P
The files contained in nx-7.0.0.9.mp01.zip are provided as replacements for previously installed NX 7 products.
# B/ O% C7 z7 _
+ w, p8 H: o( ]1 W
- g- [' b8 B; {2 L$ ^. b  n0 O( ~5 A! S, A0 o
For the Windows XP32 platform, you should have at least 930 MB of free space to unzip this file.
% n7 e) B$ L) p7 X! Q7 B! Q! {8 k/ A. d" R$ ?. a6 x3 t4 M. {' O9 p2 K8 y* {# I6 m$ e+ {( O
8 @, m  `. O" y; \
For the Windows XP64 platform, you should have at least 1.11 GB of free space to unzip this file.
7 D" u& J1 y& r$ ]# y" p& W( y( q& d7 {- H* g7 j
# Q- V) ]' a2 v# R; e
  U2 A( E6 o% ^3 A7 aVersion NX 7.0.0.9. must be installed before updating to version NX 7.0.0.9.mp01. Please be aware that these updated MP files will be superseded by the next maintenance release or maintenance pack installed on your machines.+ g! S6 S* f& P1 V; r0 m! r
0 W  T  L: S0 C; a! x
8 ~& B9 \( c5 u9 J7 s+ u4 o9 a; a1 ^) _
  B6 Q  J8 i, r6 t5 [% U% T- c
To use this update, change to the directory where you unzipped the nx-7.0.0.9.mp01.zip file, make sure the entire set of new MP files have execute access.
; s( X) g& w8 j* e2 `3 K" C3 t
% P, r8 F4 ?8 p0 c' X7 Q2 t% v. s/ p( X
2 C% S3 h0 X4 D. Y- V0 [; N: T  ~' j2 J" }# D8 Y) K
4 l/ N) L( g( Y+ w) r0 \, N( z6 i9 |- ~8 |0 }. q
Then do either one of the following:
$ L7 \; O  B( c8 y/ L/ P& o  ?& G' P2 t' s5 c+ m
1.  Run 'run_ugsupdate.exe'
" w! N- ?' T& U% k8 ^. p- Y" y9 l
3 T, x/ I: Q7 i
This will read the %UGII_BASE_DIR% from the Registry and apply the update to the NX 7 folder.
: i3 g( `( _" ^  x8 [7 P3 x5 Y8 ^& s* f% |/ Z  V" t) T( `
2.  OR, you may follow the instructions below to run ugs_update.bat directly.
, b: O5 o+ b6 u4 ?, Z! ]. Q& c
/ `: P8 \2 r$ E! `$ H1 `, i
Before running the script, please make sure the environment variable %UGII_BASE_DIR% is set to the base directory of the NX 7 release or set to the appropriate installed directory on your system. Then execute the 'ugs_update.bat' script.
: Y% b2 d9 p  d" U. ~
1 L7 E; ^2 e, {6 v0 P+ F3 y; G1 v. O: o2 a5 u& k- J" Q7 R! T$ a
For example:
; n8 K. N# l0 A  L+ X! I2 J! P+ D5 m6 F" Q) z5 u
& T9 r* X2 q) r2 e3 \1 N, E* H+ G/ K; L9 D2 ?2 x* M
         set UGII_BASE_DIR="C:\Program Files\UGS\NX 7.0"
9 n5 a; O1 @+ u) }3 n7 m0 x* C. R/ [1 V! Q1 X
% F2 e! |- N) p; n
3 s! \' W3 h& |cd NX70_mp01
6 x! P4 ]/ G/ o' _/ `; v  X$ t( E5 _         ugs_update.bat /v  v4 ~" K5 S5 M* D, M2 S9 g
. \  T5 Z; K% p7 g
$ F: J: m+ I0 ]' K' `* Y1 q: B4 A0 ^8 B7 e' S) w, L: WThe script supports a "/v" switch to turn on verbose messages while doing the file updates. The default operation of the script is non-verbose.
! P& |4 m' l4 D! f' \, u& }1 H3 p
3 k3 I% y9 }4 Z" X5 t: X& d5 I, Q0 |$ R" k8 YThe script supports a "/d" switch. This will turn off the script
! @8 s; R( n" D: @( h) ^3 x% {: S2 O/ _' M2 B! Wconfirmation prompts. Useful for running the update in a batch job.
' \3 k# |: N6 p( {: X9 Z2 {' @# |' J1 |7 Q. x# ?- m0 e" a5 U) U3 D
" ~  |5 A/ t1 DThe script also supports a "/p" switch. This will turn off the initial 4 ]: M( u& P) e" H7 B
8 u5 [0 Y5 F7 M4 ^2 `: f7 oconfirmation prompt but it will display the final 'done' prompt. This is useful for running the update in a batch job where a final prompt is desired.
