[2009-5-6]UFO Download English 软件更新列表[UFO]: p' H ~/ W" \( T
Software Name:PLCEdit 2.0.3( Installation of multi-language version) 9 x% K& z1 ~# V. a+ `
Language:English
( l0 g# S6 I: YSoftware Size:3640KB
3 E+ B& L" R- R# DIntroduction:
: ?/ u1 H. x+ s/ z2 b' X. W
" V9 u2 ]2 o8 Y M% h2 Khttp://www.ufodownload.com/soft/UploadPic/2009-5/2009561247966625.jpg$ E8 y( ]: L( i
1 \% g1 i; ^0 ~0 [5 q, I" APLCEdit is a freeware source code editor for PLC programming.
/ O( Z2 K" `( n( K3 D7 J1 wPLCEdit can read, edit and create POU files, comptaible to Moeller SucoSoft and XSoft, all CoDeSys export files and Siemens IL and SCL sources. ! u' ?6 h1 u2 E2 z% [5 ?8 [" |
2 f! Z1 U8 p- r, b3 AWith PLCEdit it is possible to create the different types of files, Program, Functionblock and Function. . D: T" i; _6 K( ]8 r8 U1 V
: H' R3 l- Q- ~8 D- P
The programming languages are Instruction List (in German AWL) and Structured Text.
* G! F1 q! `5 i+ Q( M o, n+ L5 D: \' e( y8 _
Features:
- H$ v6 t5 N# D, q/ Ysupport for Moeller, 3S Software (CoDeSys) and Siemens sources
6 n9 J9 Q3 I/ W: o$ ]& y: [2 O% U4 m7 R3 j4 _
programming languages Instruction List and Structured Text
+ q" W f4 D; X( d( b
: |( A/ H& S) c" r; d% s3 b# f5 Msessions as different POE files in a desktop file
$ O5 p8 X5 D+ `; C
! @0 T9 o4 {6 E) Sdrag & drop opening and printing
% v5 Q7 g- S; j M+ {$ H( p- j5 M Y- ^! H) R7 k) V8 ^( H% i
a bi-lingual interface and help (en, de) ( q& Y8 y0 `0 K% w
S7 I& C6 g- D/ A) ^4 N( X
POU Info dialog for all files " Y( m1 }. L W9 P" x
, T/ Q% p& \: T I+ L6 L* xenhanced CoDeSys support : H' e) e, A5 c
) h C* Q/ {) B( P1 a
redesigned print function
, r/ g U& M; Y4 o' F& y; f8 m5 k* ]3 t$ q7 F
rebuild language handling ( [+ X4 g0 M. o' t5 E. g/ F
$ A& h+ t, w, R- O/ C8 H+ E2 _
7 o+ e+ L( i) A5 v9 C! t. @ Down LCEdit 2.0.3( Installation of multi-language version) Software Name:Jailer 2.97(English green version)
4 a) y) L. B; U6 ALanguage:English- ~ ~! ^0 z! H4 n% _3 W9 i
Software Size:4983KB
/ X; J3 {" i `' C' lIntroduction:
# }8 ?6 a: N. ?7 G% k6 O Q/ j$ H W
A powerful Java-based data export and extraction tool.
6 K5 o4 T3 v0 o [( x
' {; ^; v2 ]7 x' W, gJailer is a powerful and smart data extraction tool that enables you to:
1 C2 w* e- O* h, Z- c* W5 I6 `2 F. \9 s9 {1 A# w4 V- ^) v5 \
· extract small consistent (referentially intact) row-sets from your productive · database and import the data into your development and test environment.
G& }* H4 l' ?% ~& N: ?& c- O
· remove and archive obsolete data from your productive database.
: E' H; k) P) FExtracts consistent, referentially intact row-sets from your R-DB (DB2, Firebird, Derby etc.).
- ]1 g- ?7 C, |' }# h; r* v* Q8 d8 lAlso Removes and archives obsolete data w/o violating integrity. Highly configurable, generates topologically sorted SQL-DML.
3 l, F* t9 g; B" ?4 Y, i7 ?. E2 V5 z# W, h) A
( L( k" y9 u9 y2 g Down:Jailer 2.97(English green version) Software Name:WinPDF v1.0(English version is installed)
5 ? X' Z# e! ^- f# F6 @; LLanguage:English
" a. }) d! }( ]% ^ A& W% ~* R/ PSoftware Size:708KB' g' e; B& c' N' Q2 X
Introduction:. ~/ f# x5 `2 p* k, ~; B
9 ^0 h6 x3 y1 R! r/ _
http://www.ufodownload.com/soft/UploadPic/2009-5/20095612405923080.jpg! h) Q1 S, e# L8 S- s3 y5 J
( ~; g& X/ X, @* c- d+ W; z( ^
WinPDF offers an easy way of creating high-quality PDF documents out of almost any windows application. The software installs a PDF writer named "Easy PDF Creator" as if it were a real printer, making the creation of PDF files as easy as printing. Common documents can be converted to PDF files at an incredibly fast speed while retaining the look and feel of the original documents as well as many options that give users flexibility in PDF creation.
' G3 k6 V- U1 L" v! ?, c Down:WinPDF v1.0(English version is installed) 8 V# O+ O( Q* m- h' D- Q
[quote]Software Name:VMware Workstation 6.5.2 Build 156735 Windows(English version is installed) 7 q s2 L) z8 ]1 Z1 D; E/ d
Language:English
, m0 V9 d1 z7 _Software Size:468822KB% t3 L2 c7 n, i- @9 s1 N7 i
Introduction:
% b6 z/ u+ m" g* a& j# V% |7 H
! |1 C7 v0 n- D, F; P( M8 [http://www.ufodownload.com/soft/UploadPic/2009-4/20094181527042634.jpg |
