发表于 2007-11-19 09:05:56
来自: 中国北京
接上面的
PACKAGE MFG uglmd 21.000 BEAA3ADCFF3A COMPONENTS="MFG_assemblies \+ N7 P0 d3 h6 O/ }+ D$ r
MFG_cam_base MFG_cavity_milling MFG_drafting MFG_dxf_to_ug \
: x: V6 m& @6 t0 ]1 | MFG_dxfdwg MFG_features_modeling MFG_fix_axis_surf_mill \
0 Y5 o' p% z2 }( Y MFG_flow_cut MFG_free_form_modeling MFG_gateway \
3 O n9 |& I! u MFG_graphical_tool_path MFG_grip_execute MFG_iges \+ k: g& E# v) L3 m6 l% o1 f
MFG_nc_external_program MFG_planar_milling \8 X9 e) ]4 V* G6 Q1 M4 }
MFG_sequential_milling MFG_shop_doc MFG_solid_modeling \9 f1 p y I U) ]
MFG_std_ug_library MFG_step_ap203 MFG_step_ap214 \+ F% j' \7 I1 G
MFG_surface_milling MFG_tol_cavity_milling MFG_ufunc_execute \
( v* u- ^4 N# O- k: M0 i MFG_ug_post_exe MFG_ug_to_dxf MFG_ug_to_vericut \
& L" z; ?) h! w( T MFG_ug_visualize MFG_var_axis_surf_mill" OPTIONS=SUITE ck=502 u+ N! D' F; @6 L' {0 X D: b: {" s
INCREMENT ASCFEA uglmd 21.000 permanent 99 09F8739DF74B SUPERSEDE \
( Y) s6 V( U2 i4 q9 a6 F DUP_GROUP=UHD user_info="Engineering NASTRAN Connect" \
' S( L8 t& Q/ z% g s) s7 I ISSUED=10-aug-2002 ck=123
) v% L% o; {! cPACKAGE ASCFEA uglmd 21.000 491125667FDE \# o1 i$ c% E1 k* Q7 ]
COMPONENTS="ASCFEA_auto_solid_meshing ASCFEA_features_modeling \5 V* p. [& |9 x0 [
ASCFEA_free_form_modeling ASCFEA_gateway ASCFEA_gfem_ansys \
2 r, R% h, u E% E: o ASCFEA_gfem_nastran ASCFEA_solid_modeling ASCFEA_ug_scenario" \+ Q4 i' h4 v* a' s* c
OPTIONS=SUITE ck=34
$ u: M# k0 A# `INCREMENT INDDES uglmd 21.000 permanent 99 A23626FFEDDB SUPERSEDE \
& I+ {, {9 q. ?9 g9 c& q7 ` DUP_GROUP=UHD user_info="Industrial Design Solution" \
7 M5 h- c( y2 @ B* z/ E$ c m ISSUED=10-aug-2002 ck=94 L$ _( ^9 t5 J( H0 E
PACKAGE INDDES uglmd 21.000 4B942093CA3D COMPONENTS="INDDES_drafting \
- x" j7 G8 D* [" H; `% p INDDES_dxf_to_ug INDDES_dxfdwg INDDES_features_modeling \
8 }' A# L* U* z( Q) V2 Y# V INDDES_free_form_modeling INDDES_gateway INDDES_iges \
* }" O8 }. ^* U* q% }* c( `) N INDDES_sla_3d_systems INDDES_solid_modeling \/ F. D) ~" o8 J" L7 M# c5 a1 A
INDDES_studio_visualize INDDES_ug_photo INDDES_ug_to_dxf" \
* q+ p$ `8 p6 ?2 y9 G4 p OPTIONS=SUITE ck=126
* Q+ y% A. a( ZINCREMENT ASCFEAP uglmd 21.000 permanent 99 B56FFCDE9B79 SUPERSEDE \
# s7 T; P$ h' q9 y5 G* t% h* N DUP_GROUP=UHD user_info="Engineering Solver Bundle" \
; V; x: P1 f9 V, K8 H t6 a. V ISSUED=10-aug-2002 ck=168
. {4 u d5 V* e l+ X) EPACKAGE ASCFEAP uglmd 21.000 554DE5D8F472 \2 Y, ?( R) }* D, R4 H: n+ [2 G
COMPONENTS="ASCFEAP_auto_solid_meshing \0 [* z6 T( J9 ?
