楼主: solid_user
[分享] ProCAST2006 R1 crack (by gellmaR)
 楼主| 发表于 2007-10-11 18:22:54 | 显示全部楼层 来自: LAN
原帖由 chinalaowang 于 2007-10-11 09:08 发表 http://www.3dportal.cn/discuz/images/common/back.gif
2 D* {% V. W  G! B- G$ E0 T' F9 c, ~如果能将magmaCrack了就ok啦!
4 X7 }( M9 f/ r$ ]( e4 c0 }  _' t1 uI do not use MagmaSoft and have no got Installation of that Apps...
发表于 2007-10-12 22:54:45 | 显示全部楼层 来自: 中国上海
并行的有人试了么?我试了好像还是没什么效果,出来的那个cmd与提供的不一样啊
发表于 2007-10-13 14:35:50 | 显示全部楼层 来自: 中国浙江宁波
谢谢!我可以上传MAGMASOFT4.2 ,不知能否Crack呀!
发表于 2007-10-13 15:45:25 | 显示全部楼层 来自: 中国湖北荆州
ProCAST2006 R1 crack (by gellmaR) » 发表回复
MAGMASOFT4.2FTP上早就有了,只不过到现在也没人能弄开
发表于 2007-10-16 11:58:54 | 显示全部楼层 来自: 中国广东广州
dear solid user,- c5 r( j1 m# D3 l; N: x* u8 O
i really appreciate your great work for the crack. while  the database which used in microstructures do not included in this license and i really need it to sovle my problem. i am expecting for your new crack on it, thanks' }+ ?2 g! e3 U5 v/ K7 F
" Q+ L& _( O% k% V( t* c+ g  q% |+ k) \* T; ^6 }' ?
 楼主| 发表于 2007-10-16 22:32:34 | 显示全部楼层 来自: LAN
原帖由 jojo1983 于 2007-10-16 11:58 发表 http://www.3dportal.cn/discuz/images/common/back.gif
3 `* ^3 p5 k/ K) a4 wdear solid user,
  p2 D& _8 F1 E; o7 H6 |# ti really appreciate your great work for the crack. while  the database which used in microstructures do not included in this license and i really need it to sovle my problem. i am ex ...
' \0 [; C' I: A1 h8 d$ k
I can try to fix but I need a simple test file (please make a folder with all needed files: geometry, materials, initial and other date...) so I can run your study in ProCAST module and see the problem!; N* ^  [1 P8 q4 |: z$ X3 T6 ]
Check your PM for my e-mail adress
发表于 2007-10-17 21:05:14 | 显示全部楼层 来自: 中国广东珠海
mirc test file
tcast.rar
348.93 KB, 下载次数: 21
发表于 2007-10-17 22:37:24 | 显示全部楼层 来自: 中国江苏南通
good 谢谢各位楼主,我也遇到40楼同样的问题,望楼主solid-user早日Crack
6 z3 ]5 q1 U6 j+ {: T$ S+ p0 B1 s* |+ e! P
[ 本帖最后由 xfzcgzs 于 2007-10-18 06:32 编辑 ]
发表于 2007-10-22 19:20:17 | 显示全部楼层 来自: 中国浙江宁波
确实是高人啊!& B9 s2 o2 d# s( F( [
如果能将magmaCrack了就ok啦
 楼主| 发表于 2007-10-29 05:35:07 | 显示全部楼层 来自: 俄罗斯
jojo1983 ,  zqlong and all..) B- D+ x* c2 a9 }" j4 u
Now MICRO calculation is fixed!! F& t. {1 H2 B4 \# z
Here is a additional patch... Use this patches for already cracked ( not original ) "pro_icc.exe" and "pro_vcc.exe"!: I- g6 C9 S# C. c- |, a
$ M" [, _! y: P. p& j) IGood luck!
procast2006.1_micro_crk_gellmaR.rar
9.91 KB, 下载次数: 54
发表于 2007-10-29 14:49:45 | 显示全部楼层 来自: 中国江苏南通
请教一个问题我已经把文件复制到bin里怎么还出现这个图形,望帮助?谢谢!