) N9 n2 V' |) x
4 R( H0 i1 U" E% x3 `, I
! p2 l( i# |  M9 D# U
4 w4 q4 x4 [5 @: Q6 E9 A- e/ ~) w
, m$ i) b' U" ~0 l( r/ {- E6 o  y5 [! X  [7 l  m1 a
, B0 k2 o9 {9 P+ N7 E* C% K$ X6 M) I( w/ `* D1 y% g6 H, Q) {
1 B) U* Y$ l; U- c) i. T' D! a5 A1 w, D; V  q8 A
0 F, q6 I  m0 J4 ~& D. @3 Q# e- X, g& Y$ V& \- m, t& c7 B/ O7 v) l2 Q) z9 m! [- F
! P1 f4 G9 l% ?1 w- N# i, u* B& c. r, e! ]" t5 Q2 N  n1 r. n
; x) r! E: [$ ~; C, C
5 Q+ h' g2 y) Y9 ~" J; j, @! I
3 V5 Q7 Y! Q& Z# Z. y1 f$ }. T6 q4 g8 H
6 s/ z, `1 p! Z/ }0 v: {6 O) T9 }3 j+ S  ~( p
After the MP update has run successfully, the following identifying text will be written into the system log of every NX session:
9 U) z7 C. P( q3 I/ K% I4 @1 |% [$ e+ P2 D* k: T4 P
8 R  w) p( I# @+ V
+ o/ ^4 t4 J  S4 M
" G8 W4 f3 V3 a; q
6 R$ s- s& k  X- ]- b0 U" @: n. B$ X
"NX 7.0.0.9 MP1, 29Sep09. See Maintenance Pack letter for detailed list of fixes."
8 R$ x# `* ]9 y, C7 V+ A1 r
$ n* i% Z. x3 a, A0 L# q; `4 H4 }
% p; B1 O  t( p* L6 }' b7 S. m! j; \6 W2 j' y* k
If you have any issues with the installation or support of these fixes, please contact your local GTAC support group.
8 z8 j- ~. e; \+ R
( Z  [- P, |9 q. _6 q
" R1 J+ L- X2 L
7 b5 J* v! Q, f9 o
) l2 [0 \9 K/ u( Y# i, `$ I
3 [* g& E+ M8 a' a
Sincerely,
" K! \6 Y3 Q" b: t  M7 i9 _+ i6 N1 ?
  k) }& j7 r+ o& x7 t( q9 u: \$ l# ?3 ]! b- C7 U8 X
( q5 M! I$ V% F* P, F" X, h5 _
The Siemens NX Team
发表于 2009-10-15 13:50:03 | 显示全部楼层 来自: 中国上海
哇晒,就大补丁了,晕。下载地址哪啊?
发表于 2009-10-15 15:49:30 | 显示全部楼层 来自: 中国河南洛阳
升级还没下来,补丁就来了,UG也就是,为何不稳重一点,等没问题了再发布多好,刚刚发布升级就打补丁
发表于 2009-10-15 15:51:32 | 显示全部楼层 来自: 中国河南洛阳
上面也没说补丁点什么?
发表于 2009-10-15 15:55:34 | 显示全部楼层 来自: 中国福建三明
真是的,这么快发布新版本何用,6.0刚装就7.0了,几乎天天要升级软件了。
发表于 2009-10-15 16:46:18 | 显示全部楼层 来自: 中国广东深圳
日啊,7还没装就打补丁了.
发表于 2009-10-15 17:05:22 | 显示全部楼层 来自: 中国浙江温州
要命啊 这么快就出补丁了啊 :funk: :funk:
发表于 2009-10-15 17:10:04 | 显示全部楼层 来自: 中国广东深圳
要命啊 这么快就出补丁了啊
发表于 2009-10-15 20:42:31 | 显示全部楼层 来自: 中国黑龙江大庆
补丁地址????????????
发表于 2009-10-16 07:45:55 | 显示全部楼层 来自: 中国上海
NX7.0还刚出来,补丁就出来了,这么早??、
发表于 2009-10-16 08:59:14 | 显示全部楼层 来自: 中国江苏苏州
原帖由 fjp010922 于 2009-10-16 07:45 发表 http://www.3dportal.cn/discuz/images/common/back.gif
3 w; a7 a2 y2 A1 U! U" ?NX7.0还刚出来,补丁就出来了,这么早??、
; X2 n1 i. U% R
现在都是这样!!!!!!!
发表于 2009-10-16 12:24:35 | 显示全部楼层 来自: 中国陕西西安
晕死了% Z. s6 T7 W9 I
补丁是所有软件的一大特色
  I7 u2 x- H' w! w% M就像人避免不了得病一样
发表于 2009-10-16 12:41:11 | 显示全部楼层 来自: 中国四川宜宾
一起出,怎么还做补丁
发表于 2009-10-16 21:22:42 | 显示全部楼层 来自: 中国江苏淮安
NX7推出太冲忙了
发表于 2009-10-17 17:58:48 | 显示全部楼层 来自: 中国天津
这多是什么啊?怎么用?
发表于 2009-10-30 08:36:24 | 显示全部楼层 来自: 中国辽宁鞍山
看看!!!!!!!!!!!!!!!!!!
