发表于 2009-6-7 19:30:40
来自: 中国江苏无锡
!-----------------DISPLAY FUNCTION--------------------------------: D# f$ w O8 L4 j' V
% D5 b2 Y$ n2 b. K
0 B) ]! r9 l- n- S
3 Y4 l3 ]3 k' B6 @, ?' a- W- r& i8 X+ m) Q3 d) H
0 N6 p( m1 A# C# B
# O* N+ g; Y, U, b0 h; f* }( X; @% z) A) ~* G5 i& N8 F
5 s o3 K; j" @& P8 D: y. Q, w
$ e& A; z7 X+ J6 ^! O' _+ m
+ B( r" Y* D& e& ~- \4 S
$ Y( _6 z8 n% a; U1 ^8 b/ ?
. |6 v( p! K- {
& x* h C- R Z7 W6 b' U" r# N, n" u" S* V; H
+ x" P7 V. r4 x: B4 R5 G m. a
. }9 m* N6 c; l3 n$ i) c
" @) y# ~- [' {5 M: B2 k
. @1 h% f* ]; X$ M7 `2 N* p! n7 b# K& I. A
5 h* P" z: [# e) Z# C3 j9 |) X, M- d, A) T
' w' A! ^/ T% R# g8 c
$ K/ x9 W* V! k- g) o* t. }5 Z+ u5 A( W0 j2 r
# _; d( |- ~4 k; {- Y6 Q
!--------MAKE DATUM PLANE (FRONT, TOP, RIGHT)--------------------
) n" T- x. W! e# l
* w/ }5 K. H/ t) T0 V5 u, y; v( n' ^* P
!--------MAKE FRONT, RIGHT, LEFT, TOP, BACK, VIEW----------------# a; K0 H3 P% S: m
: e$ I* {1 S5 |7 v9 ]; @2 E
; }; a5 c* }" p4 X$ d: A* U
!--------Setup layer-------------------------" s5 P/ [4 J1 o( o, c
: z) D# g3 r% ?4 c
; d! I% O" Y, E: X!--------ADD PART INFORMATION RELATION--------------------------
p7 i, h; k8 q6 w4 U/ F, T8 Q: N1 e" d+ r& m0 |7 ? `% [
: G M; v0 S; E) W5 S" g- x
!--------MISC. FUNCTION------------------------------------------9 o7 S# L; z+ R0 R: `
2 s6 L8 r7 G* U% j' _' b$ ~9 N6 C! M+ R% P
& w4 l& m! H9 n7 b1 c$ O S* d
!--------CREATE FEATURE FUNCTION / EDIT FEATURE FUNCTION---------
1 P, n7 n/ B# C+ l+ @
/ c3 ~+ N0 j/ q
& @- T2 O+ y; f( H+ c- }$ P- s, V/ M; c" h: [
) o( n( O9 M$ h8 E7 V6 D
0 u D! H$ p2 f; M$ G4 I4 Q8 N
# l p. A0 b" c; q6 g
' S& y& M! ~9 U/ g" g2 B4 A!--------SKETCHER FUNCTION--------------------------------------
, `, z' Y; T$ o" C( S6 Z+ B( N
& g* n6 F8 u- F, k; P N% T; r5 x2 A
!-----------DRAWING FUNCTION------------------------------------3 [' y( {9 K; g n1 w# ]
4 s+ c0 B. z# l# o/ `$ ^0 f' `
" T6 ~, k& D0 q0 p- A7 ]( H!------------INTERFACE FUNCTION________________________________' z$ _* t1 \& R1 V7 w! {
& B, M2 _5 k6 |1 l m# ^!------------Pro/ENGINEER SYSTEM SETUP--------------------------1 d0 {7 o( @1 i
pro_unit_length unit_mm: @5 Q2 N4 @9 G7 v0 n4 ]
pro_unit_mass unit_gram( ~% P( Z& g6 o* {( Y& z3 \
relation_file_editor protab
! O" \2 C/ D* t3 v1 T etolerance_standard iso5 [; ]$ [- I1 I5 V
tol_display yes, Q R6 X" Z/ P3 F( x8 V# Y
tol_mode nominal* R& {( o7 y$ D; f5 l/ f) i2 L# i
tolerance_class medium
& _. H9 |" M0 d1 F5 z3 Iallow_old_style_round YES
& |6 O9 X4 h6 x/ W5 `pro_symbol_dir E:\work_2005\color4 ? R! y u4 t& V
drawing_setup_file E:\work_2005\dtl\drawing.dtl
8 p, c ^- K, b6 ~& J( bdrawing_file_editor PROTAB
/ o0 R# I4 [! [3 P; d$ _1 t7 Fallow_move_attach_in_dtl_move yes
; S, r6 ^" Q7 P# cdefault_dec_places 5
9 E. r, ~" R2 k* j3 E( qmark_approximate_dims yes+ [3 i6 M9 U' i+ C8 `) G5 J8 T
plotter LASERJET4V* T6 A0 j3 \3 O, ]8 f# d
plotter_command windows_print_manager
0 k7 A% B, h: U: D0 n9 }$ utolerance_table_dir C:\Program Files\proeWildfire 4.0\tol_tables\iso
6 d# _# A9 g+ a' Nplot_names yes1 g7 z9 D' B7 j. O+ s4 Z
pen_table_file E:\work_2005\table# y5 p/ c" o# m% P7 R5 ^
tangent_edge_display dimmed
. s; X9 O2 R. g& ~; Ldatum_display NO
. M, E+ H7 [0 o% M9 G, }datum_point_display NO! L* n( o: R. H5 S0 Z8 V
display_coordinate_sys NO/ r$ ]* l7 U3 a+ Y
axis_display NO