发表于 2007-10-29 14:53:37 | 显示全部楼层 来自: 中国广东广州
dear solid_user ,1 X# F* M, l( x$ N1 Y, H
        I'm sorry to trouble you,  I fall into a new trouble that the procast can not work after I followed the readme file ,put the patches into <ProCAST2006.1 program directory>\bin and run them, the cmd information is " Unable to open formatted input file p.dat"   . would you please help us one more time ,thank you very very much! 111.jpg
发表于 2007-10-29 14:56:10 | 显示全部楼层 来自: 中国广东广州
xfzcgzs 兄弟,那两个文件复制了还要在里面运行的
) |* ]" E# ]& B! X
6 p/ r$ F) @" \5 A0 v但是运行后 procast计算时却打不开p.dat了, 不知道你会不会遇到这个问题啊
 楼主| 发表于 2007-10-29 17:40:45 | 显示全部楼层 来自: LAN
原帖由 xfzcgzs 于 2007-10-29 14:49 发表 http://www.3dportal.cn/discuz/images/common/back.gif; _8 N7 i, ?' c8 _( k+ S: M
- q4 \- H( J4 s9 t: Y& m
. O) u' E9 y+ Q, N
To use MICRO module you need to:) {: {, @; t6 J" t& M: a0 P, R
! r% t7 R) Y; M' U1 w0 t3 M1) Install ProCAST2006.1, m1 }- X" z3 d1 ]7 q9 a
$ }' M4 L  S, }! Z8 Q  O2) Replace original *.exe in "<ProCAST2006.1 program directory> \bin" directory with craked ones from archive in my post#1
5 D5 A% v7 w- I0 s
$ R! g0 ]4 I! V1 U3) Download a additional crack "procast2006.1_micro_crk_gellmaR.rar" from my post#46, unRAR two patches from that archive into  "<ProCAST2006.1 program directory> \bin" and run them$ `( Z: Z8 H9 M: Z
2 X9 O9 P! q- B* z+ C) l
[ 本帖最后由 solid_user 于 2007-10-29 17:47 编辑 ]
 楼主| 发表于 2007-10-29 19:30:26 | 显示全部楼层 来自: LAN
原帖由 jojo1983 于 2007-10-29 14:53 发表 http://www.3dportal.cn/discuz/images/common/back.gif
' I# c. T$ H( I: fdear solid_user ,& B5 t1 l! \0 `/ ]# w" Z$ _; W: |6 I
        I'm sorry to trouble you,  I fall into a new trouble that the procast can not work after I followed the readme file ,put the patches into \bin and run them, the cmd informat ...
, r7 t5 w7 {/ d+ ZI did not see such a problems on my computers!
" Z( [: ~' L$ W6 ]9 aDid you create that *p.dat files in licensed or cracked PC2006.1?1 g5 V* _& T, M( p7 c0 r6 t
+ k; S# ]/ `, E[ 本帖最后由 solid_user 于 2007-10-29 19:31 编辑 ]
发表于 2007-10-29 19:51:21 | 显示全部楼层 来自: 中国广东广州
oh ,may be that's my fault, The ProCAST2006.1 Installation which I didn't download from this forum because of our bad campus net . I asked a friend to send me an installation file which may not fit the crack,   really thank you very much ,solid_user.   I'll try to find a way to download the installation from the ftp and try again..    thank you
发表于 2007-10-29 21:53:31 | 显示全部楼层 来自: 中国广东广州
http://www.3dportal.cn/discuz/ftpse/    procast06R1下载
 楼主| 发表于 2007-10-29 22:52:44 | 显示全部楼层 来自: LAN
原帖由 jojo1983 于 2007-10-29 19:51 发表 http://www.3dportal.cn/discuz/images/common/back.gif
9 _& ~7 m1 G1 h. F4 m5 M6 |oh ,may be that's my fault, The ProCAST2006.1 Installation which I didn't download from this forum because of our bad campus net . I asked a friend to send me an installation file which may not fit th ...
7 }) i6 W7 {/ @: t2 yIt will be very usefull if you can compare ORIGINAL files in "ProCAST2006.1 program directory" from your Installation and from this forum ftp-Installation and report what files are different!
