查看: 3721|回复: 6
[求助] lisp语言求助~~~
发表于 2013-2-1 21:02:01 | 显示全部楼层 |阅读模式 来自: 中国江苏无锡
(defun c:ccd(/ v1 v2 p p1 ang m h1)
  (setq v1(getvar "osmode"))
  (setq v2(getvar "cmdecho"))
  (setq v3(getvar "blipmode"))
  (setvar "osmode" 512)
  (setvar "cmdecho" 0)
  (setvar "blipmode" 0)
  (setq p(getpoint"\n插入点:"))
  (setq ang(getangle p"\n旋转角<0>"))
    (if (not ang)(setq ang (/ pi 2)));默认旋转角0°
  (setq h(getreal"\n粗糙度字高(即粗糙度符号大小)<3.5>"))
    (if (not h) (setq h 3.5));默认字高3.5
  (setq h1(/ (* 2.8 h) (sqrt 3)))
  (setq m(getstring"\n是否为加工表面(y/n):"))
  (command "layer" "M" "细实线" "");使用“细实线”图层
  (cond ((or(= m "y") (= m "Y"))
                 (setq cc(getstring"\n粗糙度值<3.2>"))(if (= (strlen cc) 0)(setq cc "3.2"));设置粗糙度默认值3.2
                 (command "line" (polar p (- ang (/ pi 6)) h1)
                                 (polar p (+ ang (/ pi 6)) h1)
                                 p
                                 (polar p (- ang (/ pi 6)) (* 2 h1))
                (command "text" "m" (polar p  ang (+(* 1.9 h) 1)) h (- ang (/ pi 2)) cc)
        ((or(= m "n") (= m "N")) (command "line" (polar p (+ ang (/ pi 6)) h1)
                                                  p
                                 (command "circle" (polar p ang (/ (* 2.8 h)3)) (/ (* 1.4 h)3)))
         (t (alert"\n请输入yn")(princ))
   );end cond
  (setvar "osmode" v1)
  (setvar "cmdecho" v2)
  (setvar "blipmode" v3)
  (princ)
);end
6 f" W# [( H% @$ |+ v4 q; f; j( b
为什么运行出来的文字不旋转?. @9 o; U9 R( E
' E% Z! ^  n* R. \ps:在循环语句中碰到其他值时怎么样让循环不终止,而是在警告之后继续执行,如下:
2 z  n' U2 c4 ~: N
(cond((or(= w "y")(= w "Y"))
        (setq ll(getdist p1"\n引线长度:"));引线
        (command "layer" "M" "细实线" "");箭头引线细实线
        (command "line" p1 (polar p1 an ll) ""))
       ((or(= w "n")(= w "N")) (princ))
       (t (alert"\n请输入yn") )
" ]0 i" k" j1 h+ N
 楼主| 发表于 2013-2-1 21:08:04 | 显示全部楼层 来自: 中国江苏无锡
文字旋转角只能用确切的数值 而不是变量吗
发表于 2013-2-4 22:56:04 | 显示全部楼层 来自: 中国辽宁沈阳
本帖最后由 woaishuijia 于 2013-2-4 23:06 编辑 9 b* E  r$ X7 }  a  p  r
dreamMore10 发表于 2013-2-1 21:08 http://www.3dportal.cn/discuz/static/image/common/back.gif3 O5 B2 _+ ^) x( j! m
1 q- Q: V* \! c4 F- [& Q
5 k* |. I; }2 ^文字其实已经旋转了(如果你选中文字,打开"特性"管理器就可以看到文字的"旋转"并不为 0 ),只不过你在代码中给出的角度单位是弧度,而你CAD的角度单位却不是弧度(默认是十进制角度),需要在代码中换算一下,或者修改"AUNITS"系统变量为 3 (角度单位改为弧度)$ X& a  S1 Y. `, t
"cond"函数不是循环,而是多条件、多处理结果函数,执行完判别式为真的代码后一定会跳出.当然你可以在它外面套一个"while"函数,在"cond"函数的不符合条件代码组中加一个标识性的变量赋值语句,跳出后由"while"函数检查该变量是否被赋值,如果"cond"执行的代码不是理想中的就重新来过.例如
  1. (defun c:ccd (/ v1 v2 v3 p p1 ang m h1 b)
    1 {9 H1 B1 M; m2 P, A+ ]
  2.   (setq v1 (getvar "osmode"))& W& ^( }4 N5 B% O) y3 n' E9 S
  3.   (setq v2 (getvar "cmdecho"))0 j8 l3 N) H! n
  4.   (setq v3 (getvar "blipmode"))
    ' H4 J: q7 `7 c0 H7 ]0 {
  5.   (setvar "osmode" 512)" i9 ]. ?! H! `9 W% m% X( g) R6 P
  6.   (setvar "cmdecho" 0)
    , c! V! K' a% S  w- U% k2 ?
