发表于 2008-1-26 08:51:20
来自: 中国广东中山
网上找到的,供大家参考; G9 L( K9 A% H2 _0 t* v
solid_user 2007-12-22 20:13 7 [& z' w! S/ U/ a
To all who have a problems with this crack!5 t2 N9 D4 c$ d" d3 k6 t
, f$ h6 [7 K5 Y1 C
This crack needs a file "ftilicense.cfg" to be present in <BlankWowks program directory>% b+ o, {$ D/ w
5 e/ }7 u4 t) e9 \- G2 Q& J; iso
/ F; k1 M1 C; k' @7 @ P! ^8 r9 D0 [0 M W
Fist way to Install
7 f! a6 }3 |% h. Y* q, g* G
" B* {( G4 r2 h0 G2 r( d1) Run BlankWorks v3.0 Setup and select "Node locked license"
; f9 T8 ]& q! q% {! g" v: t7 i2) Click "OK" and "Next" in any Setup windows (when aked for lisense file path jast click "OK" too!).% J8 J, {7 O( ^- f, Z( e
3) Replace original files in <BlankWowks program directory> with cracked ones1 h# S/ g1 z. G: ^& R
That is all
. Y m/ j" V% M$ C5 p1 y% s3 x
& _. Y# l- A% u) n( ZSecond way (If you setup not Node Locked License and you have no "ftilicense.cfg" in <BlankWowks program directory>)
4 `/ t4 t v- R7 S; g2 z4 T/ `, g; E7 _
1) Create an empty text-file "ftilicense.txt" 2 C: t1 T9 ~" y1 y$ h( \& K
2) Rename it to "ftilicense.cfg" and put it into <BlankWowks program directory>5 |5 }. J- F, ~; N6 R( E; ]# V- M& |3 C
3) Replace original files in <BlankWowks program directory> with cracked ones |