发表于 2007-10-30 09:27:08 | 显示全部楼层 来自: 中国广东广州
原帖由 solid_user 于 2007-10-29 22:52 发表 http://www.3dportal.cn/discuz/images/common/back.gif0 w. r8 {8 p" a
1 B- P" P6 b# J+ o; y/ JIt will be very usefull if you can compare ORIGINAL files in "ProCAST2006.1 program directory" from your Installation and from this forum ftp-Installation and report what files are different!
7 m4 e- _, J" R6 p9 T( w( s
' g$ s- ]1 B' Y. N
hi,  yesterday evening I got a installation from this forum ftp,which I found that was same from the installation I used before . The problem which i found out is on my operating-system . I'm sorry that I don't have ORIGINAL files,although I really wish to offer it ,in order to requite your big help.  I don't know that there are really a difference between the assemble module in meshcast and that mentioned in meshcast's users guide. I believe that you're sure to solve it some day ,cause you are our hero, thank you !!: j) L+ D& z2 m% D7 l' C
发表于 2007-11-20 17:12:35 | 显示全部楼层 来自: 中国广东广州
非常感谢楼主的付出,尽管我还不能下载。提个外行的问题,楼主能否直接做个license文件,就象老版本的Crack一样?这样可能更方便,吹毛求疵了。
; d; \4 ^% f" M/ v" `yet,i thing if we can crack it like the old version that by using a license work?
发表于 2007-11-30 22:37:50 | 显示全部楼层 来自: 中国江苏苏州
我的procast2006.1在检查网格时老是应用程序错误,请问老大们是怎么回事
 楼主| 发表于 2007-11-30 22:50:08 | 显示全部楼层 来自: LAN
原帖由 wlm508 于 2007-11-30 22:37 发表 http://www.3dportal.cn/discuz/images/common/back.gif
; K2 R" d. J$ D- K: U! C: l我的procast2006.1在检查网格时老是应用程序错误,请问老大们是怎么回事
6 E5 R" M$ W1 g: z' w9 |5 @( F% W! J9 d8 t7 a
It is ussual thing... MeshCAST can not automaticaly create a mesh on complex geometry with default settings
( Y; h9 ~+ W$ ~! n  S6 V. yYOU HAVE TO EDIT MESH MANUALY! (read MeshCAST Manual )5 o& ?' k) N) N) j  F
9 v  o* o$ B0 E4 LOr use a Geomesh http://www.3dportal.cn/discuz/viewthread.php?tid=405646
: ~2 Y! y# c9 jor Visual-Mesh for meshing models for ProCAST
8 w7 q6 p5 |4 {( L1 q/ g0 J
" Q# D% V3 k* E+ [[ 本帖最后由 solid_user 于 2007-11-30 23:47 编辑 ]
发表于 2007-12-1 07:53:30 | 显示全部楼层 来自: 中国江苏南通
我做那一个
发表于 2007-12-7 16:53:02 | 显示全部楼层 来自: 中国陕西西安
solid_user,you are great, thank u very much.
) c6 {% ?9 Y. J  O* @8 C; P% X, Fbut now, I have a problem.when I run "calcosoft result" or"porosity_post",It has the warming" no valid token for using this postprocessor" ,i don't know why ? Please help me!
' n- F0 d/ b) c; {, W9 J) s% x
* J  z) H6 p% a[ 本帖最后由 bopie 于 2007-12-9 11:19 编辑 ]
发表于 2007-12-15 08:47:12 | 显示全部楼层 来自: 中国浙江宁波
原帖由 solid_user 于 2007-10-11 18:22 发表 http://www.3dportal.cn/discuz/images/common/back.gif- [# ~9 Z+ i" e, p* `# G9 ~8 v9 C
9 ?/ z8 A6 E* x1 D0 b( m+ v) JI do not use MagmaSoft and have no got Installation of that Apps...
6 }& u3 l( s" u
% j- X' z7 l3 s' M/ `8 U  D
. E, H8 x, F1 P' {楼主,我已个传了MAGMASOFT4.4,麻烦您CRACK吧
