3天前
查看: 2912|回复: 7
[分享] 最新win7/win2008傻瓜式激活工具Windows Loader 2.1.5~~~~~~~
发表于 2012-6-27 08:20:06 | 显示全部楼层 |阅读模式 来自: 中国广东东莞
更新了最新版本。2.1.5
+ @( @; y( G; K8 P
( n2 K4 V% _: o
  1. File   : Windows Loader.exe: A5 [! e: s$ t- m; s2 i
  2. CRC-32 : 86d512467 ^: Q* Q" E- t. H9 z
  3. MD4    : 7abd6fb5c76f5b33a9ce2dddcf41577f' v- g5 s  X! x3 l, n
  4. MD5    : 269632a286f976f8c14873345fd989a6
    ' t5 g  O" H& Z" n8 V2 A5 o. O
  5. SHA-1  : 3a0fe8b574d685ae9ed5f1ee6ecf50086ddfdd2f
复制代码
  e: ]5 n0 V: T* ^! C' i3 F6 X6 I! C; f1 ]0 [; D; b  G5 R
This is the loader application that's used by millions of people worldwide, well known for passing Microsoft's WAT (Windows Activation Technologies) and is arguably the safest Windows activation exploit ever created. The application itself injects a SLIC (System Licensed Internal Code) into your system before Windows boots; this is what fools Windows into thinking it's genuine.
) I8 ~% v5 a0 m' z; u4 r* I" a7 q; d- w0 v
The things you might want to know9 O) z# j5 _4 T* j# u8 y; o. o
- It works on 32-bit and 64-bit systems# \# B* U6 T8 o4 I  [3 w1 ~
- It's compatible with Windows 7 SP1 and all system updates2 d% Y. j. h; v$ y; T
- It's compatible with all system languages: c( T# k* |7 c- [, y( n9 A3 A
- It can be used to pre-activate Windows8 p' q. I  C$ k% n" O
- It allows you to install custom OEM information1 O! f$ K' A7 k
- It features application integrity checking
5 y3 j4 C/ c4 Q- It supports hidden partitions and some complex setups
& U2 q. N4 v4 J! H5 L- It can work alongside Linux's GRUB or any other boot manager- ^) B7 T  p2 B- `& t0 e) [
- It works with VMware, VirtualBox and Hyper-V
5 ?" e% B( f% ^) n; Y& [  \/ H2 R- It works with most hard drive encryption software e.g. TrueCrypt or BitLocker2 l; V% `* ?6 j8 A7 i0 Z
- It allows you to add your own certificates and serials externally6 h5 W6 g7 r& B: x0 K
- It will install just the certificate and serial for users with an existing SLIC 2.1$ [9 w. y- }+ ]; D7 E7 P+ O
- It features automated system profiling (The application matches everything up for you)
$ |3 Y$ A2 S! l- It won't modify any system files
4 U% X' V1 b4 W9 a- It runs before Windows is launched
+ O+ d, _9 k4 G5 l# M8 i- No extra processes are run so you have nothing eating at your RAM8 M7 d! \3 a0 C7 p: g
- All key parts of the loader are encrypted with a custom encryption" V1 e6 j% g3 q8 O, e
- Every user has a unique version of the loader installed on his or her system! V5 Y$ F" N! C! @: \: U- {
1 V% Y5 h3 l0 s0 |& A( u( k4 L
Supported operating systems
! Z6 [; ^5 a( B- Windows 7 Ultimate
( d/ Y1 |* t4 H$ R% Z* E4 H( Y- Windows 7 Ultimate E# w, h4 \- ?% W/ V9 W: p: E  D
- Windows 7 Professional
( \% K, d6 X. i2 u" {% C1 n- Windows 7 Professional E
3 S1 ~0 x) ?- M3 i3 Y4 |! i% Y; f6 z- Windows 7 Home Premium# _2 Z, L8 t4 ]# W
- Windows 7 Home Premium E
1 A5 S) F+ `2 ~* _6 @- Windows 7 Home Basic
0 Z' {+ M& l6 @# r2 p) b- X: C0 c- Windows 7 Starter3 `' v8 a: q9 K& E) e$ z  B
- Windows 7 Starter E
- S  Z6 M8 x# o8 b6 r$ b- Windows Vista Ultimate
" f  W' i+ [8 Q$ r- Windows Vista Business
% _1 w8 A  F, H& O0 Z- Windows Vista Business N; ^% ~2 L, J& O
- Windows Vista Home Premium0 J- N, l! T" U4 s, M4 m8 S3 C
- Windows Vista Home Basic7 w% i2 [2 K# ]
- Windows Vista Home Basic N
