查看: 869|回复: 0
[其他] 用吸管来制作漂亮的虾
发表于 2010-4-30 10:06:56 | 显示全部楼层 |阅读模式 来自: 中国上海
http://www.cngadget.cn/wp-content/uploads/2010/04/Strawshrimp.jpg
很漂亮,这是利用我们平常所用的那些吸管制作而成。
http://www.cngadget.cn/wp-content/uploads/2010/04/strawshrimp2.jpg
Hello Class! Today we will be learning how to make a shrimp out of a bendy straw.
http://www.creativeblythe.com/myimages/IMG_0359.jpg
http://www.creativeblythe.com/myimages/IMG_0340.jpg
You'll need a bendy straw. You can go buy some or go raid McDonald's
http://www.creativeblythe.com/myimages/3.jpg
Cut straight up the straw.
http://www.creativeblythe.com/myimages/4.jpg
You need to cut the straw so there are three pieces. For me it's easier to start by making two cuts at the bottom of the straw and then cut straight up.
http://www.creativeblythe.com/myimages/5.jpg
http://www.creativeblythe.com/myimages/6.jpg
Fold the skinniest piece
http://www.creativeblythe.com/myimages/7.jpg
Start out with the folded piece on top and take one of the other pieces and wrap it under the folded piece
http://www.creativeblythe.com/myimages/8.jpg
Pull the wrapped piece over and through
http://www.creativeblythe.com/myimages/9.jpg
Pull tight.
http://www.creativeblythe.com/myimages/10.jpg
Turn it around(If the bendy side is facing left turn it to the right) and do the same with the other piece.
http://www.creativeblythe.com/myimages/11.jpg
http://www.creativeblythe.com/myimages/12.jpg
http://www.creativeblythe.com/myimages/13.jpg
http://www.creativeblythe.com/myimages/14.jpg
Turn back to the other side piece and pull it up.
http://www.creativeblythe.com/myimages/18.jpg
Then pull it to the right.
http://www.creativeblythe.com/myimages/19.jpg
Then crease it along the fold.
http://www.creativeblythe.com/myimages/15.jpg
Then pull the piece under and through like you did the other knots.
http://www.creativeblythe.com/myimages/16.jpg
Pull it tight.
http://www.creativeblythe.com/myimages/17.jpg
Turn it around and do the same to the other side.
http://www.creativeblythe.com/myimages/20.jpg
http://www.creativeblythe.com/myimages/21.jpg
http://www.creativeblythe.com/myimages/22.jpg
http://www.creativeblythe.com/myimages/23.jpg
http://www.creativeblythe.com/myimages/24.jpg
After a second fold on each side it should look like this on the top.
http://www.creativeblythe.com/myimages/25.jpg
It should look like this on the side.
http://www.creativeblythe.com/myimages/26.jpg
Keep going till you don't have enough side pieces to knot any more.
http://www.creativeblythe.com/myimages/27.jpg
It should look like this now.
http://www.creativeblythe.com/myimages/37.jpg
Pull one of the side pieces up and crease the fold at the bottom.
http://www.creativeblythe.com/myimages/28.jpg
Fold it in half and crease it at the fold.
http://www.creativeblythe.com/myimages/29.jpg
Cut up the side pieces to make legs. You'll have to fiddle with them some so that they look right and so that it can stand up.
http://www.creativeblythe.com/myimages/30.jpg
Trim the folded piece to the length you want your shrimps feelers(is that what they're called?)
http://www.creativeblythe.com/myimages/31.jpg
Cut the piece in half.
http://www.creativeblythe.com/myimages/32.jpg
Cut the halves in half, then trim the bottom ones.
http://www.creativeblythe.com/myimages/33.jpg
Curl the feelers with your nail.
http://www.creativeblythe.com/myimages/34.jpg
Smush the tail so you can cut it easier.
http://www.creativeblythe.com/myimages/36.jpg
Trim the tail in a rounded cut.
http://www.creativeblythe.com/myimages/35.jpg
Slit the sides of the tail and then bend it in a shrimpy shape.
Now you have your straw shrimp!
