查看: 2354|回复: 4
[求助] 为什么电脑键盘的几个键显示别的键的内容
发表于 2009-2-18 12:24:07 | 显示全部楼层 |阅读模式 来自: 中国上海
我下载了一个雨林木风 Ghost XP SP3 装机版系统,安装后发现显示器分辩率无法更改,只能选择640x480,中16位,,显示如下:- d3 J1 Q' |+ r# k4 W
System Information
& H4 `) o; U6 U7 x6 c( _8 k$ W1 n( P------------------
( M0 h7 t5 }% q7 |  Y( N$ |Time of this report: 2/14/2009, 03:50:26- s7 q" T8 {$ L* R5 [
       Machine name: KMS-COMPUTER1 P  x5 S9 g+ [$ r1 l
   Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)% ?& {5 E. V3 K8 H+ H3 U
           Language: Chinese (Regional Setting: Chinese)& \  y8 j) s- v' L
System Manufacturer: FUJITSU
; ~' v0 y+ I- p2 _6 n+ E       System Model: FMVNUUC3Y
, m- ^  ?( G- d  h               BIOS: PhoenixBIOS 4.0 Release 6.0     & q: ], q& h& Q2 c, `2 w
          Processor: Intel Celeron, ~860MHz( \- D% h. e9 h0 l2 ^# d
             Memory: 254MB RAM
0 c3 ]1 r* `8 L' f, M( a          Page File: 131MB used, 397MB available
4 g" v8 ]9 q$ N/ \0 S( P, y        Windows Dir: C:\WINDOWS! j' N' y9 O5 L& {7 F
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
5 p0 Z, U. S0 L, xDX Setup Parameters: Not found
+ I  g0 x# o! v- g9 H     DxDiag Version: 5.03.2600.2180 32bit Unicode
+ w, o3 Q: z' O7 q/ J. Z------------  W1 y1 n% C3 ~9 |
DxDiag Notes
, d4 i/ K% k/ T' Z! I9 U------------9 L1 J8 ~, r2 d0 p( u. Q8 X
  DirectX Files Tab: No problems found./ m; S" F+ k- n6 W
      Display Tab 1: The system is using the generic video driver.  Please install video driver provided by the hardware manufacturer. Direct3D functionality not available.  You should verify that the driver is a final version from the hardware manufacturer.) U5 M- q- }# [) C- c) U% t
        Sound Tab 1: No problems found.
2 u* i3 L7 z( F( p% c          Music Tab: No problems found.1 ?% [- k- `5 p) D
          Input Tab: No problems found.
2 E1 Z  B2 z$ d. d* c        Network Tab: No problems found.
6 `& p- f& D& x# @. h--------------------5 a. L1 C8 A) z: x* `$ |$ q, e
DirectX Debug Levels
4 {. ]8 i: b# v0 X--------------------
& ]& c: ^) Y7 ?+ ~, PDirect3D:    0/4 (n/a)" a. \; l# y+ h# B6 E; m( S
DirectDraw:  0/4 (retail)
& L6 F8 D- n6 s! VDirectInput: 0/5 (n/a)
4 \- i/ w6 [6 @; FDirectMusic: 0/5 (n/a)/ K) Q/ J- n4 l  D9 L. _# {
DirectPlay:  0/9 (retail)
# Q0 U, J7 j) l  T3 G) LDirectSound: 0/5 (retail)
. z6 J% z4 R7 mDirectShow:  0/6 (retail)
# l) P7 k! s6 I% g---------------
( M$ K8 T* O! ?Display Devices
2 F9 p5 q" d9 C- [8 V---------------; W1 k2 r; |3 v$ B9 U6 a; i
        Card name: . P5 I' O( j* |, ~+ F
     Manufacturer: 0 j( K/ f9 l# @; m
        Chip type:
/ q. T- v0 b# @         DAC type:
, O" x- p1 ^0 D+ S+ D       Device Key: Enum\# F3 c2 @- ^, U: B3 _
   Display Memory: n/a+ q3 {! H3 A) P8 o, x: G
     Current Mode: 640 x 480 (16 bit) (1Hz)3 b  e, |5 \: W8 y- t5 x4 I# T
          Monitor: % N$ G. a" m2 T( @/ k' d5 ?( q$ a6 ?
