查看: 10833|回复: 4
[已答复] 求助:TIR的含义
发表于 2007-3-21 23:31:52 | 显示全部楼层 |阅读模式 来自: 中国陕西咸阳
求助:TIR的含义
日本图纸里的外径对轴线的跳动为:TIR0.04,那么有谁知道TIR是什么意思呢?
1 X+ }  J- [1 b, `谢谢了
3 P3 s/ D7 q- Q" Y1 C+ T  i9 i) C7 E1 L6 o) L
发表于 2007-3-22 16:49:03 | 显示全部楼层 来自: 中国上海
你的应是同轴度的意思0 z2 b1 \, J/ D( H* ^9 m$ r
- l7 F' b& v# n% e! @' xT.I.R全称应该是“Total Indicated Runout”意思是“总体指示偏差量”。0 p. M8 A# P' q& n
TIR: total indicator reading (总指示跳动,总指示偏转, 总指示偏离量, 总体指示偏差量,都可以) 4 q: m( F, r3 i0 E' B+ Y
5 ~8 K7 f6 |- T' TRoundness and Out Of Roundess
( _6 x0 g6 @5 O. N6 n: w  T8 B- y. s* C
Roundness tolerance, a function of normal shrinkage variations in the metal, is a tolerance zone for concentric circles within which each circular element of the surface must lie. This zone is the total indicator reading(TIR) when the part is rotated 360º. Another, quicker method is achieved by calulating half the difference between the maximum and minimum quantities of range. ±.005” per inch (.127 mm per 25 mm) is a general rule that may be applied.
9 F- D2 X: n6 H, r+ q: z( n( k& xOut of Roundness is the radial deviation from a true circle and a given circumfrence.
  H( |! m+ k7 {# g
, \4 J, K  p8 W( G3 m0 o5 [- |[ 本帖最后由 3dwhcyh 于 2007-3-22 16:55 编辑 ]
开亮 + 2 应助
发表于 2007-3-22 23:23:09 | 显示全部楼层 来自: 中国上海
发表于 2009-5-14 10:52:43 | 显示全部楼层 来自: 中国江苏南京
是同轴度吧。
发表于 2010-12-22 08:28:55 | 显示全部楼层 来自: 中国福建厦门
本帖最后由 jiba35 于 2010-12-22 08:32 编辑 # y- l" X( C  e
3 g; w; _2 D+ o% e( s0 f3 o3 s
学习了 谢谢分享!
开亮 + 2 交流
