查看: 1348|回复: 2
[注意] 求Crack(第9关)
发表于 2009-3-13 15:03:33 | 显示全部楼层 |阅读模式 来自: 中国天津
这是一个国外的小软件,据说全球只有4个人通关了,求高手过第九关截图![local]1[/local]7 q& I% o/ v% }% S- J
+ W, G; |: o& b
[ 本帖最后由 zzj8001 于 2009-3-13 15:34 编辑 ]
 楼主| 发表于 2009-3-13 15:54:53 | 显示全部楼层 来自: 中国天津
附件
刚才附件没上去,这回我再试试
发表于 2009-3-13 19:21:34 | 显示全部楼层 来自: 中国江苏无锡
说的是bloxorz吗?下面是全套答案。$ S/ C- F9 Z. g0 `/ x) O
+ v7 f  t8 q. _6 c! m5 v3 t
stage1780464→↓↓→→↓→
stage2290299↑→↓→→→↑↑↑→↓←↓→→→→↑↑
stage3918660→↑→→→↑→↓←↑↑→→→↓↓→→↓←↑
stage4520967↑←↓→↑↑↑→↑→→→→→→↓→↓↓↓↓↓→↑←←←←←←↓
stage5028431←←←→←←←←←↓↓←↑→↓→↓↓→→→→→↓→→→←←←←↓←←←←←←
stage6524383→→→↓→↓↓→↓↓→↑←←←↑↑←↑↑↑→→↓→→↑←↓↓→→↓↓→
stage7189493↓←↑→→→→→↓→←↑←←←←←↓→↓→↓→→→↑↑→↓←↑→↑↑→→→↓→↓→↓←↑
stage8499707→→↓↓↓→→空↑↑↑→→
stage9074355→↓→→→→→→↑→↓←←←←←↑空↓→→→→→↓
stage10300590→→←↓↓↓→↓↓↓↓↓←←←←↑←←←↓↑→→→↓→→→↑空↓↓→→↓→↓↓↓←↓↑→↑↑↑↑←←↑←↓←←←←←
stage11291709→→→→↑←↓↓↓→→→→↑↑←↑↑←←←↓→↑→→↓→↑←←←↓↓←←←↑↑↑→→↓←↑↑→↓←↑→↓←
stage12958640←↓→↑→↑→↑→↑→↓←↑→→→↓↓↓←↑→↑↑↑←←←→→→↓↓↓←↓→↑→↓←↑↑↑→→↑↓←←↓↓↓→↑←↑↑←←←↓↓←
stage13448106↑←↓→↓←↑→→↓←↑↑↑↑←←←←←←←↓←↓→↓↓←↑→→↓←↑→↓↓→↓↓→↑→→→→→↑←↓←↑↑
stage14210362→→→→↑←←↓→→→↓↓↓↓←←←↓→→↓→→←←↑←↑→→↑↑↓↓←←↓←↑→→→↑↑↑↑←←←←←←↑→↓←←←←←↓↓↓→↓→
stage15098598→→→→↑↑空↑↑↑↑↑→→→↑↑→→→→↓↓↑↑空←←空→→→←←←↑→↓←←↑→↓←←←↓←←←↓↓↓↓←↑→↓→→→→→→→
stage16000241→→→→空→↓空→↑空→←←←空→→→空→→→→→←←←←→→→→→→→→→→→空↓→→→→→→→→→→
stage17683596↓↓↓↓↓↓↑↑←↓→→→→→↑→→→←←←↓←←←←↑↑↑↑↑↑→→→→↓→→→→↓←↑→↓↑→↓←↑↑→↓←←↑→↓←←←←↑←←←←↓↓↓↓↓↓→→→→↑→→→↓↓↑←↑←←←↓←←←↑↑↑←↑→→→→→↓→→→
stage18284933→↓←↑→→↓←↑→→→↑↑↓↓←←←↑→↓←←↑→↓→→→↓↓↑↑←←←↑←↓→↑←←↓↓↓↓→→←←↑↑↑↑→→↓→↑←↓↓→↑←↓→↑→→→→→↓↓↓←↑→↓↓←↑→↓←↑→
stage19119785→→→→→→→→↓→↑←←←←←←↓→↑→→→→→↓↓↓↓↓↓←←←←←↓←↑→→→→→→↑←↓←←←←←↓↓↓↓→→→←←←←←←↑↑
