发表于 2009-2-10 09:17:13
来自: 中国香港
Copy Edit Ctrl+C Copy the selection and put it on the Clipboard
! @2 K7 D+ B9 c9 t X; Z# TNew Filing Ctrl+N Deletes the current drawing# ~6 [8 H* ]4 A; [ e6 N
Load ... Filing Ctrl+O Loads a file into OneSpace Designer Annotation.# j6 n, v; i. e1 t8 N& e/ i
Toggle Open Menus Miscellaneous Ctrl+Q Toggle Open Menus9 v5 V# s5 d. Q) N
Save ... Filing Ctrl+S Saves the data to a file.
3 Q5 V+ K, Z! KUndelete Delete Ctrl+U Undelete elements.
@7 B+ x G, T! rPaste Edit Ctrl+V Insert Clipboard contents! q) A( T$ `1 Z0 f% g: K' K
On Context Help F1 Help on current context
3 p4 A) V) h9 S) N7 ZGlobal Axes On/Off View F10 Toggles the global coordinate axes on/off in a given or selected viewport$ B/ D/ D; M; r& w
Full Screen View F11 Toggle Full Screen Mode on and off9 f0 O! J# n4 D$ Y E( ]+ U
Browser Bar View F12 Show or hide the browser dialog bar
+ T9 X+ m. I) f0 ^' g; d0 jSelect Select F2 Select objects
\% C8 f, X; T" z. d5 dSearch Next Miscellaneous F3 If Search command is active: Search next matching item. Else: Toggle the global coordinate axes on/off in a given or selected viewport.0 G! I ?( g' z/ Q8 a
Hidden On/Off Viewport F4 Toggles the hidden lines in Annotation views on / off.
3 g+ c/ m; N7 p$ ^' TGeo On/Off Viewport F5 Toggles the lines in Annotation viewport on / off.1 J2 a' \4 L' m ^/ D6 H# i
Task Bar View F9 Show or hide task bar
: t3 {$ e" r" aUpdate Colors On/Off Viewport Shift+F10 Toggles update colors in Annotation views on / off.
" K( V( D5 K* J- j2 e/ Q( ~8 {1 qDrawing Browser User Interface Shift+F12 Show drawing browser. i' w9 U- G9 g% j
Tangent On/Off Viewport Shift+F4 Toggles the tangent lines in Annotation viewport on / off. S, B8 n8 V2 E$ S
2D Geo On/Off Viewport Shift+F5 Toggles the manual created lines in Annotation viewport on / off.% ?; f# U, Y4 y9 o% f4 g7 P5 l. K7 i1 _
Vertex On/Off Viewport Shift+F7 Toggles the vertex in Annotation viewport on / off. |
