; ============================= Start ucs.lsp ==============================! V) z1 E" o5 K8 ~
; this file is created to have quick access to ucs and view related commands J6 C9 n+ l7 O% s- Z7 Z; B9 l
; created by: Don Wen6 L+ p# {8 u$ T2 F8 a/ d. i! a! n
; on: August 12, 2009
) h# c. w( Y) _, U4 G; Usage: 5 @% t1 P% G M+ v' y
; Run appload to load ucs.lsp in AutoCAD
* s X E. n* _% Y! v8 w" C1 }: `; then all the following shortcuts can be used as: u3, uz, ub, v1, v2, vv1, vv2, etc.
/ d- [- N, _* D9 g) B9 {7 U/ u- g1 U5 W8 f9 \; u) y
;create shortcuts for ucs commands; W; v1 _ |: U" [3 H' _3 R( S
;u3() ---- UCS with 3 points5 v' v. E3 ~! E' Y& [
;uz() ---- UCS with Z-Axis"! I. v' G- @8 H, y
;ub() ---- UCS with Object"
3 L% j1 ?; ?7 z7 F8 P6 Q! g$ ]! T4 q+ p# K6 }. R% S/ Z: U
; create shortcuts for view commands
7 k8 v6 X6 a* V$ G3 I;v1() ---- view from top
3 l# \6 A2 G% }8 q! x: O;v11() ---- view from bottom
$ o. D; X$ g, |; w8 |2 ^/ R) v. D$ l7 Q- A6 q$ B) Z( @# A7 Y- o
;v2() ---- view from left
9 Y; B1 B+ G7 z1 i- Q% s1 g Y, k1 Y# x) {;v22() ---- view from right* |- e9 T; j o! r. s8 H
" L8 K% s3 H' O1 m
;v3() ---- view from front
1 Q' |6 L0 _5 V" R6 f: P;v33() ---- view from back
2 t, G1 a; ~, L' T& l/ v+ C" A( r: G1 K2 c
;vv1() ---- view from south west (SW) iso/ D5 v% a) ~! G$ X5 y3 R9 v
;vv2() ---- view from south east (SE) iso
8 e4 a- b8 H* n: X! [;vv3() ---- view from north east (NE) iso
. a, }( T i2 U: g;vv4() ---- view from north west (NW) iso
) P* ?3 `9 M; h: `4 z; h( ^3 D, K' @# ]( S0 { L: f% S6 k
2 g* P) m7 z! G+ k* d2 z$ \" ?* t1 a" s2 d) ?
(defun c:u3()
# N. u! p( h/ r, j0 [ ;UCS with 3 points7 ]+ V( ]+ N$ V* M: M
(prompt "UCS with 3 points")( ^/ L+ t G* i- ]; | ]0 q, x
(command "_ucs" "3")
) r6 C* e6 D$ x" p7 Q7 O5 k- \ (princ)5 }2 [2 A' h+ T
% G3 k- ?0 W2 G9 i( s1 e3 j7 u$ t: s7 Y, ^+ n
(defun c:uz()7 t) M% d" d4 ]4 k
;UCS with Z-Axis
- k8 p7 R6 g% f) _# ^" ], ^: ] (prompt "UCS with Z-Axis")% U# z. _* F( p% p3 f
(command "_ucs" "za")9 ?5 @7 x2 C: |, s4 Y
(princ)
/ W+ B" ^2 v, n) |)
# B3 {& Q. g1 U( a3 A, {* q' m% f* U/ r" f3 J
(defun c:ub()
' n D! Y. V8 L7 p: U ;UCS with Object4 T1 d3 b8 L- ]$ G; S, V: \" L
(prompt "UCS with Object")
$ Z3 F0 n2 u& F; M' `, A (command "_ucs" "ob")
- }! g4 _$ D9 M* o (princ)
) [, ]# z* {- n( M& p)
7 \8 H, e2 W, y6 L$ K6 `% e: j3 M z9 |5 m
- R* B1 s/ G% @8 D# ^6 Y(defun c:v1()
F3 d% O! k9 A" \; view from top
, a7 U; T3 y. _: b; r5 ^9 P4 O4 l4 W (prompt "^C^C_-view _top")
. g9 i* G7 D8 |" A) R3 Y (command "-view" "top")
7 |# ^ F- w7 ` (princ)
- q( q6 A. s6 e2 w: R$ h)
! t1 J& V: b& n. ?! i
) \7 R: x7 n! A! k. |. J& y, R( w+ {. f% O& ?