stage20543019↓←↓→↓←↑↑→↑↑←←←↓←↑→→→→↓←↓↓←↑空↑←←←←←↑↑↑↑↑←←←←←←↓↓↓↓↓←↓↑→↑↑↑↑↑→→→→→→→→→→←←←↓↓↓←↑←←←←←↓↓↓↓↓→→→→→↓
stage21728724→↓←↑←↓→↑→→↑→→→↑←↓↓↓↑↑↑→↓←←←↓←←↓←↑→↓→↑←↓→↑←↓→↓↓→↓↓→→→↑↑↓↓←←↑←↓→→→↑↑↑↑→→→
stage22987319→↑←↓→↑→↑→→→↓→→→↑→↓←↑→→↓←←←↓→↓↓↓←↓↑→↑↑↑←↑→→→↑←↓←←←↑←←←↓←↓←↑↑→↓←↑→↓←↓↓↓→↓↑←↑↑↑→↑←↓→↑→↑→→→↓→→→→↑
stage23293486→↓↓←↑→→→→→→→→→↑←↓→←←←↑↑↑↑↑→→→→↑↓←←←←←←↓↓↓↓←←←←←←←←↑↑↑→→↑↓←↑→↓↓→↓↓↓←↓→→→↑↑↑↑↑↑→↓←↑
stage24088198↓←↓→↓←↑↑↓↓→↑←↑→↓→→↑↑→↑→→→→↓←↑→↓→↑←←←←←←↓→←↑→→→→→→↑←↓→→↑←↓→空↓空→↓←→↑→→→
stage25250453↑→↓←↓→↑←←↓→↑↑→→→↑↑←←↑→←↓→→↓↓←←←←↓→→↑→→→↑↑→→→↑←↓→↑↑←↓→↑→↓←
stage26426329↑↑←←←↓←←←↓→↑→→↑↑→→↓→→↓→→↑↑←←↑←←←←←←↓←←←↓↓↓空↑↑↑←←←←←←↓←←←↓↓↓↑↑→↑←↓→↑→→↑↑→→↓→→↓→→↑↑←←↑←←←←↓↓↓↓→→↓→空↑↑↑←←←←↓↓↓↓→→↓←
stage27660141→→→→→↑→→→↓→↑←←←↓←←←←←←↓→↑←←↓→↑→→→→↑→→→→↓↓↓←↓↓↓←←←↓←↑↑↑↑→↓←←←←←←←←←↑→↓↓←↑→↓→↑←
stage28769721←↓↓↓→↓←↑→↓↓→→↓↓→→→↑↑↑←↑←↑←↑←↓→→↓→↓→↓→→↓←↓←←↑↑↑←↑←↑←←↑←←↓←↑→→→↓→↓→↓→↓→←←←←↓↓↓←←←←↑↑←←←←↓空←←←←←←↑↑←←←←↑
stage29691859→↓←←↑↑→↓←↑→↓→↓↓→→←←↑↑←↓←↑→→↓←↑←↑↑←←→→↓↓→↑→↓←←↑→↓→↑↑→→←←↓↓↓↓↓↓→→←←↑↑↑↑←←←←←←→→→→↓←↑→→→→→→←←←←←↑←↓↓↓↓←←←↓→↑←↓→↑←
stage30280351↓→↓↓→→↑→→↓→→→→↑↓←←←←↑←←←↓↓←↑→→→→→→↑↑↑→→→↑→↓↓↓←←↓←↓→↑↑→↓←↓←←←←↑←←↓←←↑←↓←↑→↑↓←↓→↑→↓→→↑←↓↓←↑→→→→→→→↑←↑↑↑→→→↑→↑←←←←←↓←
stage31138620↑←↓←←↑↑↑↑↓↓↓↓→→→↓←↑→→↓←↑↑→↓←↑↑↑↑←↑→↓↓←←←←←←←↓→↑→→→↓↓↓←↓↓↑↑→↑↑↑←←←←↓→↑←↓↓↓↓↓←↑→←↑→↓→↑→→↑→→↓→→→↑←↓→↑↑↑↑↑→↓←
stage32879021↑↑←↓→↑→↑→↓←→↑←↓←↓←↑→↓←↑→↑→↑→↓←←↓↓↓↓←←←←↑→↓→→→↑↑↑↑↑→↑→→↑↓←←↓←↓↓↓↓↓←←←←↑→←↓→→→→↑↑↑↑↑→↑→→↑↓←←↓←↓↓↓↓↓←←←↑←↓→→→→↑↑↑↑→→↑←↓←↓←↓→↑←←↑←←←←←↓
stage33614955→→→→↑←↓↓←↑→↑↑→→↓→↓→↑←←↑→↓→↓↓→↓←↓↓→→↑↓←←↑↑↑↑←↑←↓→↓→↑←↑←←←↓↓↓←↓←←↓←↑
