查看: 1955|回复: 0
[转帖] Adobe Audition v:3.0/多国语言/零售版
发表于 2007-11-13 23:24:36 | 显示全部楼层 |阅读模式 来自: 中国浙江杭州
Adobe Audition v:3.0/多国语言/零售版3 B9 H& {( ?) H5 |' r4 E, q
Adobe Audition 3.0 | 225 Mb) E+ v+ i0 u% q
http://img.verycd.com/posts/0711/post-435613-1194576843.jpg
, _  p2 k( e% W& U/ ^% LAudition 3.0新鲜出炉,新功能包括:
, g( M% n+ N( D3 G支持VSTi虚拟乐器!这意味着Audition由音频工作站变为音乐工作站
8 S( H1 h5 o4 a增强的频谱编辑器。可按照声像和声相在频谱编辑器里选中编辑区域,编辑区域周边的声音平滑改变,处理后不会产生爆音 * D$ H) H% X( i
增强的多轨编辑:可编组编辑,做剪切和淡化 : ?/ w. [' a7 A/ i' B
新效果:包括卷积混响、模拟延迟、母带处理系列工具、电子管建模压缩 / H% a& c* `4 Z. A) O
iZotope授权的Radius时间伸缩工具,音质更好
. r) J6 `* C9 k% N8 c- \3 q新增吉他系列效果器 2 |  N+ e* z) R( |
可快速缩放波形头部和尾部,方便做精细的淡化处理
2 H. }8 r7 U( F+ f3 ]  f8 @% d增强的降噪工具和声相修复工具
, X* f1 S5 @6 s! ?) L更强的性能:对多核心CPU进行优化
3 p( i( B! I. p' v8 o+ z: s波形编辑工具:拖拽波形到一起即可将他们混合,交叉部分可做自动交叉淡化4 f8 l; J1 |; A. x4 b& ]* X5 b* h+ Y
Audition 3.0将于2007年第4季度上市销售,价格349美元,从2.0升级是99美元,一段时间将提供DEMO下载。" e. l6 T" z/ q5 x6 Y+ O) Q0 z+ A
AdobeR AuditionR 3 (formerly Cool Edit Pro) software is the all-in-one toolset for professional audio production.. Designed for demanding audio and video professionals, Adobe Audition offers recording, mixing, editing, mastering, and effects processing capabilities. Its flexible workflow, combined with exceptional ease of use and precise tools, gives you the power to create rich, nuanced audio of the highest possible quality. Whatever you do with audio, Adobe Audition 3 software helps you sound your best. Get professional results in real time with AdobeR AuditionR 3.0 software.
5 {  O) p0 Q5 G! c: @; ~Adobe Audition 3 is designed to give audio professionals - sound designers, recording and mastering engineers, and musicians - a flexible production toolkit for recording, mixing, editing, and mastering audio. With comprehensive audio mastering and restoration capabilities, Adobe Audition 3 helps professionals create music and radio spots, as well as restore imperfect recordings with sophisticated editing tools. New features include VSTi virtual instrument support with MIDI piano roll, enhanced spectral editing options, fast fade and crossfade controls, and advanced multi-core support.
! L0 o, U( v6 m) F6 e* P( uhttp://i2.photobucket.com/albums/y1/belinamen/startingpage-1.jpg
1 ?7 R/ U& z0 M4 @# N9 n3 M( q: ~New effects include Analog Delay, Convolution Reverb and Tube-modeled Compressor, while the Guitar Suite can add analog-modeled effects to dry guitar tracks. iZotope Radius time stretching allows users to accurately change tempo and pitch independently. Audition 3 additionally offers on-clip fade handles, a dedicated Top/Tail mode in Edit View, automatic crossfades and the ability to edit grouped clips together.3 e- B1 W. u3 o9 S! n
Audition 3 also adds new Adaptive Noise Reduction and multiple phase correction tools. Editing in the Spectral Frequency display is enhanced with the Effects Paintbrush and Spot Healing Brush, similar to the tools found in Adobe Photoshop CS3 software. Also, the addition of the Marquee Tool to the Spectral Pan and Spectral Phase displays lets users visually isolate and edit any sound based on time, frequency, phase or pan location., u9 c; ^8 x' U$ H' x# K