  7.   (setvar "blipmode" 0)
    / s7 i4 ]% z- Y, u$ n
  8.   (setq p (getpoint "\n插入点:"))
    " S$ j# Z4 A% H. k2 _9 A( Y3 o
  9.   (setq ang (getangle p "\n旋转角<0>:"))
    ( K, ]+ p& Z, J: O6 ]* y8 ~
  10. " [( c% N0 R8 D, v; K" J/ o7 n
  11.   (if (not ang)3 z& m: v; ^  ^% B
  12.     (setq ang (/ pi 2))& K- s" \( t3 g/ E  n
  13.   )                                        ;默认旋转角0°. W" H0 V( [$ S0 }/ y
  14.   (setq h (getreal "\n粗糙度字高(即粗糙度符号大小)<3.5>:"))
    2 w5 U. G* r$ o  h9 x# W" E
  15.   (if (not h)
    % V6 q* P2 z) s
  16.     (setq h 3.5)
    4 N& k  A1 D7 u& W3 [: T
  17.   )                                        ;默认字高3.5/ V+ M* i/ P0 O( x- b4 n; Z
  18.   (setq h1 (/ (* 2.8 h) (sqrt 3)))  _. E& m' T' v
  19.   (command "layer" "M" "细实线" "")        ;使用“细实线”图层* I! m1 T- o3 ]7 S9 s" a( t7 i$ @
  20.   (while (not b)
    3 [5 o3 P6 u8 \) A$ I+ W
  21.     (setq b t
    " B' |: }$ T3 m& w7 O
  22.           m (getstring "\n是否为加工表面(y/n):")
    * L4 h9 L& K& _& k" ~5 c
  23.     )
    8 @; J8 h  O+ S/ Z2 L! |6 f
  24.     (cond ((or (= m "y") (= m "Y"))
    % S! f. t- P9 b* N/ @
  25.            (setq cc (getstring "\n粗糙度值<3.2>:"))
    ' h  o. b9 C' m2 n+ X  K! O
  26.            (if (= (strlen cc) 0)
    + t# q  a$ M; \7 h
  27.              (setq cc "3.2")% F- p; M: M" D6 \/ F3 N8 `
  28.            )                                ;设置粗糙度默认值3.2
    1 U) F6 R, _2 n1 e
  29.            (command "line"3 o0 E9 X3 v; l: u- Q, b
  30.                     (polar p (- ang (/ pi 6)) h1)
      y$ E3 |) s4 G# X
  31.                     (polar p (+ ang (/ pi 6)) h1)4 {$ t& n* R/ @3 s/ s/ p- g
  32.                     p; q& Y& P, Q6 I6 c# Q3 y! C4 j
  33.                     (polar p (- ang (/ pi 6)) (* 2 h1))8 m$ |; U: a; T3 o  _) d
  34.                     ""
    - P0 Q" I' c/ R- j+ e& s
  35.            )
      m% V: M+ R( `* E' E7 u% F, V
  36.            (command "text"
    - q, X2 K3 v% p/ S5 I1 ]! Y& Q
  37.                     "m". E6 e7 X8 \. N/ l
