查看: 1567|回复: 2
[讨论] 蓝屏问题
发表于 2009-10-21 20:46:35 | 显示全部楼层 |阅读模式 来自: 中国湖南常德
有时候蓝屏会出现下面字样,只是有时候出现蓝屏。其它时间可以正常使用。懂的,看看这可能是什么原因。有什么解决方案。A problem has been detected and windows has been shut down to prevent damage to your computer.+ k( L: _. z2 ]+ T- H8 X
DRIVER_IRQL_NOT_LESS_OR_EQUAL
( R7 b! A+ s) U' c" C: m; AIf this is the first time your seen this stop error screen,restart your computer,if this screen appears again,follow:
3 l2 W- {5 n; Y' K) _Check to make sure any new hardware or sofeware is properly installed.
% A, q. m* P( {! Z7 h  v6 H/ kIf this is a new installation,ask your hardware or sofeware manufacturer(生产厂家)
' t9 C" [0 H% x9 OIf problems continue,disable or remove any newly installed hardware or sofeware.disable BIOS memory options(内存选项) such as caching or shadowing(缓存或阴影).. W7 P: F/ Z- U4 p9 S: v* J$ j. t* X8 ]
If you need to use safe mode to remove or disable computers,restart your computer,press F8 to select Advancee startup options,and then select safe mode.
发表于 2009-10-21 22:12:34 | 显示全部楼层 来自: 中国北京
是驱动不匹配吧~!
发表于 2009-10-31 22:47:03 | 显示全部楼层 来自: 中国江西南昌
真是巧啊  ,和我电脑出现蓝屏得一模一样,我现在也愁啊,问了好多人,有说东的,有说西的。综合一下,应该不是硬件得问题,可能是CPU风扇得灰尘太多了,散热不好。  但我不太敢动那CPU风扇,怕坏了。呵呵。。。  这件事我郁闷了好久,朋友,加下我QQ ,475709399 下次一起讨论下。
