查看: 2269|回复: 1
[已解决] Transmagic.Plus.v2006.SP1如何安装?
发表于 2007-4-14 10:10:42 | 显示全部楼层 |阅读模式 来自: 中国江苏镇江
Transmagic.Plus.v2006.SP1是一种专门浏览3D模型的软件,如proe,UG,catia,solidworks等的软件,其介绍如下:5 x, b- _6 L$ l' {. }3 a" y4 i+ s
0 @0 t% _( D/ N8 e- P
TransMagic develops a broad range of 3D CAD translation, geometry % j) P+ o' S, c7 ?$ Z; U
       repair, and visualization applications to meet a variety of
# ^  A: r1 L! T7 D% s- w       engineering needs. TransMagic products support the major 3D CAD   % x# \6 q9 C; l( [
       industry file formats at a very affordable price. The supported   8 ^: V9 w7 o3 R9 ?
       CAD file types include SolidWorks, CATIA V5, CATIA V4,            2 v1 ~; z" s* t1 J
       Unigraphics, Pro/ENGINEER, ACIS, IGES, Parasolid, STEP, HSF,
, P# H+ P" D, {8 Z       NGRAIN and STL. Using the highly robust and accurate ACIS and
8 M& t3 l& X8 w: @- m, O       Parasolid formats, TransMagic supports solid to solid file        6 G2 l& y- A/ g. j+ m
       transfer between hundreds of additional applications. See our CAD " H8 |% T* F0 i- E4 m0 e
       Translation Software Compatibility Guide. TransMagics
* @4 W2 g6 _+ }5 K: G( k4 q( a) z       easy-to-use, standalone interface does not require any CAD
( r/ ^& W) h4 z2 o9 S       software! TransMagic offers tools to view and fix problems in the
* _, D$ k# A9 Y  J, p! m       geometry before translating a file. The unique TransMagic Repair
( N; d: ]) e& p4 N3 u       system makes many repairs automatically, such as, stitching loose
! y1 t7 n' [; C3 g* {# k- s       surfaces (faces) together in IGES files. Advanced Repair options,
$ x3 H4 o. A- u2 _/ K* a# f1 v       such as Full Repair and Assembly Repair, close gaps in geometry to
+ J# R! F+ z2 ~$ L; d1 p7 W       create 搘ater-tight?so lid models and fix tough geometry         9 B9 A/ W- J# u4 [& c
       problems. Large gaps or missing surfaces can be closed or replaced 9 s# l6 f8 M" X" o4 s
       using TransMagic's advanced Repair tools.
* c  y, [3 e" r5 g& l1 _
2 L3 b6 K, V0 x& {. Z1 \8 R/ a+ A& c覆盖crack文件里的SlsApi.dll和SlsApiEx.dll无效(仍提示还没注册). Q& [; J5 y+ a# M5 V7 f
运行Keygen_batch.exe及Keygen_plus.exe提示错误
& i0 \5 d5 w( U( j% W# T有人安装过吗?
发表于 2007-4-20 23:56:56 | 显示全部楼层 来自: 中国上海
我的版本为2005版,不用解密的,还可以修补面