  38.                     (polar p ang (+ (* 1.9 h) 1)); a0 R. V, _; K' _
  39.                     h$ P4 @6 r0 C3 L- ?$ J, c+ T% L
  40.                     (* (/ (- ang (/ pi 2)) pi) 180.0)
    3 n- U) L, o. Y- u5 t) l
  41.                     cc: d# H9 M. E1 H
  42.            )( T, y. L/ |4 K/ ?/ {- E* Y; f1 Q' V
  43.           ), F" o$ @1 g  @. y
  44.           ((or (= m "n") (= m "N"))
    # x1 ~9 I4 H2 h! Z! ^5 x+ Y
  45.            (command "line"
    - n2 `: g6 u$ g! {; E1 Q
  46.                     (polar p (+ ang (/ pi 6)) h1)/ l' `( P8 }. C5 a- z
  47.                     p
    ( m, V2 z8 U$ U) I. X( X2 @# Q
  48.                     (polar p (- ang (/ pi 6)) (* 2 h1))
    # g. s: e3 L9 p. B% z+ |
  49.                     ""- |9 n3 J& k# N" h$ n, t
  50.            )# A9 g9 h8 a1 M3 {; t$ E
  51.            (command "circle"( h' D  u+ d6 v1 L" R/ K* ^
  52.                     (polar p ang (/ (* 2.8 h) 3))& b+ p+ u6 x+ ?; D4 t! I
  53.                     (/ (* 1.4 h) 3)
    , q& e, C& R) N$ o4 w
  54.            )
    4 x( D0 o# j1 Y2 a: k
  55.           )$ g! k, n4 E: R  x: ?, k
  56.           (t (alert "\n请输入y或n") (setq b nil) (princ))7 x8 I. a5 p& O
  57.     )                                        ;end cond
    - r) q/ Z4 ~' B7 s
  58.   )                                        ;end while9 u8 u/ G) q3 P% `( Y' p- }
  59.   (setvar "osmode" v1)! u% u: O* p% M1 A* x6 c6 Z
  60.   (setvar "cmdecho" v2)4 _7 Y+ Y$ D. Z: o' j0 I
  61.   (setvar "blipmode" v3)& t2 k+ L* g4 m9 H+ A/ W
  62.   (princ)9 ]( P4 x- E3 J2 O, v; U' B
  63. )                                        ;end
复制代码
事实上,这个代码中使用"getstring"函数获取用户输入的"y/n"是不合理的,应该先用"initget"函数定义关键字,再用"getkword"函数接收用户输入的关键字,当用户输入的不是用"initget"定义的关键字时,会自动提示用户并重新来过.
& V' E+ [3 M: i' _7 ]$ k9 V用initget定义的关键字,可以用下列等待用户输入的函数接收:getint、getreal、getdist、getangle、getorient、getpoint、getcorner、getkword、entsel、nentsel 和 nentselp,唯独不能用getstring
  1. (defun c:ccd (/ v1 v2 v3 p p1 ang m h1)0 }9 [% ?6 D9 L: @9 }
  2.   (setq v1 (getvar "osmode"))+ B$ s4 f8 T) t% M2 R4 ?
