查看: 4944|回复: 3
[注意] 跪求90°侧铣头后处理,G18 G19程式
发表于 2010-10-14 16:45:01 | 显示全部楼层 |阅读模式 来自: 中国江苏苏州
跪求谁有G18 G19 后处理啊  我真的很急很急 非常急  谢谢各位高手了
) q' E6 U$ |* B, UQQ254796733
发表于 2010-10-14 19:13:06 | 显示全部楼层 来自: 中国重庆
INTERACTION (USER_1)"Start Main Program Number"+ V. v) G/ m1 ?/ t
PNum=100;  M* [) c% Z% w. A/ r
INTERACTION (CHARACTER)  "Use   Sequencing?(Y/N)"
! n  M& p& e: ^" z0 v+ ^2 k* {( SSeqFlag="Y";
; W/ m! z5 `* U( J4 \( a5 D' I' M, L2 L, O/ y. d" T
FORMAT (COORDINATES) Ynew;! h+ f. N; z! G- l- c1 ]
FORMAT (COORDINATES) YCENnew;
2 H3 i- w5 X! HFORMAT (SEQUENCING)  CurSubNum;
: {4 F- w% F+ _! {6 W3 Y* r. V
! x" s% M+ G! e5 F! m/ OMODAL X_CURPOS Y_CURPOS Z_CURPOS  X_CENTER Y_CENTER;8 t6 G- l5 l, G" m: H
MODAL MOTION_CODE CUTCOM_ON CUTCOM_OFF MCH_FEED CIRC_MOV;- p" i9 R/ k/ B
MODAL CYC_RETR CYC_PECK CYC_DWELL CYC_XSHFT CYC_YSHFT CYC_RETR Z_CYC_DEPTH Z_CYC_CLEAR;# r# s! {. X. D. S; g* G. U  D
MODAL  SPIN_DIR SPIN_SPEED;$ B6 X  [, y% p3 w1 X* _+ ~3 J; i
0 g8 \; ]3 r# |% ~& P3 l
& I% s: ^9 A3 b& y( `- L. O$ BNEW_LINE_IS $;, g8 I( w' ^: M8 k7 [
IF(SeqFlag == "Y")
# X) b# y5 A; b4 _    OUTPUT \J "N" SEQ_NUM " ";
$ ~0 {' A, w  Z6 S2 ^& T  END_IF;3 k  i" \3 H" g- a0 h
    IF (seqflag =="N")
9 _' ^- d& v* S6 g. H     OUTPUT \J;; s! Q( L" d, S/ H5 S' d& j
  END_IF;
8 n+ u" N4 H: b% ]3 k6 P . l/ U5 a  L* P+ T0 u
IF(SeqFlag != "Y") 5 r- j0 g& Z% B' K
    IF(SeqFlag == "y")
0 z; i4 o* `7 W; g9 l) d; o    OUTPUT \J "N" SEQ_NUM " ";
9 C6 {, X6 ?; T' l6 Y  END_IF;
: C# d3 L: _$ q) a6 h  END_IF;
+ j/ l# p' e1 Q" }) ~* v) ~" h) @8 l  z0 Q( a 0 r. _. ^) R2 |$ _+ y& Z. e
  IF (seqflag !="N")
+ x6 W' I+ F8 Q  x) T" p    IF (seqflag =="n")- i! ?6 U/ f6 |$ ~
     OUTPUT \J;
. S  T" O# G) \( g$ l  r  END_IF;6 B* z) X7 \$ R. ]5 u
  END_IF;9 A1 c& w9 t! Y4 L' v
! E* U! k8 o8 l; p
BEGINNING OF TAPE: 4 Q! l) z* v% _& a
        OUTPUT \J "G90 G80 G40 G21 G17 G27" ;: n& u% V2 k6 J" z$ {
        OUTPUT \J "(UAO,1)";
( Y3 k1 }7 A% k& v4 g5 Q' ~1 R        OUTPUT $ "G00Y" Z_HOME;                        ! R# {. s! n, L, \0 G/ u2 H
END OF PROC:- ?  `! J; J4 K9 K6 f7 |9 F! }/ m
        OUTPUT $ "M05";
, w2 l2 ~1 a) |( \        OUTPUT $ "M09";
% f4 I- r) A* `$ N6 f$ cEND OF TAPE:
8 e7 s8 n+ o, P7 K* H) m8 n        OUTPUT $ "M30";
  w& e/ h0 Z$ p, m7 s3 u( E3 p/ P. U
TOOL CHANGE:, ~- R. F. j! o9 Y8 @, H4 D! _
        OUTPUT $ "T" TOOL_NUM " M06" ;        : _, ], v2 f& |7 W! X7 h! X
        OUTPUT $ "S" SPIN_SPEED " " SPIN_DIR " ";
  I* }! y9 l, @- i& ?8 I7 U         OUTPUT $ MCH_COOL;        / v8 N6 c6 \/ A" i, R: p
START PROC: ) ^7 ?7 V: s* Y" y) t+ K1 x
       IF_SET(SPIN_SPEED)2 G! }7 V3 ^: f1 w7 D
      OUTPUT $ "S" SPIN_SPEED " " SPIN_DIR ;" {& ^. R, I4 b, p
      OUTPUT $ MCH_COOL ;
4 }5 e, P) w9 Y/ d: L) Z+ K7 B) I END_IF;