(defun c:v11(), \- B C' b8 {+ O* o% w6 \
; view from bottom
$ P) A* M, S3 R0 D8 {* U (prompt "^C^C_-view _bottom")
! n1 p; k9 B$ e3 t) r. t6 b0 ], [ (command "-view" "bottom")
# M3 b$ Z; R) A$ E (princ)
& I) M* n; W6 S6 I4 [)
. K6 U+ A5 _# J9 D4 U# ^# @) f" c+ F# j P, ?" U
(defun c:v2()6 W3 Q. x( t$ y; t
; view from left
& t" L5 ~4 o+ I! Z (prompt "^C^C_-view _left")
5 I+ q6 H b: Y( t0 L (command "-view" "left")2 K$ }0 x9 N2 y. s. A2 U
(princ)
; p; Z5 u$ a0 k) b" K)
( ~+ }! w/ K: E+ C1 O. U4 Q$ |! b& b& C9 b9 X; u
(defun c:v22()
4 ^4 `8 D; y% ?; view from right
* ?' s( x2 W1 S. O9 X9 m/ a: O l+ A (prompt "^C^C_-view _right")
/ g2 f! X1 d" ]& x5 I8 _# y (command "-view" "right")" Z& H" M$ J/ t1 d. r6 ]. ~; q7 ?7 u
(princ)% B) d! ~# I7 e6 R4 f7 _6 r, X
. R% F3 B0 N3 `) F N" ~: A/ d3 K7 F5 _
(defun c:v3()
- d: U: j$ C) w. Q+ d' }; view from front
2 e, J3 K6 \: {9 K, B (prompt "^C^C_-view _front")- n, k3 d8 V/ o6 ?+ E
(command "-view" "front")1 w2 a3 ?# M( v5 r
(princ)) h6 F3 y7 l; O- p
)! K# {" Y3 `# a. ~
. [; X/ U1 }% g' B5 Z
(defun c:v33()8 a. {; ]+ z n i1 U% f
; view from back7 ~! H! H7 V' Q9 ?
(prompt "^C^C_-view _back")
8 p5 }4 [$ `$ R: E) U4 P (command "-view" "back")
% y1 W l: s, Z$ I( M3 r (princ)
7 X) a2 E( c, d+ L8 m" a. |% {)
4 b0 C# J! T. k' F& f% E, v# \% g# k; X# \- a/ ?: `& d5 q6 `7 v' o
(defun c:vv1()0 n$ e. p* V9 x6 j
; view from south west iso6 q: S; f5 C' S3 _* ^( U
(prompt "view from south west iso")/ B9 D" y- K* }5 T" U$ @
(command "-view" "swiso")* L: O9 ?, j6 E; L. n
(princ)
) q4 M/ `& f# y: q+ m)
& A( H2 ?* d" l* v3 B9 b8 g9 L1 |6 o4 r4 V
(defun c:vv2()
1 d" ~+ O) U9 b3 N' T: u" I+ a; E; view from south east iso
/ P f( _ k8 `! Z) P: [5 m (prompt "view from south east iso")
9 C! E) t: ~$ i8 e+ z) J (command "-view" "seiso")
0 I# e: g v1 a% ^" i) u. [ (princ)
4 S8 f0 i& j7 d5 z" h)# ~1 W. \/ V( n+ J
a, ]. ]. d$ u& x T* C/ ?% B5 n
(defun c:vv3()
( P- Q- |% _ U/ L9 Y5 [" A; view from north east iso
" [; c& `, q+ N! ^9 o# x0 T. ~ (prompt "view from north east iso")! n3 m5 o( l/ P: `# E" m
(command "-view" "neiso")2 P s) F& K$ j/ U8 j* Y/ O
(princ)2 O& I! B" y% Y! C: u0 A4 R
)+ L2 s# k7 q( u- \3 ]2 ^4 @
2 ?$ E5 N8 K& l6 n
(defun c:vv4()
V8 y. J, Q8 d" s, w$ l; view from north west iso
7 m5 B3 q7 U/ l+ [+ e" E, [& a (prompt "; view from north west iso")
5 u) Z& X5 g2 ^* J (command "-view" "nwiso")" I8 \+ ^# X o4 n* H
(princ)# q+ q' g4 L7 T8 i; F6 d7 [4 E
)9 ^( R G3 @$ a- W- B( R
6 n4 g. j6 w* Z8 i5 g7 q
; ============================= End ucs.lsp ============================== |