    " q# L6 K& U* @5 h
    0 g5 b9 V3 U8 {5 z9 C; W4 K
  5.   (setvar "osmode" 512)5 }- K8 I; D% Q
    ) |9 \$ F' {/ X- B4 Q2 v  j3 Y
  7.   (setvar "blipmode" 0)8 {5 S& z; T3 v$ _: k! [4 S3 {! ^
  8.   (setq p (getpoint "\n插入点:")): Z. U0 i  F  j3 B
    % h; @+ f+ F7 K& N) `. Q
  10. 3 S1 ?7 i+ B) K
  11.   (if (not ang)
    * x/ s3 W) G7 X' O# ^& G" w
    # Q9 `8 A' L/ I$ ~+ g
  13.   )                                        ;默认旋转角0°1 J% o. W( b6 b0 Z6 z8 }7 e
  14.   (setq h (getreal "\n粗糙度字高(即粗糙度符号大小)<3.5>:"))' K7 n" R- V6 M
  15.   (if (not h)
    ' F7 F" b6 F$ o) p$ ~
  16.     (setq h 3.5)" G! N7 \% @* o/ N. g1 u! E
  17.   )                                        ;默认字高3.5
    / g' T( `% B$ N5 H, K: m& L
    ( @, N4 T$ |! L- T; r
  19.   (initget 1 "y n")- l0 B: k$ o+ B# i" q" s
  20.   (setq m (getkword "\n是否为加工表面(y/n):"))- C2 b! A' m2 @( o
  21.   (command "layer" "M" "细实线" "")        ;使用“细实线”图层
    7 G) N: D  I* @# p+ U' g- ~
  22.   (cond        ((= m "y")8 x/ \0 S' }1 ~. X
  23.          (setq cc (getstring "\n粗糙度值<3.2>:"))- B* H) h) D2 ]( e2 F! e
  24.          (if (= (strlen cc) 0)
    ; \. j* x, M6 ]( }5 i+ |" a' E
  25.            (setq cc "3.2")* L; @0 k! i, ^7 e
  26.          )                                ;设置粗糙度默认值3.2
    ! e+ a2 U- A. w$ g& Q
  27.          (command "line"
      L' e& d- O' Y- ~3 M/ U( T- R
  28.                   (polar p (- ang (/ pi 6)) h1)
    . v5 g# L. w0 x7 g$ J# x
  29.                   (polar p (+ ang (/ pi 6)) h1)
    % T6 I9 m$ q9 G* K5 v2 F) }7 i
  30.                   p
    ) K6 e  c$ o6 f, a( z' f5 W5 M
  31.                   (polar p (- ang (/ pi 6)) (* 2 h1)): S0 T* u+ U$ I6 ~
  32.                   ""
    ( g9 L4 E) D. x; h4 _
  33.          )
    7 [/ n  M$ P% B6 b1 q
  34.          (command "text"
    6 _2 M9 f7 ?4 ~; \' T" [' W
  35.                   "m"# m, R) g( b( l- j1 X
  36.                   (polar p ang (+ (* 1.9 h) 1))
      j+ `* ]2 T$ r5 u( t
  37.                   h
    / P3 O- l9 H8 d; h) r3 B# h  Z4 y! X- z: C
  38.                   (* (/ (- ang (/ pi 2)) pi) 180.0)
    + I1 W' |" Q3 L4 z* ?3 e: a& Q. o7 S
  39.                   cc
    + ^/ z* A! ~1 n: U3 ~; d' d, ^
  40.          )0 E! p- R. g' d
  41.         )+ C& v% B9 q2 W" f) [' I
  42.         ((= m "n")
    ' i1 d! y9 o6 {" J5 e
  43.          (command "line"
    , R  X+ v8 {3 j- l
  44.                   (polar p (+ ang (/ pi 6)) h1)5 `# `) e$ e! Y+ x! g9 ^+ k: d
  45.                   p
    / o( m1 c3 G" _2 X" x+ e
  46.                   (polar p (- ang (/ pi 6)) (* 2 h1))
    : A3 A6 {8 F+ Y% O
  47.                   ""3 h( |' e9 P  Y; d2 \5 E
  48.          )
    7 Z4 ?6 r4 H( S' y; H
  49.          (command "circle"
    2 n( q  {/ l; Z7 M2 i
  50.                   (polar p ang (/ (* 2.8 h) 3))% W/ ^0 i, y) s' L2 D: V) g
  51.                   (/ (* 1.4 h) 3)
    ( J) C7 S+ p( u9 W
  52.          ); T2 Y3 I1 Y, i/ _/ i& s/ b
  53.         )/ u. k7 O: i3 d( \! G1 k
  54.   )                                        ;end cond2 s' k. i/ P9 @- X! c' [0 z
  55.   (setvar "osmode" v1)
    : y/ R( ^" E4 e) ?  ?2 l$ b
  56.   (setvar "cmdecho" v2)* F9 p2 @7 Z6 m2 D9 O% s) ?
