查看: 1971|回复: 0
[分享] 关于cimatron后置处理
发表于 2007-12-14 17:19:03 | 显示全部楼层 |阅读模式 来自: 中国山东烟台
TOOL CHANGE: FIRST:
1 s- \" u. y" z% }  e      SET_ON  SPIN_SPEED SPIN_DIR ;
1 ?, I' N  h( i+ X6 i4 a" E4 ?*-----save first tool number
" M5 a5 {3 S& f( R6 j2 o  f; x      FirstTool = CURR_TOOL ; " }' b  X7 t, g" ~! G
      LastTool  = CURR_TOOL ; 3 z2 O: r: \( Q- f7 I0 N& a
2 ?2 x3 w$ ~4 e! C*-----tool cutter compensation register number : \: B+ n) V% K0 i: R/ {: Z, x
      CutterComp = CURR_TOOL +  DiaComp ; 4 F" ?9 c. O7 Z# N1 [
! m& I' V. R8 m5 v7 j
*-----assuming 1st tool is in the spindle, there is no need
9 Y  ^0 x' q2 D: T% Z& d( D*     for tool change) 3 x+ D7 E# X. t* p6 @2 V  z
*     OUTPUT $ " T" CURR_TOOL ; 3 u9 Y2 D8 O2 p, Q8 v
*-----more then one tool in this run of the Post Processor 2 m  _* H' S& e: ?) M8 ~( J
      IF_SET (NEXT_TOOL _NE_ CURR_TOOL) # J2 _3 z4 ~. H& E2 x
         OUTPUT $ " T" NEXT_TOOL ; ! [  [9 ?9 Q* @( S- q, P* F
      END_IF ;
! K; t" F) Y7 \, N0 B8 g*-----standard tool change commands. (assuming 1st tool is in
+ j, ~4 {9 E5 N6 @. M; K      OUTPUT $ " G90 G80 G00 G17 G40 G54" ; 1 ]' w/ x2 g( s) }1 o
      OUTPUT $  " Z" Zhome " S" SPIN_SPEED " " SPIN_DIR ;
( L4 @& x' N# {" O6 r6 |0 ]      OUTPUT $ "( 刀具名称---" CURR_NAME "×" CLEAR_LENG ")";
3 j4 n6 j9 E& C0 o" A8 Y( U& ^      OUTPUT $ "( 曲面偏移=" PART_OFST "曲面公差=" PART_TOL" 轮廓偏移=" CONT_OFST " )";
, V0 q$ {! J- k% F9 R# ~0 Q      OUTPUT $ "( 程式名称=" TP_NAME "本程式由" USER_NAME "编制 )";' ^5 N$ n, ~" d9 Z
5 |1 H: ?$ o7 c) h# }7 ?3 Q1 `3 X( W, r; O$ U4 \4 A1 g
   说明:1、*注释或代表不执行此内容;
) _& y; P, H3 ^; }2 J. o6 A       2、 引号里内容则按实输出;
" t: f8 \* ]/ _# b) {       3、修改保存完毕执行主菜单--NC--DFEXF--输入后处理名--回车即可。
