楼主 |
发表于 2008-11-9 00:43:31
来自: 中国广东深圳
To convert a thread dimension这个命令呢
To convert a thread dimension,+ I1 f8 U j5 w" v: _: }
- Click Modify Dims.
- Click Thread dim in the Convert section.
- The thread dimensions are displayed in Prefix, Main, and Postfix. You can accept or change their values and click Apply. 8 R1 y# L j" V1 u! ^! Z! V
After you click Apply, Annotation selects the next thread dimension and the dialog displays that thread dimension information. Annotation highlights old thread dimensions in blue and currently selected old thread dimensions in yellow. - Select from the following options:
Sheet: The sheet that contains the dimensions. Select a sheet from the drop-down list. After you click Apply and a dimension is located on another sheet, the dialog automatically selects the next sheet. Dimensions: The number of dimensions to be converted on a sheet. This field cannot be edited. Apply: Apply the new thread dimension information for Prefix, Main, and Posfix. Continue to click Apply until all thread dimensions are converted. - Skip: Skip a thread dimension and go on to the next one. This dimension will not be converted and will retain its old values.
Continue to click Apply until all thread dimensions are converted. - Click OK.
If the thread dimension conversion to a keyword was not successful, change the keyword:+ T9 y0 {4 D& B. q( `/ l
- Click Format in Prefix, Main, or Postfix. The Customized Thread Dimension table appears.
- Click Values. A list of thread dimensions appears.
- Click a dimension and click Apply.
