查看: 3622|回复: 1
[分享] solidcam后处理工具?
发表于 2016-12-27 12:37:54 | 显示全部楼层 |阅读模式 来自: 中国云南昆明
The GPPTool program can be run in one of two modes:7 Q  P: `9 [; K
  • As an integral part of SolidCAM program. Whenever the G-Code command is given inside SolidCAM the GPPTool program is activated to generate the G-Code.
  • As a separate stand-alone program; It receives as input a Part generated by SolidCAM and then generates the G-Code. This program supports list of postprocessors.  The user should make sure that the same CNC-machine is used both by SolidCAM and GPPTool. Run GPPTool by Double click on file named GPPToolExe.exe that is located on the following folder:
                    \\Program Files\\SolidCAMXXXX\\SolidCAM,# `3 r( K( Y# H% S- ]% t
where XXXX is the version of SolidCAM Software.
# m. |$ b6 b( V1 f3 b* a4 c" B' U; V上面这段话大意是说后处理工具在安装在 \\Program Files\\SolidCAMXXXX\\SolidCAM,可是我的solidcam2011却只有一些后处理文件,没有执行程序。我的安装我看看了是没有问题的,是不是这个版本的solidcam2011 sp0没有哟,有没有遇到有过同一问题的哥们,来说说呀
- r6 \+ {& d1 k3 q1 h; x来源: solidcam后处理工具?
发表于 2016-12-27 22:51:18 | 显示全部楼层 来自: 中国江苏南京
你应该有GPPTool 这个软件(程序)才行