  57.   (setvar "blipmode" v3)( _+ }, N2 G3 o
  58.   (princ)
    * K9 @3 V/ f3 L
  59. )                                        ;end
复制代码
参与人数 1三维币 +10 收起 理由
唐昕晨 + 10 应助
 楼主| 发表于 2013-2-5 13:43:32 | 显示全部楼层 来自: 中国北京
woaishuijia 发表于 2013-2-4 22:56 static/image/common/back.gif+ q4 G& F; Z5 z% k
文字其实已经旋转了(如果你选中文字,打开"特性"管理器就可以看到文字的"旋转"并不为 0 ),只不过你在代码 ...
5 Q! E$ s* h* O/ }9 H谢谢版主
7 f$ [7 P: ?5 Q$ i! [关于initget函数,我不是太理解,像getint这样的函数“关键字”怎样设置呢,好多书上对这个函数讲的都不是很清楚,能不能给几个例子看看?再次感谢
发表于 2013-2-6 23:37:04 | 显示全部楼层 来自: 中国北京
initget 函数用于为 getint、getreal、getdist、getangle、getorient、getpoint、getcorner、getkword、entsel、nentsel 和 nentselp 函数设置用户输入的规则。
; ]: u1 D( i/ V' F8 g$ T9 ]该函数用在上述等待用户输入函数的前面,只对它后面第一个等待用户输入函数有效,且是一次性的。
1 J! a, n. q8 O- d- L7 q6 Winitget 函数有两个可选的参数。如果两个都写的话,第一个是一个正整数,用于规定用户输入的限制条件。常用的数值有 1,2,4 三个,1 是禁止用户空回车,2 是不接受用户输入 0 ,4是不接受用户输入负数。其它值我就不写了,有关该函数的资料上都有。6 I# K6 o# I3 S$ W
现在,我们在CAD命令行输入 (getint) 回车,然后再输入正整数, 0, 或负整数,回车后命令行回显用户的输入值;不输入任何值直接回车,命令行回显 nil ;输入其它字符(如“y”)回车,命令行回显“需要整数值”。
! }1 d& S) Y* }我们再输入 (initget 1)(getint) 回车,然后不输入任何值直接回车,命令行回显“需要整数值”;其它与前面一样。说明由于 (initget 1) 的限制,(getint) 已不能接受空回车。
/ o3 @8 d+ [% ~  X7 e我们再输入 (initget 2)(getint) 回车,会看到 (getint) 不能接受输入 0。
5 F- c0 v: ^5 c! T0 @% R! u我们再输入 (initget 3)(getint) 回车,会看到 (getint) 不能接受空回车和输入 0 。因为 3=1+2。
6 f2 G9 j) |, T/ M6 G1 k依此类推。
: p$ s4 f  h4 \+ n7 K我们再输入 (getint) 回车,会发现前面 initget 的设置已经不起作用了。因为它是一次性的。
% K1 \# y# S3 N/ u( @/ y$ V1 \- s/ v0 n6 z9 V- P
第二个参数是一个字符串,用于设置允许用户输入的关键字。多个关键字之间用空格隔开。
, i* ~8 U2 C( B& x2 X如:CAD画圆命令 circle ,在用户指定圆心后,命令行提示“指定圆的半径或 [直径(D)]: “。这一部分如果用 lisp 来写,就可以写成
  1. (intiget 7 "d")1 i1 p  R  |' n- v3 E( n
  2. (setq r(getreal "指定圆的半径或 [直径(D)]:" ))
复制代码
代码中第一行的意思是:下面的等待用户输入函数只能接受正数或字符"d"。
" ?- \1 {: Q1 A& S0 O5 E% X第二行中 r 的值只能是用户输入的正数或字符"d"。9 `0 b7 A" N3 m! p# s7 ^
$ ^# L* S. K2 C* d
至于对用户输入的处理,就需要 if 或 cond 函数出场了。
 楼主| 发表于 2013-2-8 17:53:30 | 显示全部楼层 来自: 中国北京
woaishuijia 发表于 2013-2-6 23:37 static/image/common/back.gif5 \# H$ h" C6 n
initget 函数用于为 getint、getreal、getdist、getangle、getorient、getpoint、getcorner、getkword、ent ...