ASCFEAP_features_modeling ASCFEAP_free_form_modeling \) P3 o- K9 R$ p0 H$ }+ ?5 D
ASCFEAP_gateway ASCFEAP_gfem_nastran ASCFEAP_pfea_static_modal \+ l4 ~: ]% X+ B* R3 T
ASCFEAP_solid_modeling ASCFEAP_ug_scenario \5 k; r! I7 F6 ?) E& E. }" @$ ^, {, y
ASCFEAP_ug_struct_pe_solver" OPTIONS=SUITE ck=126
a% u7 F1 t4 g9 x$ M+ \" A/ hINCREMENT ENGANS uglmd 21.000 permanent 99 D9D9E79C84D3 SUPERSEDE \
$ W" S; U8 B9 Y' |. Z) y k DUP_GROUP=UHD user_info="Engineering ANSYS Connect" \
, F/ v# D0 X; x# D, O ISSUED=10-aug-2002 ck=108, ]8 E7 U* ~ I! ~0 E* N% {$ J
PACKAGE ENGANS uglmd 21.000 80C7EAC51FF6 \
. {7 Q% U" d" ]/ M. B: j6 K COMPONENTS="ENGANS_ansys_meshers ENGANS_features_modeling \2 D/ h; n# C2 c; n3 ~* |( Z& p
ENGANS_free_form_modeling ENGANS_gateway ENGANS_gfem_ansys \+ h# _3 k/ a- L0 q u! ?
ENGANS_solid_modeling ENGANS_ug_scenario" OPTIONS=SUITE ck=1190 [) {1 }% r6 F2 h! G
INCREMENT IM uglmd 21.000 permanent 99 786E149EEA6F SUPERSEDE \
+ r+ s" D' ]+ R! E5 @ DUP_GROUP=UHD ISSUED=01-aug-2002 ck=128
2 Y: H6 z, f: W' \, h& i$ e( T! DPACKAGE IM uglmd 21.000 B0378C088B7A COMPONENTS="gateway iman_1 \$ [% {9 f8 D! s
iman_10 iman_1st iman_1st iman_2 iman_3 iman_4 iman_5 iman_6 \# K* ^& ]* Q& z- a3 ?0 N
iman_7 iman_8 iman_9 iman_acm iman_adv_cm_client \
: g# m1 j1 M( Y' A6 x5 C ]7 s iman_adv_cm_server iman_adv_eintegrator iman_altris \
: K4 l1 S- U& W; H, z iman_author iman_autocad iman_browser iman_cam_mgr_ext \
+ j X2 a# h4 m$ n9 K, `. r+ P iman_catia iman_consumer iman_design_context \- g q8 {* w. k" P7 R: O
iman_distributed_svr iman_distributed_usr iman_dm_srvr_ext \
3 F* I3 s4 V6 e+ c2 U iman_document iman_documentun iman_dominodoc iman_dtk \: x* r& L& X. t; Y
iman_erp_interface iman_fcad_intf iman_hetero iman_hookup_api \2 J1 o' _# C% o& T2 a" H8 I( z9 l
iman_ideas iman_image_services iman_inclass_srv \
' W- `' u" q9 s+ W' Z! b/ E3 K iman_inclass_usr iman_iview iman_lotus iman_mac iman_markup_pc \8 j0 p# I7 X% _% O. c6 ^& z
iman_markup_workstn iman_mentor_graphics iman_myraid iman_nth \! w4 h; n2 f' T) R& ~
iman_oracle iman_p3r_acc_user iman_pc iman_pro \
, X; O. U6 |0 f3 ` iman_proc_plnr_user iman_proe iman_proe_manager \
, l" T/ [+ ?1 o# e3 J3 g iman_propdm_dmu iman_psm iman_pv_moratorium iman_pv_viewer_adv \0 c# J6 \, U$ l1 w1 T
iman_pv_viewer_base iman_pv_viewer_pro iman_qpl_srvr \
* g' ^- W+ Y* i% t0 f iman_qpl_usr iman_rdv_client iman_rdv_server iman_report_user \
8 q+ U; L& M0 M. |/ g iman_report_writer iman_res_mgr_user iman_reviewer iman_rtk \" R9 _' w" }4 N/ Y) D6 O2 f$ `
iman_sap iman_server iman_solidedge iman_solidedge_mgr \
! [0 u+ ?6 R/ D, m$ t; y2 { iman_solidworks iman_solidworks_mgr iman_step iman_step_ap203 \& d" P+ T. h0 i8 |, s9 Z$ [
iman_step_ap214 iman_ug iman_ug_manager iman_web_author \
- H- S4 d& c1 G4 ]5 Q iman_web_server iman_webdav_server iman_webserver \* @! r' p5 Y W0 l4 D. k6 N( L9 F. B& }
iman_workflow iman_workstation iman_wpp_intf iman_wpp_user \8 |4 J- ] d+ F5 G6 O7 P, x* T