  Monitor Max Res:
+ L$ c  s  M: C) F9 ]; C8 p      Driver Name: vga.dll8 |  O$ y' h# h$ n. Q  h2 A
   Driver Version: 5.01.2600.0000 (Chinese)
  K5 I4 U9 u' K; N. A      DDI Version: unknown9 O/ [7 ]$ y) |$ }
Driver Attributes: Final Retail
5 @/ c1 V1 v& i; [- V: ZDriver Date/Size: 6/6/2004 06:14:10, 9344 bytes
  s! N$ f( U8 H8 E      WHQL Logo'd: Yes; L. p$ s3 U, N9 g* e$ g# A! C
  WHQL Date Stamp: n/a
1 W8 ^8 ?" G% B! R              VDD:          Mini VDD: vga.sys
4 H' Q$ k* w/ l- i+ V' D9 E# o    Mini VDD Date: 8/3/2004 23:07:08, 20992 bytes
; i( P( N* G8 h4 Z" WDevice Identifier: {D7B70EE0-4340-11CF-B063-282AAEC2C835}- d6 i7 P9 J( f" B6 N9 h
        Vendor ID: 0x00005 |9 e; `  @, ^5 Q2 d
        Device ID: 0x0000
1 |/ S* J0 |' ~. d( l3 p        SubSys ID: 0x00000000: c2 E" a0 O) _- M7 w& e
      Revision ID: 0x0000
! q* z" j/ G% s$ c) G( K& P! r      Revision ID: 0x0000
* j/ U) |! G$ D0 _# j8 U      Video Accel:
* v/ W  x9 J) X, E; e( u) x6 ADeinterlace Caps: n/a' Z# z9 ?3 D: ~3 p
         Registry: OK: e! d9 A6 r+ [$ E8 U3 K
     DDraw Status: Not Available3 L& X, i- l( \! p; u
       D3D Status: Not Available3 s' v5 m( ^4 B7 }7 w
       AGP Status: Not Available
: X# x( |! M; u( |9 gDDraw Test Result: Not run
: K' H( x# f3 F+ ?D3D7 Test Result: Not run" P% O( D& d& D" K
D3D8 Test Result: Not run
2 z  G; B1 C: x; QD3D9 Test Result: Not run
5 t# j/ s! ^* `1 C
6 w/ u7 c: B: X% [
3 \9 `) _% M( |; S& o) q
但是在安装了INTEL82830的驱动后,分辨率可以更改,但是几个键UIOJKLM分别对应成4561230,不能输入相关字母,请问这是怎么回事?如何解决?
( v$ e. [: e1 i" S$ z- l0 X  M3 \键盘信息如下:
% p/ i$ P* {% I- k+ Japanese PS/2 Keyboard (106/109 Key)
, K, M: F$ O6 c+ d8 V: u% M0 h4 o# B| Matching Device ID: *pnp03205 l# W6 m; k0 c" }
| Service: i8042prt. ?$ ~7 i/ T2 `8 t) x
| Driver: i8042prt.sys, 8/4/2004 00:40:46, 47616 bytes
$ v4 X. [8 m( R; o$ z; l| Driver: kbdclass.sys, 8/4/2004 00:44:38, 23296 bytes: }. ^* h( S/ o
| Driver: kbdjpn.dll, 8/17/2001 22:36:18, 8704 bytes
2 l5 X" Q3 u7 _5 F: p% u- W| Driver: kbd106.dll, 8/17/2001 14:55:56, 6144 bytes
- F( E- K( u2 b1 h( \$ W6 a8 k|
) ~8 i4 I) e  o1 M" o, l+ Terminal Server Keyboard Driver, i; P7 I+ Q* Z* U% y' Y8 I
| Matching Device ID: root\rdp_kbd
& m$ ]9 S$ K( [4 x( P| Upper Filters: kbdclass- t5 J0 N' b* ~6 i
| Service: TermDD
3 n3 s. p6 B9 \; A1 N| Driver: termdd.sys, 8/4/2004 00:52:50, 40840 bytes. c* u, {/ M. V
' R& L# ?. k2 p3 t0 b
& w. e2 n" [* T[ 本帖最后由 jarwher 于 2009-2-18 12:25 编辑 ]
 楼主| 发表于 2009-2-18 12:26:46 | 显示全部楼层 来自: 中国上海
电脑是富士通笔记本FMV686UV,显卡信息如下
8 F5 t( U1 Q. O5 R- n- kDisplay Devices
3 {9 ]7 M5 W4 l+ a' s" u---------------/ t! }, a6 i0 j
        Card name: Intel(R) 82830M Graphics Controller
' n7 k/ [" ^+ t/ }0 h9 v+ M     Manufacturer: Intel Corporation
: O* r7 e" C0 R        Chip type: Intel(R) 82830M Graphics Controller8 ]1 ?) O8 Y% Z7 E
         DAC type: Internal9 d9 X5 I, D" b, n; I1 E  J% n
       Device Key: Enum\PCI\VEN_8086&DEV_3577&SUBSYS_113C10CF&REV_046 a0 X: I' m3 j6 a2 }% Y
   Display Memory: 64.0 MB
4 j: B8 F  O# X' B3 W0 R: i     Current Mode: 1024 x 768 (32 bit) (60Hz)$ U; E$ n: C; A' ?
