发表于 2007-11-22 11:18:22
来自: 中国广东珠海
thanks for solid-user!~ 但是MICRO在进行并行运算时好像有点小问题!~' R4 R: _3 F8 n' C( R: a
+ \+ j; k5 V U" w; Ainformation:
5 K" Z! k T8 {' B; I0 a& Z2 oE:\procast\abb7>set MPI_ROOT=d:\PROGRA~1\ESISOF~1\ProCAST\2007.0\HPMPI
4 N: W3 ^% {2 eE:\procast\abb7>"d:\PROGRA~1\ESISOF~1\ProCAST\2007.0\bin\datacast.exe" abb7
9 g0 ^, N" \( @4 D7 t' NDataCAST Version 2007.0, Compiled on May 28 2007 at 14:46:49( z8 Z+ Z) L/ j; H9 m1 d
Warning -- Velocity BC Node 6423 is in a non-fluid region.
$ e! M' T& t% e3 E# l* _; Y% T& t' HWarning -- Velocity BC Node 6627 is in a non-fluid region.% c# @5 x1 W6 [1 {8 i( b
Warning -- Velocity BC Node 12954 is in a non-fluid region. T3 I/ b u$ j+ i6 s+ A" R" O, y7 _
E:\procast\abb7>"d:\PROGRA~1\ESISOF~1\ProCAST\2007.0\HPMPI\bin\mpirun" -np 2 -5 l$ X$ f: d, q. _$ }. k3 Q: K) E
e LD_LIBRARY_PATH="d:\PROGRA~1\ESISOF~1\ProCAST\2007.0\HPMPI\bin" -e MPI_WORKDIR
2 D+ Y# U, q8 `, G/ U3 ?9 I="E:\procast\abb7" -e ProCAST20070="d:\PROGRA~1\ESISOF~1\ProCAST\2007.0" "d:\P
1 c* `9 F7 F+ lROGRA~1\ESISOF~1\ProCAST\2007.0\bin\procastDMP.exe" abb7
: i, o5 h( b% A( l" P' tWARNING: No cached password or password provided.3 _5 N+ d8 t' l# M6 H' u
use '-pass' or '-cache' to provide password
% z# C. M5 T, dHP-MPI licensed for ESI-Group.
- T% n) S- }9 M0 iProCAST Version 2007.0, Parallel, Compiled on Jul 4 2007 at 13:01:29* O. I2 F7 L' {
Copyright ESI Group (France) 2004-20072 I+ E2 j% |/ `. _
Executable adapted for HP-MPI!
1 r5 h" J' j" q! VPhase Diagram Calculation Code" Y. t. t' A5 t Q
Original code by H.L. Lukas, MPI, Stuttgart, Germany* L c. k5 Q/ c+ X9 z( g! k |
Modifications by U.R. Kattner, NIST, Gaithersburg, USA* C7 e9 y/ _& j4 b' m
T = 535.000000: Calculation of enthalpy failed for phase AL3TI# s8 A. P. x* |& Y
optimal communication in use.
, M6 U0 h- U/ NXYZ Cut: 9862 Balance: 1.000 [7536 15071 2]
+ F# A1 Q* o5 X! SFinal 2-way CUT: 1685 Balance: 1.011 avg: 1.0117 L5 J8 v4 n$ W
XYZ Cut: 6030 Balance: 1.000 [2615 5230 2]
/ Y9 s3 y( s# _8 U! X* mPartitioning a graph of size 5230 serially1 e0 K: G5 L5 o) R4 k
Final 2-way CUT: 535 Balance: 1.000 avg: 1.000 |