业级音频录制、混合、编辑和控制& c9 }: N# ~6 c* Z! W
满足您的个人录制工作室的需求: 借助 AdobeR AuditionR 3 软件, 以前所未有的速度和控制能力录制、混合、编辑和控制音频。 创建音乐, 录制和混合项目, 制作广播点, 整理电影的制作音频, 或为视频游戏设计声音。 Adobe Audition 3 中灵活、强大的工具正是您完成工作之所需。 改进的多声带编辑, 新的效果, 增强的噪音减少和相位纠正工具, 以及 VSTi 虚拟仪器支持仅是 Adobe Audition 3 中的一些新功能, 这些新功能为您的所有音频项目提供了杰出的电源、控制、生产效率和灵活性。
# O4 H$ J& @# O3 P0 T& i& K* W( K语言英语、法语、德语、意大利语、日语和西班牙语
9 Z$ P3 i1 A" S, L/ Z系统要求 Windows
+ u, X( R; d! m- Q; B2 M, _. yIntelR PentiumR 4 (DV 需要 1.4GHz 处理器, HDV 需要 3.4GHz 处理器); Intel CentrinoR; Intel XeonR (HD 需要双 Xeon 2.8GHz 处理器); 或 Intel Core™ Duo 或兼容处理器 (AMD 系统需要支持 SSE2 的处理器)
9 J9 }8 J3 A6 B5 F2 E% F: fMicrosoftR WindowsR XP Professional 或 Home Edition Service Pack 2 或 Windows Vista™ Home Premium、Business、Ultimate 或 Enterprise (经验证仅支持 32 位版本)
, y- H; {* n+ @3 Z6 J, h8 o512MB RAM (DV 回放需要 1GB; HDV 和 HD 回放需要 2GB)
9 G1 q) F6 b5 O; D, P10GB 可用硬盘空间 (当与 Loopology DVD 一起使用时) 6 j, G% Z3 e0 I" S% x8 Q
安装需要 DVD 驱动器
0 t1 K. N4 R5 s1,280x900 监视器分辨率, 具有 32 位视频卡和 16 MB VRAM
  Z& H! C% z# T4 q, c% y6 SMicrosoft DirectX 或 ASIO 兼容声卡
/ {  ~- s$ \+ |0 O" c5 `使用 QuickTime 功能需要 QuickTime 7.0 " T* G4 D. i' k! t( e! F% ]
产品激活需要 Internet 或电话连接
1 p3 t# S9 g+ q. k$ OUse Adobe Audition 3 to:
( ^) m% }7 Q) u& u% }' W* Create your own music
; T- b. g$ E9 L1 A8 |* Record and mix a project
8 C( A; T" [7 J2 U! Y* Produce a radio spot, F- i) e% D/ m# ]0 Y+ F6 L- C# R
* Clean up audio for a movie+ N9 K' j7 u0 J1 q$ c* G3 w
* Compile and edit a soundtrack/ o+ H# u, D' e' C8 t7 h2 G" n4 G
Top features in Adobe Audition 3:9 ?& }7 [' a1 u8 u) l" J
" \2 f& v6 x5 V2 Z2 R! Z" o" \+ sEnjoy support for a wider range of virtual instruments. Simply add a MIDI host track to your mix, choose an instrument, and then record new audio in the Sequencer.+ X+ s! i" V+ r% L
Improved multitrack editing
5 }. S# K- d7 U& x+ HSave time and increase accuracy by editing grouped clips together. Auto-crossfade clips in multitrack view to quickly mix files together. Click-and-drag fade handles on multitrack clips and in the Edit View for faster editing4 d  ~- {! a/ Q, |, B* G
Enhanced spectral editing
  F1 J0 G+ B" ?5 r/ F5 V# sMake a free-form selection in frequency space with the Effects Paintbrush and apply effects in varying degrees to that selection. Smooth over a selected region to automatically repair clicks, pops, and other noises using the Spot Healing Brush.7 K% z4 b: ]8 O0 C
Top/Tail Views& E9 B( O% Q+ m/ T
Need a quick and easy way to tweak the start and end of a loop or other audio file? The new Top/Tail Views allow you to zoom into the beginning and end of a file so you can quickly add precise fades while keeping the whole file in view.
4 v' y, m: z+ [* {7 R; CNew effects5 @, F9 a0 t9 L/ r6 H& ^
Adobe Audition 3 includes new effects such as Convolution Reverb, Analog Delay, Mastering tool, Guitar Suite, and Tube-modeled Compressor.  Y7 [! W% L. _$ O# E6 D
Superior performance
. `; w; p1 A% x+ PGet superior performance and take advantage of the new multicore processors. The optimized mix engine allows for more tracks and effects on the same machine, offering more variety and faster processing.
