查看: 3078|回复: 11
[已解决] 箱体的设计
发表于 2007-3-18 00:09:06 | 显示全部楼层 |阅读模式 来自: 中国重庆
有谁有箱体方面的设计资料* {/ h& k: o: s0 |8 q8 `
如强度、刚度等等的计算
8 P+ S( |9 ]# n关键是实用价值
发表于 2009-1-4 14:33:48 | 显示全部楼层 来自: 中国江苏无锡
我也很想要啊!!
发表于 2009-1-4 16:56:03 | 显示全部楼层 来自: 中国江西南昌
I don't know the box what you said used for what product. Because the box used for different product, you need to use different method to calculate. I advice you to use software such as pro/e、ug and catia this software all had the function to analysis.
% w- O/ s; Q* I5 G% u     but has a question, use this software, it is difficult to evalulate the results if it is ok, I think this need your experience. usussaly the result  of the intention is not smaller the material of your product.   Y& {  Y* J  B& \- w7 e; o: d1 L
     I usually to analysis by Pro/E, It is enough us to calculate. 3 E5 V+ Q% k2 I7 p6 m2 J
     Of course, you can use the software of Analys.
发表于 2009-1-7 20:49:56 | 显示全部楼层 来自: 美国
If you casn find some existing designs of gear boxs using the same situation, it will be very helpful and the most important.
+ N1 Y4 P# a) `8 Q3 ATo analysis gear box is very hard to get very accurate answer, and you still need some existing design to verify your analysis.
) N2 j' |" S) m9 }" p# uCould you tell me more detailed information?
3 [& e; z/ x+ `I may find some sample for you.
发表于 2009-1-9 15:27:15 | 显示全部楼层 来自: 中国辽宁抚顺
查找机械设计手册
 楼主| 发表于 2009-7-25 20:54:03 | 显示全部楼层 来自: 中国重庆
回复 2# 1q2w9o0p 的帖子
我想也只有靠软件来进行分析了# v" a( I2 o# B/ H! S
不知道COSMOSWorks的分析能力如何?
发表于 2009-7-30 10:34:49 | 显示全部楼层 来自: 中国江苏淮安
原帖由 DASHUIFA 于 2009-1-7 20:49 发表 http://www.3dportal.cn/discuz/images/common/back.gif7 l/ ^" T, d7 o* ~: k
3 e, V* L  j/ y# [To analysis gear box is very hard to get very accurate answer, and you st ...
have you found something about housing?
 楼主| 发表于 2009-8-17 20:28:05 | 显示全部楼层 来自: 中国重庆
不知道solidworks的simulation如何
发表于 2009-8-18 15:01:04 | 显示全部楼层 来自: 中国江苏淮安
楼上的哥们,你们说的都是典型的中国式英语,建议斑竹在本论坛开个英语专区,让大家练练。
 楼主| 发表于 2009-8-19 19:24:20 | 显示全部楼层 来自: 中国重庆
楼上的哥们的哥们
8 s0 A1 v( ~. P9 |solidworks是三维软件的名称
( f$ B5 S& H' s就好像TCL一样,请问中文如何说
发表于 2009-8-23 02:14:38 | 显示全部楼层 来自: 中国重庆
原帖由 minibench 于 2009-8-18 15:01 发表 http://www.3dportal.cn/discuz/images/common/back.gif: H3 x  p* R" d# w- X
) s# m) P" y. \% u: h1 u
+ I- X* F8 I! J来了2个老外!?
发表于 2009-8-25 06:50:37 | 显示全部楼层 来自: 中国北京
提示: 该帖被管理员或版主屏蔽
