我从论坛上看了解决SW工程转换CAD工程的乱码的问题,按照上面的修改了,可是还是不行,怎么回事,希望指点
* {7 J! R3 V( j我用的SW2005,CAD2004,不知道版本有没有影响: x* q' U4 h% J$ D
修改的参数如下
) ]; \2 a% L }*AutoCAD SHX or TTF to SolidWorks or Windows True Type font, mapping file
0 W4 ]/ `& i: W' U* T' H4 }! d |*Created: October 18, 2001
3 H, M4 e. c* {7 f4 p* file format: 3 columns, space delimited
: Y; N- M4 f9 c) C7 r% R2 |* first column = AutoCAD *.shx or *.ttf font names,
~( D" \0 b# z* second column = SolidWorks or Windows installed *.ttf font names
, W- D0 A% R6 f+ u* last column = SolidWorks->AutoCAD width adjustment factor7 m5 f1 k- b$ ?$ V$ L
* All font names in the columns below must not contain file extensions.3 @* _, E7 }6 }6 Q
* Font names in the right hand column must be SolidWorks or Windows installed True Type fonts./ X9 V3 j+ U5 Y+ ]3 F
* You can add fonts and rows to the mapping file.
7 _! |6 B- F: w! h& d* For any fonts in mapping file that are not installed, substitute default fonts are used.
; f( a0 c1 W; ^# C( Z, `* You can add comments to the mapping file. Comment lines must be prefaced with the asterisk (*) symbol.3 v; S3 N" Z& i
complex SWComp 0.97: v2 B6 y1 T& k: h c
gdt SWGDT 0.8259 \6 Y2 x/ _" h: O, @+ f0 Q
* amgdt SWGDT 0.825
) _5 f6 j; t% C( B( a/ N8 g* amgdtans SWGDT 0.8258 P& J" n6 ?2 M' j
gothice SWGothe 0.97
) N. h$ |, U3 a$ E9 Y/ X% Agothicg SWGothg 0.97; Y% d& C& k: z: _0 @, S
gothici SWGothi 0.97
1 w8 E. R, @8 i. d0 a( Q" L: C4 @+ Qgreekc SWGrekc 0.97
* F% h! d7 f: Z, C( q. K' Kgreeks SWGreks 0.97
9 Q5 r R8 @4 M% nisocp SWIsop1 0.96) k: {+ O0 `7 k) E4 x
isocp2 SWIsop2 0.960 d: w, [/ S" m# l6 F
isocp3 SWIsop3 0.969 F/ V6 Z: J. u& h$ Y: U
isoct SWIsot1 0.972 a8 D7 u( p8 J% b
isoct2 SWIsot2 0.97
y% h: @6 X! l9 ?2 s# _; bisoct3 SWIsot3 0.97% g9 W$ Q2 s# ~ I, g7 O
italic SWItal 0.85
8 P5 G8 ^# Q9 {italicc SWItalc 1.0
' z x1 K7 q8 G# I2 Qitalict SWItalt 1.0- @* B9 J5 O1 V& v& ]
monotxt SWMono 0.98' G2 r7 M c- v% Z# m$ h
romanc SWRomnc 0.97
* O+ @6 c0 r) W2 [: h% X5 _romand SWRomnd 0.97- q1 y. Y% c# n! {7 C
romans SWRomns 0.97
% Y3 w. @& T) F2 {* O+ Y: Fromant SWRomnt 0.97/ z; c9 v* X: P
scriptc SWScrpc 0.96
) _! @. T( A" J7 @9 jscripts SWScrps 0.84
5 a' U0 O0 W$ q7 Z+ a' [5 D7 msimplex SWSimp 0.97
0 r2 [. W7 I5 J6 r6 Dsyastro SWAstro 0.97* a& c6 ]' ]! S! r( v
symap SWMap 0.97
4 E$ j( x% j& J; w" K1 x. v+ lsymath SWMath 0.953 R: M3 d; {4 N4 J, s! ?
symeteo SWMeteo 0.95 V, @) ]3 ^, b5 Z
symusic SWMusic 0.94
& K$ }. i5 ]9 D+ gtxt SWTxt 0.96
D0 t* B' N g. X8 ]. G# k$ cSimplex Simplex 0.97
0 D+ w" |! r' ~, \5 YArial Arial 0.97
: U6 p9 S$ }9 q Q8 |SansSerif SansSerif 0.97
. }9 `$ H1 j( ~; l/ nSwis721 Swis721 0.97
* d: D; m: {3 V1 b宋体 宋体 0.97! U6 D H" R- a) z) ~
新宋体 新宋体 0.97% z+ J% f2 u0 m& U. { l
仿宋_GB2312 仿宋_GB2312 0.97
) b# M0 x# f5 v0 S" Q楷体_GB2312 楷体_GB2312 0.97
: T/ {, I! s/ K; {6 b$ |9 _隶书 隶书 0.97 |