+ U0 N/ J- S9 ]9 [' k  ^
对于关键字,返回的都是字符串,可以用关键字控制if或者cond的选项吗?
& G; K3 ^3 ?  ]( D+ U! N/ D$ rps:版主新年快乐
发表于 2013-2-8 23:13:02 | 显示全部楼层 来自: 中国北京
下面的代码主要展示 initget 函数的用途及对用户输入的判断和处理.代码中的关键字只用了一个,实际应用中如果是多个关键字,只是判断和处理复杂一些而已.
  1. ;;;画圆. _" j5 n' W  U
  2. (defun c:aaa (/ p1 r1 d)
    0 f0 {! S3 D7 i1 K2 r/ \, ~2 C
  3.   ;;指定圆心: J0 K' {$ {; K( \) W3 b
  4.   (if p                                        ;检查是否存在用户以前输入的圆心
    9 t( O/ C- X( W) A( b6 V
  5.     (progn                                ;存在以前的圆心,作为本次输入的默认值' X" z7 _& ]* ^( D
  6.       (setq p1 (getpoint (strcat "\n指定圆心<"
    7 _4 v; B4 o2 I
  7.                                  (rtos (car p))8 S# w: k3 q$ ]4 H% i  h" B# K
  8.                                  ","
    ( C0 ~- m% s) I5 `. w* r" x
  9.                                  (rtos (cadr p))6 j$ }: V0 L. k1 k- T7 |
  10.                                  ","% b" T2 d( C8 ^& u. r) Z* l
  11.                                  (rtos (caddr p))" x) d! [- P6 Q
  12.                                  ">:"
    * K* r- M, l+ S* [6 o" [
  13.                          )
    , t" B, H# }$ m( @
  14.                ). Z$ ~$ y0 q  `0 a; b# Y2 D3 v
  15.       )                                        ;用户指定圆心
    ! s4 \  @$ `) o! |4 W: y* ~
  16.       (if p1                                ;检查用户是否空回车.如果用户空回车,后面直接使用原值
    ( {6 ~% b( k' M9 g: ~) b
  17.         (setq p p1)                        ;用户输入了新圆心,保存到全局变量,用于画图和作为以后的默认值
    ' Z) V( I, K5 x5 x- U& O. L
  18.       )
    - ?" E7 t8 ^9 O' X, ?) W6 N
  19.     )- ~, Q+ z. }( u
  20.     (progn                                ;不存在以前的圆心
    6 a  ^6 G1 R) X# Y
  21.       (initget 1)                        ;禁止用户空回车
    9 o$ x1 m" Q) U
  22.       (setq p "\n指定圆心:")                ;用户指定圆心
    - W) b0 Y  o) `+ c, K1 l' y
  23.     )
      J& W4 B* r  {2 ^& P2 I
  24.   )                                        ;指定圆心结束
    ' |2 u# K5 v8 B
  25.   ;;指定半径" Y4 ~) z5 o. M" s: X' j
  26.   (if r                                        ;检查是否存在用户以前输入的半径
    / \! U/ z2 N1 Y7 M5 ]% s7 L& c
  27.     (progn                                ;存在以前的半径,作为本次输入的默认值& b) X- ]% \0 B2 `+ A. z
  28.       (initget 6 "d")                        ;禁止输入0或负数,允许空回车和输入关键字"d"3 z( `, X. R. p0 Q6 S
  29.       (setq  R$ q, E7 I( t