iman_x_terminal pv_portal_mkp pv_portal_std \- G/ b: f/ T2 \8 n. |: ~1 R
pv_ugdatagenerator" ck=99
e, C' \) y4 y) c! XINCREMENT IM2 uglmd 21.000 permanent 99 931715D525D8 SUPERSEDE \" }4 Q' }, R0 l
DUP_GROUP=UHD ISSUED=01-aug-2002 ck=80$ J- Q* }) n3 q! g
PACKAGE IM2 uglmd 21.000 1C7D81518365 COMPONENTS="iman_11 iman_12 \
& _: u, @1 N3 l# L w. X9 Z iman_13 iman_14 iman_15 iman_16 iman_17 iman_18 iman_19 \, a' b% F+ }) x2 [9 s5 }7 r
iman_20 iman_21 iman_22 iman_23 iman_24 iman_25 iman_26 \# y& k: y5 B4 s
iman_27 iman_28 iman_29 iman_30 iman_cc_editor_usr \5 M. o$ D1 p8 J/ f0 @
iman_emp_connect iman_inclass_svr iman_mfg_struct_vwr \5 A# t6 y6 ~2 m6 [
iman_mfg_struct_vwr iman_myriad iman_pro_intralnk_dmu \
' D! i" S" P' B3 x0 A8 J2 n iman_prointralnk_dmu iman_rdv_client iman_rdv_server \
" d- H/ F5 ~ V+ F: |" Z* [ iman_tcm_xsrv_ext" ck=85& s( R8 ]& O2 {* P, K% v
INCREMENT UGNX1 uglmd 21.000 permanent 99 D047F202F169 SUPERSEDE \
! E4 z) t& F4 D% k$ X$ O DUP_GROUP=UHD ISSUED=10-aug-2002 ck=148
4 A' |* R0 |* N5 q9 n+ h% M- U9 sPACKAGE UGNX1 uglmd 21.000 2803C4B8A41E COMPONENTS="gateway \+ F7 t$ T* Q/ F1 ^1 w" k7 k v
3d_to_2d_flattener adv_assemblies adv_sheet_metal_dsgn \
9 |/ Q6 F- y' S! s adv_turning adv_ug_library ansys_meshers assemblies \
6 |8 ]( I: r6 S8 N auto_solid_meshing c4x cam_base cam_dialogs cam_uif \
7 n6 k2 q" p" O3 T. R! F( R cavity_milling composites curved_flat_pattern \
9 J) x: D1 q( v: Q$ W) w6 { cutting_optimization design_optimization die_face_design \
% Z0 v6 o% [/ A" g1 s' q' ~( f direct_geometry dmu_partitioned_hlr drafting drive_curve_lathe \+ q8 A* q' f9 j) W W8 L
dxf_to_ug facing_milling features_modeling fix_axis_surf_mill \
3 _- M& P! j4 l* K: |% P5 B; { flat_patterns flow_cut foreign_geometry free_form_modeling \
8 C5 W. w8 @# p. q+ u1 f genius_4000_access genius_4000_api genius_4000_base \
* h* h5 X! ~) g( ` genius_4000_fixture genius_4000_fsm genius_4000_nc_prog \- v) M" B$ U4 n8 d/ p3 H
genius_4000_stock genius_4000_tool geometric_tol gfem \2 G* t8 n. V) c# q0 W# a
gfem_ansys gfem_nastran gfem_postprocessor gm_proprietary \
2 Z, p3 M8 z O2 {, m+ n graphical_tool_path grip_development grip_execute icad \
8 |7 e% s f9 N# N" k; H icad_interface iges moldiq motion_dyn motion_kin \
! Z1 N+ j" d3 x. H+ N routing_isogen shop_doc std_ug_library studio_render \
- V5 D* ` U2 z2 q# ~4 K/ l5 C$ L% ~8 L thread_milling ug_pv_interop ug_schematics interleaf_if \) e$ y( U! ]+ s6 f! @: X3 d
jama_customization kanji_characters lathe mechanisms \
f4 u5 |4 M9 x/ Q: k' } mesh_list_element milling_express mold_flow moldflow_ppa \
6 L0 J. J: i4 l ?$ \. d moldware_design moldware_integrated moldware_manufacture \
( @" {+ b' i; y5 |- V* i# U2 b: S& R multi_part_gridding nc_external_program nurb_output_enabler \
1 J' N- _% k; E; g) x* R pfea_static_modal planar_milling punch_optimization punchpress \: q7 Y4 @# j8 j, _6 @8 Y3 l