          Monitor: Digital Flat Panel (1024x768)# x+ w/ V7 |" T0 R& w  ]& k( a2 A- u1 o
  Monitor Max Res: ! H! a2 ~9 s% m5 B+ g7 J: z, l1 F
      Driver Name: ialmrnt5.dll* S1 B& I7 ]" j/ @# l6 `1 l- h. e
   Driver Version: 6.14.0010.3889 (English)
4 B/ S6 h1 E. F+ p$ d( l      DDI Version: 9 (or higher)
# ?2 V4 g9 {! ?, X7 B( S3 k. m2 lDriver Attributes: Final Retail
: M  j! d- Y$ w( D Driver Date/Size: 8/20/2004 16:11:36, 37951 bytes
# l5 ^  {2 l( |      WHQL Logo'd: Yes
+ P7 A8 E* @2 g  b9 l8 L2 n  WHQL Date Stamp: n/a
! e/ S2 A( m8 i4 k9 W! S% k              VDD:          Mini VDD: ialmnt5.sys7 f5 P1 ]( q: s
    Mini VDD Date: 8/20/2004 16:26:00, 737874 bytes
8 X! x9 b6 L  T$ hDevice Identifier: {D7B78E66-7637-11CF-4E7C-3631A5C2CB35}
8 P! ]2 ]- k  m7 x9 N% D# M. X; w        Vendor ID: 0x8086" S) m6 v. q% f' p
        Device ID: 0x3577
* Z: P, c5 m+ |+ S, i- f        SubSys ID: 0x113C10CF
" [! A/ Y* r( }$ y# |2 P7 i' f  I      Revision ID: 0x00042 K& u( |9 `9 M: X1 z. z
      Revision ID: 0x0004
- v. @. a. o6 z$ p" J      Video Accel: + F5 [( R1 M9 ^% n& h
Deinterlace Caps: n/a% b5 k4 k$ Q) d1 `
         Registry: OK
& |3 N, `$ @# u     DDraw Status: Enabled. H. ?# R& [6 f2 R
       D3D Status: Enabled: y! W3 q1 ^; O: R2 l
       AGP Status: Not Available/ Q! H0 v+ @% Q6 v4 t
! \+ {8 P1 b5 @4 v D3D7 Test Result: Not run; r; ~+ T7 m, S1 ~3 w
! s1 C$ o' [- h. O8 i D3D9 Test Result: Not run9 ^" S6 r0 R- X  h! Q6 I
$ G* _5 u, M/ f$ u. a- W7 w5 a" }$ E[ 本帖最后由 jarwher 于 2009-2-18 12:29 编辑 ]
发表于 2009-2-18 12:37:40 | 显示全部楼层 来自: 中国浙江杭州
这是因为你按了笔记本专用的键盘,请按住Fn+上方的F10(F12),我也忘记是具体是哪个了,你看一下在F9~F12有个键盘图标的,你按哪个即可解除你所说的情况!
发表于 2009-2-18 12:58:09 | 显示全部楼层 来自: 中国辽宁大连
可能是无意开启了数字键盘的原因,应该先查看键盘上数字键盘指示灯状态是否亮着的,如是按住Fn键再按Num Lk键。
 楼主| 发表于 2009-3-1 12:00:29 | 显示全部楼层 来自: 中国上海
不是开启了数字键盘的原因,根本没有开启数字键盘
