发表于 2008-9-11 08:29:57
来自: 中国辽宁营口
参考下面例程:
8 W: M. v, ~) I* H1 j/ \7 ~; W0 Y, K7 y$ ^ |
打开Windows记事本,写入点坐标(如下图)并保存为“E:\1.txt”# z1 p4 _0 T" S4 l# Q
. [: m: t+ `3 j2 k3 E
6 e! [' r9 Z" p
在VBA编辑器中写如下代码
1 U$ P: n; k, t* e0 U. e( y---------------------------------------------------
5 K2 W }4 y& R2 A9 ZSub A()
. _: M# H+ I# }* X A Dim F As Integer, P(2) As Double% E) H$ s; B' ]/ K* U, t7 V0 M5 Y, K
F = FreeFile()
8 {6 [5 Z' w) j6 w$ p7 j. B Open "E:\1.txt" For Input As F5 F* |* r7 {/ m h
Do Until EOF(F)
) L- ?7 i7 I( ]) l( H) L1 q Input #F, P(0), P(1), P(2)
: _( a/ {+ n( m8 i ThisDrawing.ModelSpace.AddPoint P
* G- u: ^& [6 W4 [4 g Loop
8 B. a2 ~1 I6 D# G8 k1 a5 J Close F
c& a9 s) u# v9 k: [2 l0 uEnd Sub; K" W; c) d0 }5 A' p
' y3 a+ Z* D9 q$ m* R8 d- C# d# X+ b3 R% i) n7 Y! ?$ W9 ?4 B: b
下面的代码也可以3 G2 Q+ b9 o; f2 ]" ]% P. |
" o- ]: z7 n w) a8 R1 p* G# c/ eSub B()
/ o- u, P S( R2 Q Dim F As Integer, S As String9 T5 `9 q. f* r: N
ThisDrawing.ActiveSpace = acModelSpace
1 C. ]% g5 [6 E( N1 t8 J F = FreeFile()0 T! K7 f9 @4 {$ Q7 S
Open "E:\1.txt" For Input As F2 J: {& s' ?: G
Do Until EOF(F)
) ?+ f; I: m9 ?9 c Line Input #F, S
8 i9 z( z7 P8 w& K9 b ThisDrawing.SendCommand "point " & S & vbCr
4 H" A+ B- T. J0 M Loop
0 O+ F' d+ c m& P% ~2 ^- Y Close F
/ N( u. F3 w1 ~- y8 w/ h! X; fEnd Sub& `4 W- w+ @5 `3 I3 l