punchpress_optimize routing_base routing_conduit \. T6 \* D7 F2 b9 y, |4 u F
routing_flex_hose routing_hvac routing_piping routing_raceway \; h5 r& Y4 P% y; h
routing_steelwork routing_tubing routing_wiring \
- r8 A# X( l3 M& N9 G/ I# n sequential_milling sheet_metal sheet_metal_design \1 g3 D, x- O) P7 N6 q
sheet_metal_die_eng sheet_metal_fab sheet_metal_nesting \% T: Z- S( K/ ~
size_opt" ck=88
2 |3 B7 Q* q: |( N' E& bINCREMENT UGNX2 uglmd 21.000 permanent 99 0E1D7F19F3E1 SUPERSEDE \" l7 v6 f& J% a7 O/ V0 P7 h
DUP_GROUP=UHD ISSUED=10-aug-2002 ck=110
0 S V3 Q' H% dPACKAGE UGNX2 uglmd 21.000 3EAB4F6256E5 COMPONENTS="gateway ds_studio \
, O U, I1 U2 g+ W# V adv_routing design_studio die_engineering genius_4000_machine \
2 M- v: L; C- b2 Z1 j! S) n9 A metris pv_ugdatagenerator shapescan shop_doc shops_design \
; q' M* X# y" p shops_die_mold shops_ff shops_shell simulation single_geometry \7 L* ?: `: j( x; M
sla_3d_systems solid_modeling step_ap203 step_ap214 \
. l+ c& F4 R+ W1 l# U# F studio_analyze studio_free_form studio_visualize \
, v K4 R* q J* [: e; H* w surface_milling swarf_cutting tol_cavity_milling \
$ z( d' y) P1 N' [8 V% w ufunc_development ufunc_execute ug_data_pipeline ug_epak \
# q3 b+ S, \* G% v ug_fast ug_fly_through ug_library_fixtures ug_mold_design \
$ T. x" i1 O, {' v* l1 `# m ug_photo ug_post_adv_bldr ug_post_exe ug_post_lathe \- L9 B& j4 X9 ~7 S3 ^7 I% w- c
ug_post_mill ug_process_aid ug_pv_interop ug_reality \
+ n, x. ]% r. V1 t, A0 C ug_scenario ug_shapescan ug_to_dxf ug_to_vericut ug_turning \* \' k2 h4 o$ Q+ {% Z7 t
ug_visualize ug_web_express ugmx_api_development \9 t& Y) j1 X0 y2 N% ~+ V: `
ugmx_api_runtime ugmx_drafting ugmx_dxf ugmx_iges \" ~9 O/ @7 G; s( [) M6 O4 ^
ugmx_para_design ugopen_menuscript ugopen_plus_plus ugremarx \8 b d: g6 a- s* I( k* J
ugweld ui_styler unc_lathe_simulation unc_mill_simulation \, ~; z: N; N& p* r7 l8 V
usr_defined_features var_axis_surf_mill vcheck \& \6 k& S6 b$ L6 D% v# l3 W
vda_4955_checker vda_fs_translator visual wave \
! \8 q; U/ _$ c2 t G wire_edm_machining wiring_harness scstrp adv_gear_wizard \0 Q, [/ |! `3 S& G! I/ W
cam_facets casting_wizard cattoug composites dxfdwg \
6 o1 D5 L: Q' A' i$ B3 x2 V gear_wizard proc_pt_asst proetoug prog_die_wizard prt_cfg_asst \6 ?$ r& E# t+ h& m# U8 E
ug_aml ug_body_design ug_checkmate ug_collaborate \
# {% ~- E1 f4 }+ m8 \1 f4 V ug_comp_flattener ug_comp_pipeline ug_composites ug_die_design \
& r, V, Q( u* N9 L4 Q ug_emboss ug_expr_manager ug_feature_rec ug_healing \
( U; N* j0 V4 y. l( g ug_holemaking ug_ipw ug_kf_airfoil_band ug_kf_author \
/ Y7 N7 S9 {! _5 \0 a ug_kf_checker ug_kf_execute ug_kf_feature ug_kf_interop \
: B$ A: m& a0 R* x ug_kf_new_geom ug_kf_update ug_kp ug_mfg_advisor ug_opt_wizard \' X3 K( C( M; B. P+ w
ug_packs ug_post_kinematics ug_quick_stack ug_smart_models \
$ Y, P, O& F' e# ] ug_strength_wizard ug_struct_pe_solver ug_var_axis_profile \5 ?# L9 _. c* F; m# @
ug_vki_meshers" ck=135 |
