Dear Sir- U" Q8 C) G. V' X4 Y% ]0 }" b
^. j& x7 F! T( u9 m
you can open data in C:\Program Files\Delcam\PowerMILLxxxx\sys\hci\popups\2 N& {9 i, @+ D3 w0 Y
explorer.ppm ==> you can edit left trees% m) I9 m% w" C! M
default.ppm ==> edit powermill's main screen 0 X' v) z. k- X! ~. B7 _& P) E .....etc. 5 n8 R" X6 n. O( i( o& Y8 q' t5 W2 J: ~# d y- i( X
for exsample 0 \$ E0 Y/ R# v9 h, ^$ ]! S+ C if i want click right button on main screen to select one command to open a vb form in d:\cuttoolpath.exe1 t2 d9 ^' ?: w+ U
then i can open defalt.ppm , g& o+ ]7 ]' ?% n/ i1 q, K: y. O and insert some words like this.... + x7 Q z7 y; U# N/ E ' z7 ~. U& z. g- Z- D: x <BUTTON7 f8 n c* z6 L
command=' OLE FileAction "Open" "d:\cuttoolpath.exe"': ^% N3 |8 N# ]1 Y9 _9 w3 ]* U
label="open vbtools"3 `; a7 v1 z% O% f& C+ g! Y
/>9 Y( r* g+ y: f
$ x5 N3 J+ _5 C/ A# J0 X# J
then cuttoolpath.exe will work: m2 }2 x y) {- K
原帖由 wei17722 于 2008-8-6 01:47 发表 http://www.3dportal.cn/discuz/images/common/back.gif9 n& ~: Q$ ^; P3 Q! ]* i. d$ w
Dear Sir. h z0 H( ]% A2 J7 M
& |' Y7 r% K2 L2 l
you can open data in C:\Program Files\Delcam\PowerMILLxxxx\sys\hci\popups\/ ^" T1 A- _, L8 z, k
explorer.ppm ==> you can edit left trees - J- m" g; q8 P default.ppm ==> edit powermill's main scr ...
: |1 w5 S$ k8 q% K. [' F
* F, U0 i# f3 }' Z
) ?7 F; z9 R4 }/ H G+ R + \$ |" }$ j( ^1 c9 \# A+ Y) h+ F K% b+ F
7 o. C% T' h! H+ Z, U试了下,好象不支持中文注释啊2 k" O$ ^2 F$ W! \8 J0 ] d
% d0 ~% ^$ ]$ o( u0 ~6 R
以后回帖请写中文!!!
