发表于 2007-1-11 22:30:24
来自: 中国山东青岛
Part1 MaterialsandMechanicalDesign........................................................1 W6 Y6 f) H. @1 i; t
1.StructureofSolids...................................................................................3
( L2 W8 i. Q; F1.1Introduction........................................................................................39 C& w, [+ e1 Q
1.2Metals.................................................................................................12
* x' W+ J9 C- q1.3Ceramics............................................................................................142 o- I9 h+ j4 z. h
1.4Polymers............................................................................................15- T( O* ?/ m/ ~! Q
1.5CompositesandCoatings...................................................................15
( D+ t x4 F9 q* s2.Steel.........................................................................................................17! N/ u& \$ K \0 I+ K
2.1MetallographyandHeatTreatment...................................................181 \( h& |& R$ Z. y
2.2Iron-IronCarbidePhaseDiagram......................................................19
# P4 ]7 E: U ~6 _' m2.3Hardenability......................................................................................25
) w F/ ^: J. O- Q2.4Heat-TreatingProcesses.....................................................................26( X0 c# ]) V* T2 y
2.5CarbonSteels.....................................................................................31
/ U6 g2 d5 U* d v8 p: T2.6Dual-PhaseSheetSteels.....................................................................355 G }" S/ S) h4 v
2.7AlloySteels........................................................................................36- Q k4 b: p1 E' U
3.AluminumandItsAlloys........................................................................456 {+ ]- j Z0 g: p/ W. p
3.1Introduction........................................................................................45, S5 t/ t M6 b3 M" s7 x
3.2PropertiesofAluminum.....................................................................456 L* e& f( y) N7 j7 W) z6 J
3.3AluminumAlloys...............................................................................46' A# x' V3 F. H" h0 S
3.4AlloyDesignationSystems................................................................46$ W$ t( k! m/ q+ ]+ C+ d' E
3.5MechanicalPropertiesofAluminumAlloys.....................................48+ W- F3 ~5 o& J; W k
3.6WorkingStresses...............................................................................49
& F8 \6 d, N! S3.7Characteristics....................................................................................51. {, v0 K; ^. _4 S; E4 a
3.8TypicalApplications..........................................................................52. J- O. _7 j( J% E ^
3.9MachiningAluminum........................................................................53
8 c3 N- n. |' q0 A) u0 S$ B3.10CorrosionBehavior............................................................................54
$ N [" f. o, ~# k' H/ Y" g% m' d0 |3.11FinishingAluminum..........................................................................56" S+ h+ x4 `: ^0 }! x, d+ P
3.12Summary............................................................................................577 X, p7 i) O# n
4.CopperandItsAlloys.............................................................................59
% r8 D# A' h2 A) T; B, A! Q- A4.1Copper................................................................................................592 ^1 [8 x: M/ g+ d% h
4.2Sand-CastCopper-BaseAlloys..........................................................60+ @, K' ?6 ?8 _7 b' M* ?7 B9 Q- F
5.NickelandItsAlloys...............................................................................71
1 E% ^! d8 b6 Z/ y8 L( z5.1Introduction........................................................................................71 G: c! V h0 H7 u1 l
5.2NickelAlloys.....................................................................................72, E: f, V) ^4 N( x
5.3Corrosion...........................................................................................80
% |" T( j. E9 H& n# g A9 X5.4Fabrication.........................................................................................82% L" w, D7 _/ O- _3 C
5.5HeatTreatment...................................................................................84( H+ V' ~5 U4 {. J! R5 k
5.6Welding..............................................................................................86% E/ E/ n5 _3 n! w; @- n( h
5.7Machining..........................................................................................86
* ?6 I$ u$ V& I" R6 m5.8Closure...............................................................................................88: Z, H2 u9 k& N- ^
6.TitaniumandItsAlloys...........................................................................91 o i3 C5 N9 x' Z5 o
6.1Introduction........................................................................................91; I9 s# r0 g, C* `/ J% X* u8 S
6.2Alloys.................................................................................................92+ n& z( g0 t1 o6 Z4 e! g8 w
6.3PhysicalProperties.............................................................................96
7 K( k/ r2 |0 }* o% Y" z. j; ^6.4CorrosionResistance.........................................................................97
& }. u+ F4 T0 \3 s; N6.5Fabrication.........................................................................................98
6 N, O: U" G/ K6.6Specifications,Standards,andQualityControl.................................105/ R% y+ k2 R- s/ m' B( u
6.7HealthandSafetyFactors..................................................................107