& k4 h8 n8 Q" Y9 H* l, O; l6 }) P2 h  r  m4 M6 |. L
$ e6 b! f7 W( V: p% S* XLINEAR MOTION: fast:1 J, d( s2 ~' {
  Ynew=0-Y_CURPOS;5 J: n$ d9 q, l+ Y+ O
        OUTPUT $ ;9 g3 `0 u5 E1 q9 Y( M
        IF_SET (MOTION_CODE) OUTPUT MOTION_CODE " " ;         END_IF;
2 `+ ?+ f: Z/ S5 c- O1 R        IF_SET (X_CURPOS)    OUTPUT "X" X_CURPOS " " ;        END_IF;
! E3 u, H. u- o% j5 o1 i7 H$ A        IF_SET (Y_CURPOS)    OUTPUT "Z" Y_CURPOS " " ;        END_IF;2 ~4 p  }8 z* O
        IF_SET (Z_CURPOS)    OUTPUT "Y" Z_CURPOS ;            END_IF;# P6 W) F: o# Y% X; ^
$ I5 k+ }/ _( S+ E& r( j- j
2 [9 u/ ^2 Q" ?( U4 t1 d) P2 N8 i
LINEAR MOTION: fastlencomp:( ~  T) _0 Y8 J7 p: E+ @5 U: ^. k
        OUTPUT $ CODE_CUTCOM_LEN " H" TOOL_NUM " Y" Z_CURPOS;
  z+ A7 b4 @  X7 N3 d* V) O3 K2 {" G+ p' C2 d9 D6 p- J( z
. o( |) k- V! J* U2 U9 l, ~
LINEAR MOTION:
+ u* }, r8 N3 v! ]  R
" H& m( Y: w" a2 p+ Z& L        OUTPUT $;" \4 {# d" N: [: G0 q
        IF_SET (MOTION_CODE)         OUTPUT        MOTION_CODE        " " ; END_IF;5 P& T  S- J! d: R7 m
        IF_SET (CUTCOM_ON)        OUTPUT        CUTCOM_ON        " D" TOOL_NUM " " ; END_IF;
" @, R$ z. _" K+ ]        IF_SET (CUTCOM_OFF)     OUTPUT        CUTCOM_OFF        " " ; END_IF;3 K( E8 R1 e) L3 h
        IF_SET (X_CURPOS)        OUTPUT        "X" X_CURPOS        " " ; END_IF;2 ]3 m" J- N1 n
        IF_SET (Y_CURPOS)        OUTPUT        "Z" Ynew        " " ; END_IF;: c2 D, {% s/ W1 @3 D
        IF_SET (Z_CURPOS)        OUTPUT        "Y" Z_CURPOS        " " ; END_IF;
/ f$ w3 P" {, S( P2 \        IF_SET (MCH_FEED)        OUTPUT        "F" MCH_FEED;         END_IF;
5 S+ c+ L$ E' E. f/ |+ d& s9 I/ M. V' n# i" y" |
CIRCULAR MOTION:
" O" Q! J8 j; ~4 Z5 `3 ~+ @* l# EYnew=0-Y_CURPOS;7 P2 U. F& M- F; H# l  g
YCENnew=0-Y_CENTER;$ [& N8 m8 j- V9 v( C7 I$ @( o
        OUTPUT $;
4 R8 M6 {6 Y" x8 J        IF_SET (MOTION_CODE)        OUTPUT        MOTION_CODE        " " ;        END_IF ;
3 z4 `+ ]% l( Z( V+ Z+ [$ T        IF_SET (X_CURPOS)        OUTPUT        "X" X_CURPOS        " " ;        END_IF ;
' r/ R0 [, v+ m) K* Z. j! X        IF_SET (Y_CURPOS)        OUTPUT        "Z" Ynew        " " ;        END_IF ;
+ ]+ V  }9 \7 A1 N/ \% f        IF_SET (Z_CURPOS)        OUTPUT        "Y" Z_CURPOS        " " ;        END_IF ;0 K, N* ~. H1 O/ [% v- M+ j- @
        IF_SET (Y_CENTER)        OUTPUT        "K" YCENnew        " " ;        END_IF ;4 ~) y/ o& n4 S2 V4 T4 f/ e
5 {5 A+ \5 W9 d* H8 Q
; v" F" G9 ], _& z
4 h$ }" R. B8 F/ N, p$ X& UCYCLE:
3 g/ V  R7 B' k& V# H1 V+ c* W4 t; \8 N( b, B# L3 Q
        IF (QUALIFIER_NAME == "on" || QUALIFIER_NAME == "toinit")
+ t1 z/ s5 S8 V/ D( T, z        SET_ON  X_CURPOS Y_CURPOS A_CURPOS B_CURPOS Z_CYC_DEPTH Z_CYC_CLEAR MCH_FEED;7 N/ b) X& \' h( S1 u7 ?