8 d3 N& K/ P$ [; Q- tdisplay HIDDENINVIS/ ]% x6 E9 t1 W% R4 S/ `% {
bell no) B( O) N6 t/ W/ v
bitmap_size 250
7 S% p {- m7 K8 G) W8 y2 B8 ?( Bsave_bitmap NONE% p- j% z0 T! ~" I) D* D' d
button_name_in_help no( G! A, q- h& n, L1 ~* n- L
compress_output_files yes$ i4 ]% Z% z: p5 R
!MENUITEM_FONT -arial bold-14-400-0! W* Z3 w" g2 L/ v6 Y
graphics OPENGL
$ R3 M, E: h3 z' |todays_date_note_format %dd-%Mmm-%yyyy( V4 q# y' ?2 U: x d
min_animation_steps 0+ o& u; _, Z; S
iges_out_dwg_color YES' R: a* @2 J/ w z) i* p* H
pro_group_dir E:\work_2005\udf6 l3 c4 N* c* r. Y1 t6 O9 W2 c1 r
train_file_path E:\work_2005\temp\trail% J" i$ ^. f# D9 }; i5 m& p0 @
trail_delay NONE% u D1 A5 c4 Z) k- Q
trail_dir E:\work_2005\temp\trail6 M$ g# |/ r9 K' ]
pro_material_dir E:\work_2005\material8 o1 T2 Z+ Q. q" l* L
allow_anatomic_features yes
9 H, `4 [% ~9 u0 a3 xmsg_translation no* h2 [8 s7 h; k0 J6 b# G0 Y+ ^
template_designasm E:\work_2005\start-part\start-asm.asm.8; U9 {/ O- \6 r4 c
template_solidpart E:\work_2005\start-part\start.prt.20) ^7 q( V9 |: a- R, L
save_drawing_picture_file embed! ? J8 x0 ?8 s9 l% D. U- t' M
enable_absolute_accuracy yes( U+ H& l( ~' |" m
template_mfgmold D:\PTC\wildfire\templates\mmns_mfg_mold.mfg2 k, q0 S' i" M1 z" E3 P
dialog_translation no3 V0 g6 I' c+ S' F
menu_font arial,12,,) B& c+ f% F9 i0 \( w' M
pro_library_dir E:\work_20057 }" W) K% x( k) y$ z+ U
pro_catalog_dir C:\Program Files\proeWildfire 4.0\libs4 k( M1 F7 v: ?& B0 L8 I4 C1 s( j4 ^, x
show_all_mold_layout_buttons yes" {" _. I5 i! I3 M9 i( z1 @
allow_move_view_with_move yes* G' h8 W% h; H0 \
template_drawing E:\work_2005\start-part\drw_part.drw.6- J4 x0 P. c+ {! c
intf2d_out_enhanced_ents spline_and_hatch
/ ~/ c9 m- Q$ J$ R8 kuse_export_2d_dialog yes
0 u* |5 l; b4 w9 ~7 Ksystem_colors_file E:\work_2005\color\syscol.scl
) n$ N6 |, K; Z7 y3 ipro_font_dir C:\WINDOWS\Fonts
& n& K9 C9 I: l0 U! w$ D5 ~5 Rrename_drawings_with_object both
( H1 P" H; l6 B8 L& D8 gsystem_section_color (0,0,200)/ x/ @5 V P* l" h1 C6 E
sketcher_animated_modify yes# V4 E# g5 k' v- X
file_open_default_folder working_directory) K3 B$ ~) ~6 I0 g
mdl_tree_cfg_file E:\work_2005\config\tree.cfg& V& E2 j( W0 ?+ B6 z' {
autobuildz_enabled yes5 D% c! l) |1 N' B3 E
help_translation no
/ N; u- u% | A0 ~; v8 ^mass_property_calculate automatic
3 I9 L" G9 w7 @pro_format_dir E:\work_2005\format% R6 M# d6 {, q1 I
pro_colormap_path D:\0_objlib\color
) _3 p3 R/ M) Npro_colormap_path E:\work_2005\color
u0 A6 r! Z, c0 ~pro_colormap_path C:\Program Files\proeWildfire 4.0\text$ w# O. V9 `* z- C+ y7 x
open_window_maximized yes
4 [! N: w( B: b9 [7 d* edefault_ang_dec_places 2
2 u5 \6 T. }* q6 asketcher_dec_places 3
1 z7 c6 P" r2 W$ U' Sdefault_draw_scale 16 [9 U* w8 s/ h3 \% i9 k
dxf_out_scale_views yes
+ g: j9 t5 m0 ^ e2 l. v9 \/ a4 dstep_export_format ap214_cd& Z T6 ~ r: z) z K, F) x
sketcher_dim_of_revolve_axis yes
# E/ S& k' ^" h% vuse_8_plotter_pens yes
$ B# R' C; M7 _5 f) Ipro_note_dir E:\work_2005\notes
- D% z/ d9 i( o5 X3 d% h1 kpdf_use_pentable yes$ [$ E2 i8 _4 S9 \" ^2 u5 l' m
display_planes yes9 u" l8 R9 @" _# C7 X, d% R( S+ W d! s
display_points yes+ y, C; K' T+ D8 ~: d6 Y: z
display_coord_sys yes
* a) X# v' @! H/ |display_axes yes$ d) ]" I) b( z+ }9 b7 U) K
dim_inactive_components never# r3 x- N l/ g, r- G
topobus_enable yes |