) s: @8 \6 ]9 Q9 H6.8Uses....................................................................................................1077 e% W! c% J, y. ]/ C" R: W
7.MagnesiumandItsAlloys......................................................................109. c) l9 {9 g: r+ A- r9 Z% U
7.1Introduction........................................................................................109
- G; X! K5 s. p; o) v6 a% {7.2Uses....................................................................................................109
) _# ?; _. v: K' A3 a: W8 v7.3AlloysandProperties.........................................................................1108 J$ r& M( d' q+ Q
7.4Fabrication.........................................................................................110' J% @1 y1 [+ r; [) [
7.5CorrosionandFinishing.....................................................................1132 W/ T! w5 P& Z7 t, ~! b9 N
8.1Introduction........................................................................................115; c2 N1 r q0 N: B
8.2CommodityThermoplastics...............................................................116% z. K8 ?& O1 m
8.3EngineeringThermoplastics..............................................................1205 O! Y/ X) R/ x% \
8.4FluorinatedThermoplastics...............................................................1242 x' }4 d. e( L' {$ a Q
8.5Thermosets.........................................................................................128: R% J% y$ K2 G! \
8.6General-PurposeElastomers..............................................................129
/ Q# {; m1 e0 f! u5 `, ^8.7SpecialtyElastomers..........................................................................1294 _6 k, s/ W& L! U1 D+ _: W H
9.CompositeMaterialsandMechanicalDesign.........................................131
: b: ?7 K6 h6 c3 K3 d. x9.1Introduction........................................................................................131
- o' D' T" t4 f0 O( s/ \9.2ReinforcementsandMatrixMaterials................................................136
/ a5 p: j- d6 \3 P9 C' u! U9.3PropertiesofCompositeMaterials.....................................................142, Y: Z4 K% U6 {: z+ B( K
9.4Processes............................................................................................161
( ~6 L; i0 Y4 ~7 h; d. m c3 S. @9 k9.5Applications.......................................................................................163
8 c) O5 |3 B; M( n7 I; J9.6DesignandAnalysis..........................................................................1846 J9 ]) Y; Z6 C y( [* g8 o/ a# t9 H
10.StressAnalysis........................................................................................1912 i4 z8 R [; f6 N( z% @4 r
10.1Stresses,Strains,StressIntensity.......................................................191. }! i) m( V: W! W
10.2Discontinuities,StressConcentration................................................199
! Q& c6 Q/ {( f& f* }10.3CombinedStresses.............................................................................199
( p5 d) U2 N0 \4 F! ?9 t; o10.4Creep..................................................................................................2038 M# j$ L/ k, |; w0 c9 y- [, g- `
10.5Fatigue...............................................................................................205
1 n; F% a, Y# x9 T8 r10.6Beams.................................................................................................207
' L8 h0 U5 c5 ` g x6 g/ @5 m10.7Shafts,Bending,andTorsion.............................................................224; T5 l' m3 x3 u* W
10.8Columns.............................................................................................229- H }' A j% v/ m# s2 e
10.9Cylinders,Spheres,andPlates...........................................................235/ a* Z" I- @" A$ T8 y: j# ?9 W
10.10ContactStresses.................................................................................242
' A! X9 R) ^# ~- H10.11RotatingElements..............................................................................244; y6 a6 I- G1 E* D) x- T. \
10.12DesignSolutionSourcesandGuidelines...........................................2445 s5 Y1 ]9 q" B# g! ?9 k
11.ConcurrentEngineeringRevisited:HowFarHaveWeCome?..............2490 C! J/ i. W9 ^7 ]! K
11.1OriginofCE.......................................................................................2491 ~9 C J' J) e0 O4 q5 w2 w
11.2AdoptionofCE..................................................................................2506 {% T3 }0 C- L+ f% a( u R
11.3DefinitionofCE.................................................................................250
6 A/ K* z" J, n! n11.4TheCETeam.....................................................................................250
6 O8 P4 j, Y3 B0 P11.5TheEssenceofCE.............................................................................2505 T& { h- i# o& ~) J! M( r: X' T
11.6BarrierstoCE....................................................................................251
* v1 D" o! X$ _) ^7 X11.7ApplicabilityofCE............................................................................252
3 D0 f* K: X+ Y* `- T, }( m11.8CEandtheIndividual........................................................................252
1 y9 D" K8 e- c11.9TeamworkCanLeadtoChaos...........................................................2523 R- A% [; C; H/ C# d& h/ G
11.10CEandInnovation.............................................................................253
7 B8 s$ T5 M1 y11.11CELessons.........................................................................................253/ J' H0 } _ s; A. h* ]4 ?1 ^
11.12ConcurrentEngineeringTechnologies...............................................253
! @. f4 R6 A+ L) B. Q+ G. z11.13ApplicationofCEPrinciples.............................................................2582 s5 ^* Q* o$ ?# L
, j" E2 F0 y* m% ]) G Z" }[ 本帖最后由 Paul_peng 于 2007-1-11 22:41 编辑 ] |
