Dear Sir : B$ d6 |5 A+ j$ Z+ V & T" J9 K$ h% G# B1 c you can open data in C:\Program Files\Delcam\PowerMILLxxxx\sys\hci\popups\ 1 C+ j5 X) u2 p" d4 t) N# l% }% x explorer.ppm ==> you can edit left trees ! c9 L4 A( A$ G4 i' E, o/ u; v default.ppm ==> edit powermill's main screen0 w+ w. ]# S7 m+ }8 w1 ~
.....etc.9 n! M0 R( t U2 e
2 l, f! P0 O2 t' \5 b
for exsample 1 o3 N/ C5 D" Q5 V, F if i want click right button on main screen to select one command to open a vb form in d:\cuttoolpath.exe 8 g! ] k, Z2 E then i can open defalt.ppm B4 A4 W+ r! L
and insert some words like this.... " t! Y% G4 e8 X4 j- s- W) o: h/ J; `/ q
<BUTTON6 Z5 l0 K F5 |0 `, j8 a* Q: I/ D
command=' OLE FileAction "Open" "d:\cuttoolpath.exe"' ) y- i# \$ }5 N1 I2 \7 G' n, n label="open vbtools" 2 k, N; C X5 k6 D6 V/ [ /> & g5 T5 g8 w; j' s% w" X; a2 k4 f ) O. F- {- y8 _- t8 A then cuttoolpath.exe will work 5 o* I4 ]( }# `" s
原帖由 wei17722 于 2008-8-6 01:47 发表 http://www.3dportal.cn/discuz/images/common/back.gif$ Z; r8 s! p6 {0 z2 `( d/ t1 X9 [! Q( v
Dear Sir9 C. b8 X* s& r" B
8 G+ W" h3 G% ^; z% K$ c" h% V
you can open data in C:\Program Files\Delcam\PowerMILLxxxx\sys\hci\popups\- w$ i# ~, f O8 ]0 Z; p' K! O
explorer.ppm ==> you can edit left trees8 [3 N \9 b* F. `
default.ppm ==> edit powermill's main scr ...
