0 B' _" e3 @- F% L4 t5 _$ d0 Z you can open data in C:\Program Files\Delcam\PowerMILLxxxx\sys\hci\popups\ K; _. z6 ~7 C: G3 t8 t: E6 x explorer.ppm ==> you can edit left trees ! v! \4 J8 j2 {9 k; h6 x default.ppm ==> edit powermill's main screen & s- |# w; ?, R6 Y; p" Q3 N, W .....etc.2 t/ ]/ h5 ^( {, Q
6 O! F' `$ d2 N7 T) P8 s! z: f
for exsample# ~, ?# M$ A% ~9 u1 R
if i want click right button on main screen to select one command to open a vb form in d:\cuttoolpath.exe5 z" }. H. f/ T" U3 ~- K( A
then i can open defalt.ppm * ~3 r) V/ L8 D- {" n+ x% z3 ? and insert some words like this.... ' Q% [0 |* n) Z/ J) X- [ 2 o' s8 U0 H; y: n; H <BUTTON 3 P4 J2 Y3 g d$ h command=' OLE FileAction "Open" "d:\cuttoolpath.exe"'" K) i% O- R. d# g1 a* A
label="open vbtools" 8 Z# g' i" Z: _ /> $ M2 b1 o2 v3 o) x: w: k& m$ O4 Y2 @- H+ o! V4 L9 m
then cuttoolpath.exe will work$ ~: C3 ^6 o' Y( I" \1 u( L& t
原帖由 wei17722 于 2008-8-6 01:47 发表 http://www.3dportal.cn/discuz/images/common/back.gif7 D6 t4 j9 a# O& J% O E
Dear Sir% q% Z' P, l; ]
# ~9 P, Z' k s h' P
you can open data in C:\Program Files\Delcam\PowerMILLxxxx\sys\hci\popups\1 s2 ~3 L8 A9 \$ u% J
explorer.ppm ==> you can edit left trees ! z0 n; ~9 `- c' b default.ppm ==> edit powermill's main scr ...