# F, y& X% v2 S2 Y软件大小: 48713 KB , K  K. m. |. E; N. ~& T
软件语言: 英文
. V/ P& C* s" C. a9 [' f软件类别: 国外软件 / 共享版 / 音频处理 $ S2 \3 M: T1 S
应用平台: Win9x/NT/2000/XP/2003 $ a; D5 ~2 \5 n8 F4 n( I" C. z
联 系 人:
) |; `) I. M1 N% C+ ]开 发 商: http://www.adobe.com/ % n/ P3 \. u' V7 v# t
  ; k/ U3 n1 Z- U2 @2 X- c
软件介绍: " v) o0 x' E* O- o6 S
    Adobe Audition是一个专业音频编辑和混合环境。 Audition专为在照相室、广播设备和后期制作设备方面工作的音频和视频专业人员设计,可提供先进的音频混合、编辑、控制和效果处理功能。 最多混合 128 个声道,可编辑单个音频文件,创建回路并可使用 45 种以上的数字信号处理效果。Audition 是一个完善的多声道录音室,可提供灵活的工作流程并且使用简便。 无论您是要录制音乐、无线电广播,还是为录像配音,Audition中的恰到好处的工具均可为您提供充足动力,以创造可能的最高质量的丰富、 细微音响。它是 Cool Edit Pro 2.1 的更新版和增强版。此汉化程序已达到98%的信息汉化程度。# m& V) X1 g% q
专业级音频录制、混合、编辑和控制: |. R7 x% r/ O3 g) d2 ~
满足您的个人录制工作室的需求: 借助 Adobe(R) Audition(R) 3 软件, 以前所未有的速度和控制能力录制、混合、编辑和控制音频。 创建音乐, 录制和混合项目, 制作广播点, 整理电影的制作音频, 或为视频游戏设计声音。 Adobe Audition 3 中灵活、强大的工具正是您完成工作之所需。 改进的多声带编辑, 新的效果, 增强的噪音减少和相位纠正工具, 以及 VSTi 虚拟仪器支持仅是 Adobe Audition 3 中的一些新功能, 这些新功能为您的所有音频项目提供了杰出的电源、控制、生产效率和灵活性。9 k6 _; Y) M# P% W" c, S; w$ q
语言
  _3 }' ]5 K2 ]( V3 _5 b4 x英语、法语、德语、意大利语、日语和西班牙语
. p7 p* I& Z- u8 G# K& Z系统要求( `6 \6 T% |; M2 e2 d
Windows
# b& d; B) B# Y; s! UIntel(R) Pentium(R) 4 (DV 需要 1.4GHz 处理器, HDV 需要 3.4GHz 处理器); Intel Centrino(R); Intel Xeon(R) (HD 需要双 Xeon 2.8GHz 处理器); 或 Intel Core(TM) Duo 或兼容处理器 (AMD 系统需要支持 SSE2 的处理器)
( v* `* y# Y" A: g8 ?& p. W9 |Microsoft(R) Windows(R) XP Professional 或 Home Edition Service Pack 2 或 Windows Vista(TM) Home Premium、Business、Ultimate 或 Enterprise (经验证仅支持 32 位版本)
  \! H: l- [/ `5 X' [. C512MB RAM (DV 回放需要 1GB; HDV 和 HD 回放需要 2GB)
  f) i( ~4 @: S% V, j! R7 k10GB 可用硬盘空间 (当与 Loopology DVD 一起使用时)6 P$ d# f9 p9 B+ I3 C
安装需要 DVD 驱动器& w1 {; Y2 h' [2 L. B. F
7 v# p! {/ Y( l  c& |! {Microsoft DirectX 或 ASIO 兼容声卡
: Q- m7 g3 Y$ R& _使用 QuickTime 功能需要 QuickTime 7.0
8 J. H6 t6 T! h  ]  Y& u( E产品激活需要 Internet 或电话连接
; T" u3 K$ \0 p' D+ ?http://aycu35.webshots.com/image/31594/2001092207836510910_rs.jpg0 n" J6 T2 k- c3 z
Adobe Audition v:3.0/零售版+keygen1 V! Q, p  u  V9 t
Download:
5 w# T1 i% O, u% T, Q2 F' ZAdobe.Audition.v3.0.Multilingual.Retail.Incl.Keymaker.READ.NFO-AGAiN! K# J+ b2 w/ }
http://rapidshare.com/files/6901 ... NFO-AGAiN.part1.rar
, M/ r3 w$ u1 t0 E) V7 U  Z8 x: l* G% ehttp://rapidshare.com/files/6901 ... NFO-AGAiN.part2.rar
, p( G' y% m& a2 _* ]! qhttp://rapidshare.com/files/6901 ... NFO-AGAiN.part3.rar
/ j6 g$ y+ g0 O8 m! l3 ~Adobe.Audition.v3.0.Manual.Addon.Multilingual-AGAiN . H% v- P  F+ p4 }: x5 Z/ k
http://rapidshare.com/files/6901 ... tilingual-AGAiN.rar