0 v; O; |  c. J1 `; V4 o" \- Windows Vista Starter
7 W, p( }* C4 v- Windows Server 2008 Enterprise; q' J: p# H- |% o
- Windows Server 2008 Foundation, ~  X6 t* t4 w: A) m4 [/ ?3 Z# |
- Windows Server 2008 Standard
% y1 p; j% I# |. j5 K- Windows Small Business Server 20085 r6 B' |; C6 z3 _: I# M& {6 \7 V* J  r
- Windows Storage Server 2008 Standard
8 ]2 N' i0 R- b% p- Windows Storage Server 2008 R2 Essentials
! T3 Q% M0 ?- ^0 j6 T3 B( E- Windows Server 2008 R2 Enterprise
/ k3 K- C7 T& a7 g% @( a- Windows Server 2008 R2 Foundation
% x- j7 k. v* }. _! h- Windows Server 2008 R2 Standard% r/ G  c( N' o9 j5 J) g. q9 u* `+ [( `
- Windows Server 2008 R2 Datacenter% F0 @1 [; ?: s1 I: F
- Windows Small Business Server 2011 Standard* z7 f  P. R% M& y3 w$ d: p. M/ K: I
- Windows Small Business Server 2011 Essentials
* ~8 V, _1 W5 _- Windows Home Server 20117 `+ z  x; \( p9 O  m* K8 W! Z3 Z- {
' H/ H) m8 I$ I: d0 Y0 T% k; m
Note: You must be running build 7600 or greater for Windows 7 and Windows Server 2008 R2.3 e8 g( \! T/ M
Note: I don't recommend using any of the Windows 7 E editions.2 F, k6 Z- N: O! ~$ Z8 j! E
Note: Windows 7 N editions will only be supported when OEM SLP serials leak.- G( M# G: y, c4 b
" w: d6 \, a3 |( G" p! H: n8 X
Application integrity checking?7 h, K/ `8 a- q6 [. X5 A
Hover your mouse over the green, amber or red icon to see detailed application information.
' x4 B$ T5 h7 D2 U
8 l5 \2 b3 [2 t0 S* T0 hNote: Even if the icon is green someone might have found a way around the protection system so it's worth checking that the applications path is always the same as the location from which you launched the application. You should also check that the MD5 matches the MD5 found online.
. Q9 c5 b- v0 i% q! p7 K8 u& U) R# P8 V! H# R& c& D; I
Virus scanner results
' ]/ h- `' P! fAll virus scanner detection's are a false-positive as long as the MD5 matches. Simply turn off your anti-virus while installing the loader.
2 Q$ w" ]: Y* F- d, k0 z4 b$ S% H5 n" L6 u* Y+ S
Note to uploaders
3 {# ~, x0 i# ~Please tell people to read the read me file as it contains answers to many of the activation problems people have.
, N- a' [; v* n. C# b  O' f* ]+ R6 U2 i
Version 2.1.57 \; X2 L6 V8 `! P  a, @
* Added a new GRLDR version
+ U' n3 G/ ]# n5 _8 M1 n" p9 }* Added Jetway Home Premium, Home Basic and Starter serials
9 U# J' w6 o8 B3 v6 P9 R' X* Added Jetway SLIC and certificate
( a: k+ @2 i: Q2 G( q. s1 W  s* Fixed a bug that caused the unsupported status to be set for every type of issue
3 M/ n7 z9 p& W; b2 @! s2 Y. T. W* Highlighted the status line so that people understand that Windows 7 Enterprise is an unsupported operating system
- x9 @# A; J4 u( t' `- r% z! ~* Other minor tweaks and fixes
/ g" a! C8 |, m& X0 |/ |$ H
8 @/ ~6 R" C3 G4 E0 d Windows Loader v2.1.5.rar (1.43 MB, 下载次数: 88)
发表于 2012-6-27 09:44:19 | 显示全部楼层 来自: 中国天津
谢谢楼主提供的最新激活工具。
发表于 2012-6-27 09:51:27 | 显示全部楼层 来自: 中国山东菏泽
这个以后用的着,收藏了,谢谢分享
发表于 2012-7-3 21:37:16 | 显示全部楼层 来自: 中国贵州贵阳
一般win7或win8系统盘均带有破解或激活程序,下来试试,先谢了。
发表于 2012-7-7 19:21:29 | 显示全部楼层 来自: 中国河北保定
win7我都是用WINDOWSLOADER激活的。
发表于 2012-7-13 16:01:31 | 显示全部楼层 来自: 中国河南新乡
我用用看看行不行
发表于 2012-7-13 16:58:21 | 显示全部楼层 来自: 中国江苏苏州
好东西,值得收藏。Thanks for your sharing.
发表于 2012-7-13 22:27:30 | 显示全部楼层 来自: 中国广东深圳
好东西,{:strong:}谢谢{}