  30.         r1 (getdist p (strcat "\n指定半径[直径(D)]<" (rtos r) ">:"))
    2 _% j# A8 m0 x5 S
  31.       )3 Y/ F$ x8 D% H# t* Q
  32.     )
    + n* F7 p- v8 r# R$ u8 U- \. H
  33.     (progn                                ;不存在以前的半径% N" p/ J5 e; R3 F7 R
  34.       (initget 7 "d")                        ;禁止空回车和输入0或负数,允许输入关键字"d"
    ; j, T- A. F1 z1 c7 O# [$ ?, b" ^
  35.       (setq r1 (getdist p "\n指定半径[直径(D)]:")). I& b$ U0 k( E8 {7 N
  36.     )3 A4 f2 E9 P4 D- J0 a
  37.   )  ]+ P) D. F, [  X0 Y, f: p; e
  38.   (if r1                                ;检查用户是否空回车.如果用户空回车,后面直接使用原值, ?4 o0 l6 o' U' Q9 h' |4 C+ R
  39.     (if        (= r1 "d")                        ;输入了正值或关键字,检查是否关键字
    9 H( N& v9 s$ X& N
  40.       (progn                                ;关键字D
    $ c. ~& O& B" k8 V3 e
  41.         (if r                                ;检查是否存在用户以前输入的半径
    : Q) n6 s: L+ H% Q
  42.           (progn                        ;存在以前的半径,作为本次输入的默认值, D; E7 D9 U2 b% l6 P7 `
  43.             (initget 6)                        ;禁止输入0或负数,允许空回车
    + s* }! ?5 z  D( H% X
  44.             (setq
    3 _  }( f0 ]4 J6 G9 X, E4 b6 h
  45.               d        (getdist p (strcat "\n指定直径<" (rtos (* r 2)) ">:"))0 `( r' E3 ~3 k# ]; v$ {
  46.             )
    ! Z* K8 T+ I7 D) b1 q
  47.           )" z5 R, {3 D" `6 q
  48.           (progn                        ;不存在以前的半径
    / s- ~5 o& n( R4 w) C; O0 M
  49.             (initget 7)                        ;禁止空回车和输入0或负数
    ( _% I/ |2 u$ V0 u6 e
  50.             (setq d (getdist p "\n指定直径:"))7 w; P* N4 Q& a  y9 I  w0 B0 a
  51.           ), x) D3 ~% k: N9 p, ^
  52.         )7 u0 v  ~: W2 P/ p+ ]0 D
  53.         (if d                                ;检查用户是否空回车.如果用户空回车,后面直接使用原值
    % n* M& X4 [) o. u
  54.           (setq r (/ d 2))                ;用户输入了新直径,计算半径并保存到全局变量,用于画图和作为以后的默认值$ ~; R/ `, h* m0 `4 M+ u) }6 i
  55.         )9 V7 w& P1 d; h+ `: Q3 {
  56.       )
    3 `: P7 x9 v2 n. n8 S8 C; z
  57.       (setq r r1)                        ;用户输入了新半径,保存到全局变量,用于画图和作为以后的默认值, Q0 r/ `+ _" i+ {' `9 p5 v
  58.     )2 p! o2 B0 [* a$ x$ v
  59.   )0 r1 @$ r4 k. U- T- `* z$ c' ?
  60.   (command "circle" p r)                ;画圆
    2 K) j5 Y' m7 @7 n+ h2 O
  61.   (princ)                                ;静默推出" d" Y( S3 B" r5 H) }1 |7 A
  62. )
复制代码