        END_IF;        7 J8 z6 b3 h# n9 `
        Ynew=0-Y_CURPOS;
3 }9 e$ O; ?7 u        OUTPUT $;* W, o# ?& E0 O
        IF_SET (CYC_RETR)        OUTPUT        CYC_RETR " ";                END_IF;" W. Y3 `" K8 _5 j9 c, J
        IF_SET (MOTION_CODE)        OUTPUT        MOTION_CODE " ";        END_IF;
, Y  K) L: B- X+ W8 y$ t) s* t0 c        IF_SET (X_CURPOS)        OUTPUT "X"        X_CURPOS " ";        END_IF;
2 d* D& ]' |9 Q4 R( p( _; f        IF_SET (Y_CURPOS)        OUTPUT "Z"        Ynew " ";        END_IF;1 s7 b/ b8 w/ X# c
        IF_SET (Z_CYC_DEPTH)        OUTPUT "Y"        Z_CYC_DEPTH " ";        END_IF;        % B. E( Z( V: m1 n# B4 ~
        IF_SET (Z_CYC_CLEAR)        OUTPUT "R"        Z_CYC_CLEAR " ";        END_IF;
, q5 _+ L0 `( m  V) [* D8 ]        IF_SET (CYC_PECK)        OUTPUT "Q"        CYC_PECK " ";            END_IF;
! y! v+ S& B+ L! z4 g' x        IF_SET (CYC_DWELL)        OUTPUT "P"        CYC_DWELL " ";           END_IF;
- @: ]3 ^# s0 ]( n" I9 n        IF_SET (MCH_FEED)        OUTPUT "F"        MCH_FEED " ";            END_IF;+ o$ r; n0 v( X& t% C
CYCLE: off:
7 R# v* d; y2 i. ?! l
$ R, q  o: L+ `        OUTPUT $ "G80";        % c5 \  h0 {) Y) M
POST SCRIPT:5 c0 q/ I$ J. i/ e
                SYSTEM_CALL "MD " FART_NAME ;' N$ `& |3 L1 V6 B$ k) |* Y0 \# _+ j, c
                SYSTEM_CALL "MOVE " FILE_NAME " "PART_NAME"\"TP_NAME".nc" ;
7 f, H5 C& z6 _$ P) F
5 a+ t1 N) F7 i               SYSTEM_CALL "DEL /q   *.xml  *.GPP2  *.msg>NUL";
, x7 M6 e' B7 M6 C3 T                SYSTEM_CALL "DEL /q *.P01 *.P02 *.P03 *P04 *.P05 *.P06 *.P07 *.P08 *.P09 *.P10>NUL";
2 Y' c' [: P. Y8 C3 f- j         FILE_NAME = PART_NAME+".nc" ;  ( ~6 N2 Z  C. ~2 y" d7 H* i
        OUTPUT_DIR = OUTPUT_DIR + PART_NAME + "\" ;% z! H: @% q4 `( V# S. h" q
给你借鉴下
发表于 2010-10-15 12:17:38 | 显示全部楼层 来自: 中国福建厦门
这个不是G18G19的
发表于 2012-5-19 18:41:37 | 显示全部楼层 来自: 中国山东青岛
到青岛速通数控培训学校技术支持页面下载一个侧铣后处理器就行了www.qdsutong.com/jishu.htm
